- Why don't people do this to their cars?
- Difference between coated and uncoated??
- Hooker vrs Flowmaster
- New belt system layout - plz read
- FAST Throttle body??
- Best headers for lowered car?
- LS6 Vette Intake into F body Pic walkthru
- JBA shorties-RPM range comparision
- Does the Belt Brand Matter?
- Charging Issues/Need Advice!!!
- can you figure this out? all help is appreciated
- QTP catted Y pipe fit Jet Hot LTs?
- Ported TB Questions.
- Prothane Motor Mounts?
- what size band clamps
- The Soda Can Test??
- Custom catted Y pipe help?
- Quick question on headers 98-99/ on '00
- Crank bolt size???
- Complete HVAC Removal Instructions
- Loud mouth and long tube
- Best Place to get Stock MAF?
- Thermostat "correcting"
- TSP Rumbler Exhaust thoughts after installation
- Cheapest Underdrive Pulleys?
- Do MAF ends help on a H/C car?
- Loudest Exhaust?
- going to buy underdrive pulley.which one?
- Changing a/c and serpentine belt... have a few Q's
- Egr Help
- Can I Relocate My Alternator Like The Ls6?
- Exhaust Options on my 422
- will jethot catted y pipe make car sound stock with cats on?
- Jantzer t/b
- Need information for EGR
- Anybody else think the Jet Hot Catted Y pipe is raspy?
- Will Jet Hot L/T's fit an A4 car?
- What Happened
- Belt Sizes For ATI Superdampner
- Over heating question??
- How to determine a bad spark plug?
- A.I.R. Pipe Restrictor Mod - Questioned!!
- Exhaust Leak?
- oil pan/covers, dab of sealer required?
- LSX 90mm combo or stick with the LS6?
- So, How much is too much exhaust flow?
- HELP!!!!! pass. side valve cover pcv diverters
- u/d pulleys, bolt ons and n2o
- Can anyone confirm this is an LS6 Intake Manifold? dial up beware!
- What is the difference in 99-02 TB?
- Hilborn-style stack injection
- True Duals w/stock manifolds, worth it???
- Grott Headers
- screw in bellow
- Porting own TB
- Exhaust Problems
- SES Light After Header Installation
- Does the AIR pump/system work ALL the time?
- MSD wires?
- Anyone use Corsa?
- FLOWTECH HEADER install review.
- will o2 extensions that work with 96 lt1 work on my 00 trans am?
- Header gasket leak
- not sure where to post this but please look and help if u can
- LS1 oil pan differences and removal/install HELP!
- one cutout or 2? are removable cats easily removable?
- Safe to run w/o A/C Belt?
- should i use the header bolts that came with the jethot longtubes?
- ses light re: tps
- Materials and tools for header install
- headers ans stuff
- post pics of your FIPK, and a question
- What's up with the FAST intakes?
- anyone make a 3in stainless bullet muffler with a 4 in outer diameter?
- AC Clutch Removal
- What can I use to plug up my restrictor plates?
- problems after relocating battery to trunk....
- Y-pipe question
- which type of exhaust for my car
- True Duals under the axle, need some help
- Anybody know or have tapped the crank threads?
- EGR and AIR fittings on headers??
- Mufflex with Magnaflow muffler???
- Another Header Question
- !AIR burn up cats?
- My new exhaust
- My temperature is the same!!!?!?!?!
- Pacesetter Lt guys help
- Figured out my problem
- Why would this lean it out?
- how much more power
- Built true duals OMG!!!
- Exhaust question
- Daily drivers with headers come inside please
- How to do your own EGR provision on a LS6 manifold?
- really necessary to loc-tite the intake bolts?
- Please Read--i Need Advise
- New Headers!!
- cutout question?
- Either my Air fuel gauges are broken or....
- Pics of duals with mufflers, not bullets
- Can anyone recommend 3" Bullet Mufflers
- Came real close to screwing my car up...
- New MAF for an a4
- LSX and N2O
- Flow through Cats: Are they worth it
- Had to remove my LSX, and reinstall my LS6
- Hooker Headers??help??
- trans am true duals?
- Just installed Loudmouth....
- Help
- Mounting of AMW catch can...
- O2 sims. Do i need them?
- After Header Install Questions
- Carsound cats in Jet Hot catted Y pipe?
- true dual side exhaust
- Exhaust is a little to loud. Any ideas?
- Quick help needed, oem exhaust removal.
- True Duals...
- 2001+ cooling lines, with LS1 intake?
- LS1/LS6/LSX/Truck/Weiand Comparison
- Where does the purple wire go?
- Where to buy car sound cats?
- I can't stand the fowmaster A/T anymore!
- Which Y-Pipe? For LTs.......
- Jet Hot Y SUCKS!!
- Is a stock WS6 cat-back exhaust worth anything?
- just pull apart the spark plug wire apart, help!!!!!!!!!!!!!
- LS6 install and now a hissing noise?
- Cats or no cats? Need help
- New Throttle Body Install Problem
- Gonna order Oil Pressure, Water Temp and Fuel Pressure gauges, what else...
- Pics of exhaust???
- Selling borlas, what next??
- *Getting rid of plastic sheild*
- How much to install LT's
- Rough Idle & Poppin
- Has anyone ever broken a cat in less than 1000 miles??
- Question about !AIR...
- Flowtech Headers/Magnaflow LOUD!!!
- What do you think of this setup? (true dual pic)
- Installed Flowmaster 40 on stock location...
- Y pipe hitting floorboard
- flowtech how good???
- Flowmaster Crossflow muffler: Is it really that bad?
- Creaking Noise Coming From Steering
- Where can I buy aftermarket Tall LS1/6 vavle cover
- thermostat
- spark plugs??
- Header Experts,help!
- Can PCV issues lead to low oil pressure?
- LSX Intake.. got a question...
- kooks install done.
- HELP! Please
- How to get the crank pulley off?
- What's a good radiator cleanser?
- Just got the march pully ,,got couple Qs
- Pulled spark plugs out to inspect, I have some questions.
- Exhaust port diameter size
- Street Pro Electric Cutout 30 Sale !!!
- LS6 intake slightly rocks corner to corner, why?
- !AIR! Leave it or Take it off?
- Couple of questions about ASP pulley install.
- Any negative effects/harm/drawbacks running open headers?
- Newbie question about !AIR (please help)...
- Y-Pipe goes Bump Bump Help ??
- Vibration/rattle when accelerating?
- PCV Problem??
- True duals under axle, bending towards wheels
- Replacing band clamps with C-clamps to eliminate an exhaust leak?
- How to determine an exhaust leak?? Please help...
- how to disassemble the throttle body?
- exhaust question - frankenstein's camaro
- Where to buy coolant line and plugs for LSX???
- Anyone own or ever hear Dynomax Ultra Flow catbacks???
- True Duals: Everything is here!!!
- Mac Headers...... here we go again
- 78mm Fast Intake and TB installed
- Which front dampner for racing only??
- LPE intake
- Duals with Sweet Thunder Chambered mufflers
- I want to coat my exhaust with something... but what?
- ls6 intake install question
- Catting a Y Pipe!
- y pipe question
- LT, ORY, + GMMG inside please
- Kooks install=cake walk
- How much power will I lose?
- dex cool, where to buy
- Can I port my tb?
- MTI has MAF to TB Smooth Couplers in stock and ready to ship!
- Anyone ever fab up their own true duals?
- NGK vs Denso
- When running duals what lenght bullets do you usually go with?
- codes after header install.........
- Who has done the LS6 intake swap on a stock cube LS1?
- Jet Hot Install Started
- Air check valve mod really eliminate valve flutter?
- Anyone Ever Cleaned Out The Cats?
- What size tap for header bolt hole??
- Intake question..
- Which gasket for headers?
- LS6 Intake Ques. - very simple
- Oil Consumption Issues
- Where To Route Hose For TB By-Pass?
- Trim Smooth Bellow??? Bigger Clamp??
- shaner throttle body...
- Borla Mouth
- 2 quick ??'s on QTEC and cutout install,
- Tbyrne Induction
- Leaky oil access cover
- will ls1 coils work on a 01 5.3 vortec?
- With all the Throttle Bodies on the market, which is best?
- Kooks installation questions.
- LS1 Timing Tuner Wiring diagram or owners manual
- Should i be concerned???
- Is MAC w/ cats louder than LTs?
- Where can I get 3" to 3" header collector ball flanges?
- What happens if you change coolant with out flushing
- Kooks, Hooker, PPC Y-Pipes
- Kooks headers:How many o2 extensions?
- Low Coolant Sensor keeps blowing off the Radiator
- Who's Running Hedman Hedders?
- Problems after ls6 IM install?????
- HELP with longtube install!!!
- What do with EGR and AIR on header install
- New Pacesetter design is better!
- Will 01-02 Jet Hots fit 2000 TA
- fan switch
- Air check valve question...
- Would a Ported TB work well with my mods and which one to buy?
- 420HP+ guys with true duals in here please!
- 420HP+ guys with Y pipe exhaust in here please!
- Driver side windsheild wiper stoped working?
- does anyone make a screw in type plug for the rear o2 bungs?
- if you get rear o2s deleted can you still screw the 02 sensor in the cat area to pass
- Jet Hot Header Deal/Questions
- ASP pulley bolt size for puller...
- Plug Wire Question
- How Much Gain
- Couple of problems!
- car running like shit...a/c issues
- Open cutout or not?
- Any body got a tornado on there car?
- WTF?? New Pacesetter Y same diameter as I pipe???
- how much hp!
- Exhaust Tones
- Converting from 98 to 99 heads, coils and brackets?
- Those with Lanes True Duals come in
- Can i run only ONE CAT ???
