PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Anyone hear of this UD Pulley before?
  2. E cutout wireing ?
  3. bigger mas air will it help?
  4. fast 90 and nw tb help and question
  5. 6.0 oil pan vs. stock ls1 oil pan
  6. SLP D/D Intermediate Pipe Diameter
  7. Tsp headers???
  8. Borla Y-pipe ???
  9. E-cutout problem
  10. P/p throttle bodies
  11. Will a set of cats get rid of the gas smell?
  12. heads
  13. slp ls6 intake
  14. going from 3in tsp ory to 2.5in custom ory help!
  15. TPS not reading 100%
  16. Where can i buy a throttle cable?
  17. Underdrive pulley with LS7 clutch
  18. Stainless Works merge WTF??
  19. TB question, need answer asap plz
  20. 2000 ws6 exhaust
  21. installing coilpack relocation kit, (thunderracing) pics, need opinions
  22. Right way to burp or bleed 98 ls1 cooling system
  23. Need to know!!!!
  24. misfiring.....help
  25. Problem with cruise after install of 92/92
  26. loud mouth...too loud
  27. Sweet Thunders vs. Powersticks? sound wise...
  28. ls6 intake install (grinding)
  29. Injectors
  30. Water pump help
  31. headers vs gas mileage
  32. breathers?
  33. My Exhaust Install, LOTS of pics
  34. Who is using this x-pipe for their true duals
  35. Replaced alternator.... now belt giving me a problem
  36. Oil Pressure port on back of block
  37. Seized balancer???????
  38. Ls6 intake question
  39. how do the coolant tubes underneath the TB come out???
  40. knock sensor wiring harness part #
  41. question on TB tubes
  42. Differences between LS1 and LQ4(6.0l)
  43. Header install ?
  44. Prothane mounts wont line up!!!
  45. My exhaust clip...
  46. underdrive install
  47. catch can lines for 408?
  48. Which ory for headers...
  49. engine knocking/surging help!
  50. weird fuel/trims problem
  51. billy boat
  52. Port matching questions
  53. what kind of power will this make?
  54. lost bolt - even the simplest things are a headache
  55. loudmouth or flowmaster??
  56. So I just got my pro 5.0 shifter and and UD pulley.
  57. SLP Smooth Bellow Write Up/ Review
  58. Meziere water pump question
  59. how do you tune out rear o2 sensors??
  60. anyone run the vibrant racing resonators for exhaust?
  61. larger PS pump?
  62. Intake questions??
  63. Nitrous Plate Question?
  64. Would I benefit from this.
  65. Edelbrock 90mm TB
  66. Ls1 intake manifold modifications....
  67. the best headres please?
  68. Seafoam
  69. ported 90,,,, need to make a gasket {need help}
  70. Four tip CME???
  71. ls2 intake with Fast 90 or ls6 intake with Ported TB?
  72. intake change?
  73. ls2 heads on an ls1
  74. Ls6 Intake Question
  75. Weird Starter problem
  76. head comparison
  77. im so torn right now...
  78. ebay headers- which y pipe?
  79. Header pic
  80. What should i use with my ls6 intake?
  81. Typhoon install questions
  82. Powerpack vs. Borla XR-1
  83. best 100mm maf
  84. Water Temp Guage Install ERROR!!
  85. need help with manifold
  86. Descreened maf
  87. What stall do i need
  88. Manuals w/25% Underdrive Crankshaft Pulley
  89. If i have truck coil packs what plug wires do i run?
  90. Can we do a GP on GMMG exhaust?
  91. starter install
  92. swapping egr
  93. LS2 VS LS6 intake manifold
  94. Rough on Cold Start
  95. Slp loudmouth 2 review
  96. Weiand Street Warrior
  97. will these o2 extensions work?
  98. Cable operated cutout? Do you have one?
  99. Header size hurting me??
  100. Magnaflow quad tip
  101. Alternator is NOT charging!!! i need help
  102. Long tube header question
  103. ls6 intake vs. typhoon intake
  104. FAST 90 and GMPP ASA Cam = power?
  105. Painting headers question
  106. PLEASE HELP!! mail order tune
  107. Searching for UD Pulley intallers in El Paso, Texas area!
  108. What puller to use on the LS1 crank pulley.
  109. just got a new exciter wire, why 4 wires????
  110. Cut out Open vs Closed Dyno Sheet
  111. Td video thread
  112. how to take out the valve cover vent hose?
  113. Fuel rail with truck intake?
  114. Anyone make this ? X pipe
  115. 100mm mass air
  116. Borla from a 95 T/A to a 01 T/A?
  117. How to fix driver side angle of LPP headers
  118. Advantages of ported FAST 92 over ported FAST 90
  119. 99 EGR on a 2000 ws6
  120. Re-use intake manifold gaskets?
  121. Oil Pan Gasket
  122. Can anybody help with UD pulley install.
  123. 317 heads with Lsx intake??????????
  124. tax return what to do what to do!!!!
  125. header questions
  126. Do injectors go bad from sitting?
  127. Another Header Poll: LPP vs. Hooker
  128. How many wires are supposed to be in the alternator plug?
  129. My Girl's Kooks/Loudmouth sounds better than my car!!! WTF
  130. ses light-o2 sensor bank 1 sensor 1 after headers
  131. LS1 or LS6 Intake
  132. carb style intake
  133. what manifold is this?
  134. Engine cutting out, temp gauge goin crazy
  135. LS6 Manifold on a 98-00 Camaro?
  136. Gasket prices...
  137. 2.5" to 3 " pipe
  138. Muffler and turn-down after y-pipe...Which muffler?
  139. Weiand 5000 vs FAST intake
  140. Shorties vs LTS
  141. Why does a bunch of blue smoke exit my exhaust.
  142. Auto guys w/ underdrive pulleys?
  143. T56 plastic covers/shield? What's it called? Part Number?
  144. GMMG Chambered Exhaust Vs. SLP Loudmouth
  145. How do I find out what series flowmasters I got
  146. no spark
  147. Corsa Or Borla for my situation.
  148. header install update..
  149. Which Air Lid fits the best?
  150. ARH question
  151. Crane gold roller rockers. Keep the 1.7's or go 1.8 with a maggie
  152. ???where is the star connector.....
  153. Bad Ignition Coil or Tuning?
  154. cats for exhaust
  155. 2002 WS6 Exhaust
  156. American Racing Headers are installed
  157. Jet-Hot Coatings
  158. Sound clip TSP rumbler w/ Catted Mac Mids?
  159. ebay underdrive pulley
  160. Question for anyone running Lt,Gmmg
  161. 4.8L valve covers on a 5.7L
  162. Cheapest place to find LS2 TB and 3 to 5 wire MA adapters?
  163. Can i use a truck alternator?
  164. Which flexplate to use on my 403...
  165. guys with kooks headers got a question for you
  166. Need LS1 to LS2 cam and knock sensor harnesses
  167. 90mm TB and Maf connecton?
  168. 2004 GTO Alt
  169. Header install difficulty (kinda long)
  170. Need to Add Cats, help please!
  171. Texas Speed true duals w SLP header?
  172. where can i find this muffler?
  173. Alternator Wiring Question
  174. Y-Pipe Hitting undercarriage; HELP!
  175. 706 heads
  176. Any way to mod ls6 intake to work with egr.
  177. Need to Vent?
  178. need some help with exhaust flanges
  179. Why is my motor and trans sitting crooked?
  180. c6 tips vs. corsa tips
  181. installing solid motor mounts??
  182. Custom Y Pipes
  183. how much can a 6.0 block hold?
  184. Who sells the Mac o/r Y pipe??
  185. Will I need a tune?
  186. using a ls1 vacuum/smog pump for other uses?
  187. best price for pacesetters
  188. ???someone PLEASE HELP me on WIRING to my ODB2 PORT...
  189. O2 Question???
  190. How to make LQ9 look Good
  191. Anyone running these headers?
  192. Does Anyone Even Use the Air/Egr Fittings On LongTube Headers?
  193. stock intakes
  194. Help!!! Having trouble disconnecting fuel line
  195. Pacesetter LT install tips?
  196. DBW Throttle With FAST90 Intake
  197. Front plate ram air
  198. hand sanding a fast 90????
  199. Header squeak? QTP's
  200. anyone know the casting #'s on the new tahoe head?
  201. How to change power steering pump!
  202. idle problems when rolling
  203. Anyone have a wiring diagram.....
  204. New cats new rattling sound!!
  205. Cam guys: every regret putting cats on?
  206. LTs Which ones do I buy
  207. pissed off, what should I do?
  208. flowmaster comparison ques...???
  209. Guys with Gmmg and H/C come in!
  210. Differences between two intakes
  211. TB & Manifold ?'s
  212. Is there some trick to removing the stock maf?
  213. carb????????
  214. need help w/ header/exhaust setup +shop 2 install
  215. cat question
  216. which muffler should I go with ?
  217. SLP underdrive pulley for my z06??
  218. Upper Radiator Hose Width? Water Temp Gauge Install????
  219. Anybody run a TSP Rumbler Catback ?
  220. exhaust manifolds
  221. Headers,TB,CAI?
  222. Longtubes emissions vs non emissions
  223. ported throttle body?
  224. Build My Engine
  225. Looking for Tall LS Center Bolt Valve Covers
  226. Underdrive Pulley Kit
  227. tools for header install
  228. question about ls6 intake
  229. Disabling fuel pressure regulator
  230. What size TB for MY H/C combo?
  231. Clear Bolt-Ons
  232. shaner throttle bodies
  233. Help, what covers, timing chain, valley, rear engine
  234. Will this combo work? SLP headers...
  235. So my crank pulley just moved about 1 1/2". What the hell?
  236. Open Y pipe?
  237. Fbody headers with C5 (batwing)oil pan?
  238. Anyone seen these headers or installed?
  239. ssra on an ss camaro?
  240. Ls6 engine swap in 2001 camaro
  241. LS1 vacuum port removal.
  242. Findin' a shop
  243. help!!!!!!
  244. Aftermarket Plug wire lenght
  245. Intake manifolds. I'm. Lost. Help. Me....I read the FAQ's...
  246. Broke EVAP tab
  247. ported mass air flow how much do u gain with that?
  248. which header would you do?
  249. EPA standards left to states?
  250. question about thermostat on an 04 or 05 ls1 motor
