- My "empirical" testing of the SLP/Powerbond pulley
- True Dual Duals Build
- Tach?
- SLP Headers to Kooks swap
- NEED HELP ASAP!!! - Best way to remove harness with motor still in car
- LS6 swap complete now what TB?
- What size threads in ASP Crank Pulley
- Throttle body help
- in the middle of heads and cam swap have some questions
- which exhaust do you think flows better????
- ls1 coils to ls3 coils?
- 5.3 swap... more problems...
- Having weird O2 sensor issue. (Advice)
- Want my camaro to sound like a mustang
- Reinstalling engine...what is this?
- balancer already pinned???????????
- ORY + QTP Header Options
- Thicker Intake Manifold Gaskets (rubber oring style)
- HELP Fan Belt squeak
- Replacing oil pan gasket (price)
- Intake bolts tightening
- bbk header help
- Anyone plumb a line from d/s valve cover
- tps fast throttlebody
- Built motor ls1 pcv sucking up a lot of oil?
- Damn ! Bolts rung off in heads !!! ?
- tsp 1 7/8 vs pacesetter
- fast replacement intake gaskets
- camaro longtubes on c5?
- LQ4 build cam specs?
- rx dual valve catch can plumbing help
- ls2 intake swap
- Heads and cam for my new motor
- Questions about LQ4 build
- Poly engine mount orientation
- Attempted to port an extra TB i had earlier
- Throttle Body Help for 102mm Fast
- Another high idle thread...
- Misfire solutions
- Dbw issues---first post
- 98mm ftp lid
- Ls6 intake questions
- 102mm NW TB on 96mm Typhoon?
- more idle issues....yay
- MAF Question
- Fast 92 on LS1 Gto
- reverse locked out, no ENG SENS fuse blown
- thermostat for bosch water pump 99175
- msd 2 step problems
- 370 lq9
- GMMG CME Setup
- kooks headers question
- Wanting to buy coil pack LQ9 6.0
- adding ignition timing
- FLP headers/ what Y pipe fits?
- Raising Compression Question
- Exhaust Leak
- Edelbrock Vic Jr EFI / PCV Question
- Ls6 valley cover and intake doesn't fit
- MAF Question
- cross threaded rear header bolt.....
- :::Setup for Success:::
- Torquing head bolts ???
- what plugs and gap for my 4.8 with big cam
- trying to find y pipe bracket
- SLP Loudmouth tips?
- Intake question
- What Next?
- P0430 - opportunity to spend some $$? Catback, y pipe...
- Replacing knock sensors, an wire, but will I need to replace the intakes gaskets?
- Bad harmonic balancer on my LS1, which to choose?
- To tune or not to tune?
- ? Im lost ?
- please help me find where this goes!
- Am I full bolt on yet?
- exhaust QS
- 5.3 build project mentor needed
- Will LS1 Coil Packs Fit/Bolt onto Stock LS3 Coil Pack Brackets
- why does it sound like there are birds in my exhaust?
- oil psi sending unit ???
- Coil packs with heatsinks?
- Summer Is Coming, Time To Build!!
- LS1-LQ9 differences?
- v6 starter in ls1?
- LS6 Intake Manifold Experience
- slave cylinder issues
- Stock manifolds
- Whats the best replacement alternator????
- Anyone make an adjustable throttle cable bracket?
- exhaust gains
- Father Son and College.. Opinions
- K&N vs Flowpac
- Best place for O2 Bung for Wideband
- Kooks headers-cats+slp=aweful
- Turbo'd set up with no pcv... why?
- 5.7 to 6.0
- Installed electric cutout on Borla exhaust...
- anyone try one of these intakes?
- Clutch kits Recommendations
- 90mm lsx intake
- nitrous plate + 92MM TB what are you guys using for bellows?
- Tach question
- out with the old, in with the new!! update videos!!
- 2.5" or 3" for my true duals?
- TSP 1 7/8" LTs quick question?
- Anybody go from headers to muffs w/ turndowns?
- just swapped knock sensor question
- Another Exhaust thread(Cat back)
- Power steering reservoir hits iac sensor
- Hooker aero chamber
- Kooks Headers Unboxed- With and Without Coating and mid pipes!
- Need to tame my exhaust!!!!
- wiring up a cutout
- MSD 8733 OR Lingenfelter LNC002 2-step modules
- Ebay valve covers?
- NAPA Radiator
- throttle body adaptor help 90mm to 102mm
- TSP ORY Question
- Low Voltage Code Challenge
- whats the sence of having a borla or lm exhaust
- Have a few ?'s about air intakes.
- Long Tube Headers and offroad Y o2 sensor problem
- LT1 Lanes True dual system to LS1 car?
- Is my BBK now scrap...
- oil pressure
- Spark plug range?
- 1st-2nd vehicle dies issue?
- TSP 1 7/8 Headers with Pacesetter Y Pipe, Might it Work?
- 243 header bolt size?
- How to Make Stock Temp Gauge Accurate??
- 160 Tstat??? YES or NO??
- EGR/AIR Removal
- 1 wire vs 2 wire oil pressure sending unit
- Budget 6.0 build
- OBX headers to TSP 1 7/8 headers.
- best h/c/i setup
- Ported TB worth the $?
- Head valves
- Deleting ac, need help.
- New TB Issues..
- JEGS W89711 Pulley Removal/Install Tool?
- Is this a vette style WP (pic)
- Anyone have a powerstick muffler w/ cats soundclip? I did search.
- Edelbrock 90mm TB worth the savings??
- LS6 Slp intake.
- need help with picking aye muffler???
- Floor heatshield after long tube header install??
- harmonic balancer won't come off ???
- fuel rail leak
- What size belt for powerbond 10% under drive balancer??
- x-pipe duals muffler choice
- Connecting DBW to LQ4
- My LQ9
- LS6 to F.A.S.T. 92
- A/C problem
- Good Deal?
- Doug's headers electric cut out...
- Squeeling Noise
- Questions about lq4 with 241 heads..
- What air boxes fit SS hood?
- what throttle body for ls6
- Magnaflow Cat Worth More Money?
- underdrive crank pulley ???
- TBSS Intake on LQ4 fuel rail question
- A/C compressor rebuild kit?
- Cooling Issues
- fuel rail plumbing advice
- Have your Throttle Body ported by Peak Speed Shop!
- Ported TB
- 4" over the axle pipe
- Intake manifold nightmare
- How much do y'all think this will run me
- L33 ECM help
- Do I need a tune?
- Exhaust Setup/ CME / QTPs what a Steal!!!
- e85=Cornmaro or not to e85=Camaro
- Magnaflow replacement for SLP dual dual
- wiring harness question please help
- Air intake? Car runs horrible?
- Intake swap
- LQ9 Water Pump Gaskets
- How can I quiet my exhaust?
- electric water pump pcm control?
- throttle body won't open all the way
- What do you guys think?
- 2001 truck harness on ls1?
- Is my exhaust setup restrictive?
- Moroso Air Oil Separator
- Question about small flange on side of header tube
- air & egr delete questions
- starter problem
- Need Help Deciding How To Upgrade My Exhaust To Support My 408
- need help with exaust 2000 ta
- FAST LSXR 102 - lower oring ls1 style injector
- Tpis 90mm throttle body
- Transmission to engine size?
- Low iac counts
- MSD Wires
- How Long Did Your Cutout Motor Last?
- What will I noticed upgrading motor mounts?
- Corsa Tips
- my magnaflow only flows thru one side
- exhaust tips?
- Slp CME question
- injectors
- Any1 here running a cam only LS6?
- Help fast!!! Car missing In rain!!
- Meziere water pump accessories help needed..help please.
- What TB for FAST 92
- Ebay Stainless True Duals vs TSP True Duals
- Getting air out of cooling system???
- pacesetter ory VS tsp ory
- LS3 water pump on LS1 with F-body FEAD?
- Need 35# injectors
- IAC Prices???
- anyone ever use this throttle cable bracket?
- need intake solution for SD tune
- TSP bullet length
- MAF Delete pipe
- i shit you not:
- Cat shaped resonators
- Spark Plug wire observation
- Best high tuck/clearance offroad y-pipe? f-body
- 02 LS1 with EGR Plug....
- Need some advice
- Holley hi ram throttle cable bracket???
- 3-pin or 5-pin MAF
- 5.3l worth it???
- 5.3 head gasket ???
- ARP crank bolt stripped/damaged threads
- Deleting PVC
- Problem with water pump?? help
- Stock fuel pump issues...
- want to quiet down my trumpet of an exhaust
- cam degreeing help
- Engine will crank but not fire
- Replacement Alternator question
- What is my next mod?
- Going from Thunderbolt to LG Motorsports an upgrade?
- Cruise Control Failure
- changed oil pressure sender...now way high oil pressure reading on guage
- Budget Budget Budget..
- Is an aftermarket oil pan really worth it?
- TSP 1 7/8 stanless steel install
- borla plates
- Stock Injectors ?
- What vendor has nick williams 92mm in stock?
- 243 heads
- installed the chris1313 now i have a ?
- Electric Water Pump ??
