PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 [318] 319 320 321 322 323 324 325 326 327 328 329 330
  1. O2 sensor "low voltage" SES light. Please help.
  2. What's up with TPIS long tubes
  3. Swapping in an LS1/4l80e
  4. ""Paging VerbsZ28""
  5. Can we discuss the pricing breakdown on the X-pipe setups?
  6. Which Driveshaft Loop ?
  7. Need some aftermarket flywheel/clutch help BAD!
  8. Need some Clutch help BAD!
  9. Anyone with Adjustable Borla Exhaust ?
  10. What ET gains with a LS6 intake Vs. LS1 intake on a cam car?
  11. Adding flanges to SLP LTs?
  12. Hooker Cat-Back System
  13. Anyone tried the QTP Ram AIr
  14. extra hole in the flywheel orientated with the extra hole in the crank?
  15. hooker super comps
  16. My LS6 Intake Dyno Gains
  17. what would you guys rather do for your exaust?
  18. ATTENTION: SIG LENGTH LIMIT!!!
  19. Has anyone dyno'd 4"mufflex or Random tech catback?
  20. People with Duals..how much did it cost?
  21. help! breaking up at high RPM
  22. SLP maf sensor
  23. Cold Air Induction
  24. Stupid fuel pressure question??
  25. dr.gas X setup
  26. What is this "direct hits" ignition system?
  27. Parking ticket.
  28. I finally saw the GMMG and Corsa.... my thoughts.
  29. Need some help with a fuel system i want to use.....
  30. Help! Cant figure this out
  31. Nondestructive MAF screen removal
  32. Front seal leak after ASP install...
  33. Knock Sensor Part #?
  34. Question bout plug/wire installation
  35. ENGINE CHIRPING, grrrrr
  36. recent F-Body magazine articles
  37. Help me pick a muffler for my duals!
  38. Flowmaster series 10
  39. I broke down and ordered FLP LTs
  40. borla adjustable cat-back
  41. G2 aluminum D.S.
  42. headers burn my 02 sensors
  43. location of coolant sensor ??????
  44. Loud Mouth cat-back exhaust system ????and cutout vs loud mouth
  45. LS6 heads vs LS1 heads
  46. AC fluid amount?
  47. Descreening the MAF, richer or leaner?
  48. Stock and looking for mods
  49. ASP Crank Pulley Installation... any suggestions?
  50. Grotts are ON!!!!!!
  51. What type of epoxy should I when I port my TB?
  52. fuel pump & regulator question
  53. Where to get an Aluminum D.S from??
  54. Need some help please.....
  55. door screen mod
  56. TB compatibility question
  57. I need some exhaust advice...
  58. GM battery post adapter for 'Dyna-batt' type battery's?
  59. WTF??? help me??
  60. How screwed am I? Sheared off a bolt for AIR pipe
  61. `02s screen or no screen in MAF
  62. will dual/dual off of an SS bolt on my TA?
  63. New specs on Random Technology converters
  64. FLP or SLP headers
  65. LS1 or LS6 Intake Manifold
  66. Header to Y-pipe setup...
  67. Duals Sound?
  68. What could this noise be...
  69. Do all lids require you to cut part of intake
  70. Loudmouth and SLP Headers?
  71. Fuel Injectors for STOCK motor?
  72. Pictures of FLP LTs installed??
  73. Macs
  74. stock airpump crankcase ventilation/vaccum system pics and vid!
  75. i need an $ome opinion
  76. OIL??? What is best???
  77. cool fuel better????
  78. Need Help Please...
  79. Mod ?
  80. flp's clearance
  81. Whats better: Pace calibrated LS6 MAF or stock ported?
  82. How to get exhaust pipes apart after clamping
  83. '01-'02 guys with LTs, do I need 98-99 AIR tubes?
  84. Calling all Bolt-on Only Users
  85. Port & Polish TB/MAF Question
  86. Lower temps in engine compartment
  87. Performance MAF?? Which One
  88. LT's and ORY?
  89. Easy hp...
  90. Y-pipe Q.'s
  91. Having a couple probs with my car
  92. d/d vs cutout
  93. mods!
  94. Planned Mods
  95. dump to single muffer before axle?
  96. Need replacement bullet cats for TTS headers (onfire?)
  97. Need a few tips on installing O2 in SLP LT Headers
  98. Plugging O2 bungs???
  99. Whats needed fro ZO6 intake install and ditching egr?
  100. Trading my 01 on an 02 this week...
  101. Y-pipe to stock manifolds?
  102. where can i get the bolts that connect the AIR to headers?
  103. need help fast !!!!!!!
  104. K&N Generation II FIPK vs. Airlid
  105. Stock Throttle Body...
  106. exhaust leak with dynatechs
  107. 99z28rs
  108. EGR Removal
  109. 160 thermo question
  110. MAC install ?'s
  111. Throttle body
  112. Does anyone make an oil filter heatshield?
  113. +15.5 RWHP & +7.9 RWTQ squeeked out of my "Ultimate Exhaust" & Shaner TB w/LS1_Edi
  114. LoudMouth w/ SuperTrapps
  115. just put my new thermostat in!
  116. Cutout & Y-Collector
  117. True dual gains Vs. ORY/cutout:ETs and HP/TQ?
  118. LT collector/y-pipe sizes...
  119. Fuel Pressure
  120. Crankcase Vacuum w/ Exhaust Sucker Thing?
  121. will a bigger TB help my set up???
  122. Any chance I might be loosing power from this?
  123. GReddy oil catch can idea.
  124. Installed Greddy catch can today. Question about TB hose & oil consumption...
  125. Y-Pipe and Muffler
  126. MASTER LIST: All possible bolt ons...EVERYTHING
  127. Need hocker to y pipe clamps!!!!!!
  128. elec. cut out where to buy?
  129. leaded fuels & o2 sensors
  130. GM solution to detonation
  131. convert my AIR pump into a vaccuum pump?
  132. why is it boiling over???
  133. Rush Performance airfilters
  134. Hooker install Q's?????
  135. Mufflex
  136. I need FLP's phone #...
  137. headers and no gains!
  138. Firing order?
  139. Long tubes with cat y-pipe....
  140. Why does my computer reset upon almost all startups?
  141. delete the AIR or not
  142. ***LOUDMOUTH***
  143. How much power am I making??
  144. open headers question
  145. GReddy catch can installed
  146. Anybody know of...
  147. dyno'ed my 2001 a little disapointed
  148. Fuel pressure
  149. exhaust idea
  150. headers
  151. Anyone have a sound clip of a B&B with a cam .
  152. Problems getting my intake EGR blockoff plate to seal.
  153. EXTERNAL Fuel Pump Recommendations?
  154. Pulley's on an A4?
  155. How tight..... shock tower brace?
  156. Headers and AIR system
  157. General Question
  158. Has anyone removed the smog pump???
  159. Raising the air box on an SS?
  160. "Click" ...... Thats it HELP
  161. custom quick change cutout pipes done today at FLP
  162. 3" true duals...
  163. did I order the correct helms manual?
  164. need dr gas part # for x pipe stystem for SLP LT's
  165. Best Headers
  166. best sounding exhaust
  167. The best flowing "Long Tubes" Facts???
  168. Question for those with Hooker LT's and lowering springs........
  169. One cat as opposed to two cat's??
  170. would cats solve my rich problem and gain power?
  171. air pump
  172. Part# for coolant bypass for the LS6 intake?
  173. should I be popping?
  174. MSD fuelpump
  175. Anybody want an NGK spark plug sticker?
  176. Will de-screened stock MAF cause low line pressure?
  177. 4 degrees KR, help!
  178. Oil filler neck question?
  179. Here's another option for Loudmouth and ORY-pipe owners
  180. SES light turned off??!!!!
  181. Thermostat 160/180 and Radiator
  182. What was the last year for the EGR?
  183. Should GM supercharge LS6 ¿?
  184. Header question
  185. Car running like shit in hot temps!!!
  186. PRO/CON 160Degree Thermo
  187. What can a LS6 intake flow @ 28 in?????
  188. Where did you mount your MAFT?
  189. People with fuel sumps
  190. 360RWHP with bolt ons... is it possible?
  191. Trans. cooler placement?
  192. Is a MAFT a must when running headers??
  193. 2000 SLP headersand EGR/air questions
  194. Holley Intake on a '98
  195. Y-Pipe for hooker LTs and SLP Loudmouth
  196. If the Thermostat is a restriction, can you remove it in the summer??
  197. Wanting Tru-Duals but plan on lowering...
  198. LM Performance is selling the Qwik Stick
  199. LS-1 Fuel Pump For Datsun 280Z
  200. SLP 85mm MAF
  201. Is anyone running this Dr Gas Exhaust
  202. Any tricks for valve cover removale and replacement?
  203. Heat Resistant Tape ?
  204. LS6 intake install......now idle trouble!
  205. electric cutout valve owners (mccord and qtec) where is your switch hidden!
  206. Weird smell after header install....???
  207. Fuel Pressure dropping to 45psi...
  208. I got one for ya'll!
  209. Coolant LIGHT sensor part #???
  210. My QTEC Leaks....
  211. Remove MAS Screen?
  212. Meziere elctric water pump who has one ?
  213. 50lb injectors and stock fuel system?
  214. Dynabatt Qs
  215. Verdict? Hooker headers = FLP etc...
  216. removed power steering pump HTF to route belt?
  217. belt size/part # for asp pulley and no power steering?
  218. Corsa/Borla exhaust system questions about efficiency
  219. Where can I buy Corsa exhaust tips from?
  220. Finally an easy PCV solution for our cars
  221. HELP, did i get screwed on my Y pipe?????
  222. can I race with this catch can?
  223. Help! Think I crossthreaded while putting headers on.
  224. Full Hooker exhaust system
  225. source for stock looking 3'' exhaust tips?????
  226. UPF58 is still available for $4.10 each...
  227. Which bolt to remove for shorty belt mod ??
  228. How often does everyone change their plugs?
  229. Brake lights part number ???
  230. please help
  231. I got my Super sucker cold ram air kit in and tested......
  232. flp and borla cat back
  233. BEST CAI?
  234. BEST AIR FILTER K/N,HOLLY,AMSOIL,SLP DONALDSON?
  235. Spark plug wires?
  236. Finally a couple pics and 1 sound file of my exhaust!
  237. slp header install question(s)
  238. 3600 Vig installed now low oil light is on?????
  239. where can I get a two step for LS1??
  240. pulled power steering/what to do with lines?
  241. where to get asp pulley in stock?
  242. I need serious help.
  243. Rapidfire #8, Rapidfire #12 or Tr 55? Indexing Plugs?
  244. Throttle Body...BBK or PORTED
  245. Which plugs / wires?
  246. how long to get ls1 edit
  247. Fog Lamps on TA's
  248. perfect air/fuel ratio?
  249. Anyone hear about this Dynomouth Exhaust
  250. what can i hope for geting good exhaust?
