View Full Version : Generation III External Engine
- Does it matter what coil goes on what cylinder?
- exhaust swop
- Check out my Motor Plate
- Should I consider a new MAF?
- Help Borla & Hooker ORY
- Is this all the bolt-ons?
- Fuel line disconnect, what is the trick?
- Which pulley set is best?
- LT headers, which is best?
- Hooker Y-pipe question?
- Dirty MAF!!
- Carbon Blaster
- O2 Simulators - help
- where to drill throttle body/blade or idle hole?
- Tried to start car today after coil relocation, loud popping noises!!
- Is the coolant line from the radiator to the TB line really needed?
- Tips or instructions for replacing driver's side motor mount?
- Big Thanks From Kook's
- Which plug wires to get?
- What mods are actually worth doing?
- What mods can i do?
- Banks Cat Back ?
- exhaust movie clip....
- Cleaning MAF
- Are Vette pullies the same depth as F-body?
- Installing hooker cat back
- Installing Magnaflow cat back
- oil pressure sensor socket size?
- Lt1 intake manifolds
- MAC headers w/RT cats q and opinions...
- my palms are sweaty, knees are weak, arms are heavy
- Problem with Idle after Converter install.
- need some pics guys...
- Swaybar rubbing bottom of alum. A/C hose
- Do most see gains with 85MM MAF?
- What size torx for rear belt assemblies?
- ZO6 85mm MAF or SLP 85mm MAF .. which to buy?
- Vigilante 3600
- stock y-pipe vs. aftermarket y-pipe
- Optima Battery: Which model?
- Any word on the JPR EWP or the new Meziere unit?
- ds loop and true duals?
- Cats and AIR system
- dyno numbers
- merge collector to use with dynatechs?
- FLP's worth the money?
- Pace 85mm MAF!?
- How come I never hear about Dynomax catbacks?
- Just fired car up with homemade 3" Y into single 3.5"
- Air Intake Upgrade Suggestions
- Muffler vs Catback
- HELP, y-pipe is knocking
- LT Headers, LS6 intake, and MTI tuning = 15hp??
- too funny
- LT vs. Midlengths
- New Grille!! How Much Where do i get it from?
- ASP Pulley
- FLP LT headers
- Do I have an intake or an exhaust leak???
- How Much Damage Am I Causing??
- QTP headers Should I order emissions or race style?
- List of 3.5 oval mufflers? (my new true duals)
- Throttlebody Question.....
- A4 - QTEC users I have a ?
- Anyone dyno before and after true duals? Thinking...
- Optispark Options???
- True duals on a F-Body
- 02 Z06?!?!
- True Dual Exhaust
- HELP! How to change fan settings to 180.
- GMAF?
- High Compression, N/A, and Plugs
- Miami Motorsports Ls6 intake question
- LS1 Pulley
- Fernco Mod
- Intake Lid
- SLP Dual Dual
- Location of driver side valve cover breather?
- ? About the two black hoses on the back of intake?
- SLP LONG TUBES??????
- What size of locking header bolts??
- HOOKER FULL SYSTEM DYNO
- Hoods?
- Exhaust
- Exhaust
- Exhaust
- smokes after header install why?
- QTEC - Fittings?
- Hooker LT in Cali
- removeing a.i.r.
- Severe exhaust leak side effects?
- Aftermkt. Y & gutted cats vs.Aftermkt. Y & OR pipes
- HELP, car is dieing went I am driveing and let off the gas
- 2.5" ORY mac into 3" loudmouth?
- Electric water pump swaping?
- Header bolts
- QTEC installed !!
- Dynatech??
- OEM Water pump question
- Intake Manifold question....
- Ditch my LM now or wait for True-Duals?
- rebuilt electronic throttlebody
- Oil Can for PCV system
- Header clearance due to springs
- Installed New Muffs on the True Duals!
- where to get headers coated?
- aftermarket radiator?
- I beat it!!!
- What can you use to clean a MAF?
- Torque value for ARP harmonic balancer bolt??
- SLP Longtubes- going from Z28 to my SS
- Kook's Custom Headers checking in
- Anybody Make High Performance Serpentine Belts
- is anyone's hooker cat-back on backorder?
- is anyones hooker cat back on backorder
- Are stock exhaust manifolds swappable between all years or no?
- Yet another question about the Loudmouth.
- headers installed today
- Spark Plug Reccomendation
- ATTN LG
- How much hp from LM on a Z28
- SES light on after o2 simm install...
- LT's ORY and Borla
- 1 3/4" or 1 7/8" headers..what do i order????
- Hooker cat back system part number
- will a bigger alternator take away HP?
- Just curious
- Short alternator belt P#. Can someone help???
- Can I get oil pressure on back of block,behind intake?
- TTS or FLP or QTP..?
- traction control???
- Virginia Law and Exhaust
- headers w/KBDD's
- Low coolant light will not leave...
- Pics and Pricing for TSP 85mm Induction Lids!
- Weird idle problem with ported TB
- What is the size and pitch of the battery terminal bolts?
- QTEC cut-out
- Getting FLP's, got a ??
- Has anyone heard about the new intake manifolds from Vararam and Cartek? +50HP ???
- New Bolt On Dyno #'s
- After Market Exhaust?
- temp guage goes on then off...
- ASP pulley set @ LG
- Texas Speed Website?
- Combo of new modifications
- Should I replace the used intake Gasketts?
- Alternator question
- Where are the Texas-Speed Lids?
- 427 HP with a stock tail and muffler.....
- SUPER SUCKER INSTALLED. GOT A QUES?
- Coils bolt on to the motor two ways, which one is front coil??
- Thermostats?
- YOU mod my car... Cam, exhaust, others come on in!
- Straight hooker headers baby!!
- Very loud exhaust! (paging Bad Habit Bird)
- Rusting probs with Hooker LTs?
- EFILIVE OR AUTOTAP ?
- MAF---TB don't align???
- K&N FIPK - MAF to TB hose - how to get?
- 12 or 16 in. bullets?
- i know but i have a quick lt1 header install question.
- Max. Pressure and Volume for 98 Vette Fuel Rail???
- New ASP Pulleys are SFI Approved.
- Options for EGR on the LS6 intake...
- Difference between Weiand/LPE and Holley Intake?
- Does this sound like a bad thermostat?
- True duels pics?
- what should i expect to run in the 1/4 mile???
- New Dyno Numbers
- Yet Another Cut-Out Question....
- Just had ASP Crank pulley installed....
- Installed my Hooker LT's.
- ram air box
- Opening up the stock air box bottom Q's...
- Anybody have pics of Kooks headers????
- More ?'s from a kid.....
- MAC header question...
- Convertible NEEDED! Free Parts :)
- Cut-out or No Cut-out
- What should I dyno?
- what should i dyno
- Headers vs. Converter
- The ultimate TB bypass mod???
- engine builders.....
- need some numbers
- Should I replace the crank shaft seal??
- running rich
- NEED HELP!!!!!!!!!
- Anyone get their new QTPs yet?
- Anyone ever ran their car w/o the Coolant Resv.?
- cold air kits
- good parts web sites, help!!!
- Ported TB
- Need a quiet muffler!
- Timing Tuner and other such products. Are they reliable??
- Full exhaust what gains can be expected
- Magnaflow catback install HELP!!
- Granatelli vs. SLP MAF
- Peice of Plastic/Sensor behind intake manifold broke!
- 2000 Z28 Dyno Numbers Within
- hooker muffler?
- Need to upgrade my fuel system, please help me..
- Holley Power Shot vs. K&N
- Holley or LS6 intake?
- ls6 intake stock on 02 T/A???
- Going back in with my intake
- Intake Question
- best headers- power vs $$$
- Dynomouth w/o cats?
- Dollar per Horsepower : what's a good ratio?
- Voltage dropping below 13...Altenator Trouble??
- grotyohann headers
- Cheapest place to by LS6 intake w/ EGR
- Will my MAFT cancel out my aftermarket maf?
- Which Converter???
- spark plugs
- cold air kits
- catback system
- How Do I Perform a Crankshaft Sensor Relearn Procedure?
- 85mm MAF cable
- PLEASE HELP ME, VOTE FOR MY EXHAUST SETUP
- 1.8 seconds
- Driver side MAC header install HELP!!!!
- Diablo Predator
- loudmouth
- Where can I find the bolt on list?
- slp CAI upgrade kit
- where can I hook up a mechanical oil pressure guage?
- cutouts
- Build up and oil on spark plugs
- WANT TO HEAR SOME DYNO #"S???
- PROBLEM.... NEED YOUR HELP...
- which intake
- Throttle Body Vacuum Hoses
- Dyno #'s high
- question on cats(help)
- Exhaust manifold gaskets at cats.
- Headers??
- What size is the hole in a stock throttle blade?
- Dyno results. 2000 WS6 M6 w/Macs
- Borla - ls1 to lt1
- volt gauge bouncing all over WTF???
- DYNO #'S IN!!!
- Will 28 lb injectors support a H/C 420 rwhp car?
- Diagnosing a bad coilpack...
- Do air lids and better MAF's require tuning?
