View Full Version : Generation III External Engine
- ls6 coolant pipe o-rings
- I just bought an EWP!
- *Video clip* My T/A w/ Kooks LT Headers & GMMG catback
- F***ing Lid
- What else I need.
- Is it common after ls6 intake install............
- Borla
- PP intake and TB
- what size belt do i need
- LTs Question
- Catch Cans
- Catch can Question
- need info...
- Ceramic Coated Pacesetter
- whats the loudest muffler for TSP TD's?
- shave TB screws or leave them?
- Header Gaskets which way do they go on?
- LS2 intake swap
- where to put cutout
- TR55's pregapped?
- Question on Painting Exhaust
- Free EGR mod
- intake elbows
- LS6 Intake installed
- amw pcv routing?
- any way to keep tips with duals?
- Who broke their oil pressure sending unit?
- Please Help Asap!!!! Central Illinois
- will 98 Headers fit my 2002?
- anyone ever get dtc after ls6 intake swap?
- She bangs! She bangs!
- Buying some Pacesetter Headers, here’s my checklist so far, anything else?
- WB02 where to connect wires???
- Not a newbie, but I do have an exhaust question
- What determines the powerband of an engine via intake manifold design
- problems after intake swap
- i need all aftermarket guages, how do i do this?
- Time for a new exhaust. What to buy?
- Header question
- ORY to stock manifolds
- moutning wideband
- Found the best sounding exhaust
- 98 knock sensor question
- ASP or March U/D Pulley?
- Best Clearance Y pipe...PaceSetter?
- Erratic idle (mostly with A/C off) after TB install?!?!?!
- catback exhaust leak
- Estimated HP with these mods
- FAST gasket install ?
- Bump stop mod help
- PCM cover removal (2nd topic post)
- Muffler Ideas
- LT header newb question.
- noobie here...will I hate my LM2?
- best intake for 427
- Just got it iN!
- Should NGK plugs work ok with Autolite plug wires??
- QTP header installation
- Who's successfully quieted down exhaust volume INSIDE the cabin?
- Ignition Problem – Intermittent Ignition/Start
- Low idle after LT/ORY install.
- idling high, not sure if right forum
- will LS6 exhaust manifolds fiit a F body
- mounting coil packs
- I Wanna Be A Little Louder......
- Kooks Y-Pipe Hitting The Car
- L92/L76 or PRC 5.3/FAST 90 on 408?
- coil pack mounting
- Anyone running Kooks LT's with TSP TD's
- LS1 to FAST 90 and coolant lines!! help
- Moroso Spiral flows look like they flow like crap?
- LS6/Ported TB VS. FAST 78MM LSX
- rattle from exhaust?
- Self-Tune after Header install
- 2.02 or 2.05 valves?
- Production #
- New Magnaflow Quad tips on a Camaro....thoughts?
- Need Help!! Power Trouble
- Will an LS6 intake work off a.....?????
- Still a little jumpy.
- my magnaflow catback or tsp sweet thunders
- oval muffler
- power wire
- Opinions on Magnaflow mufflers on duals?
- Need muffler help real quick
- Reuse stock cats?
- water pump
- header question
- Mac Headers?
- Let's Hear Your Opinions on These 3 Cat-Backs.
- Fast/nw 90/90
- edlebrock LTs and ory w/ dual cutouts
- Throtle Body Questions
- ls2 intake
- Piston Slap?
- LS1 clamshell mount applicability
- LS6 Heads
- Quick cutout ? HELP
- Buying Headers.
- coil spark
- Camaro People Who Has A ........
- Race headers?
- First dyno run
- help on intake install!!! ASAP
- 100k ?
- MAF sensor
- For those who think Magnaflow isn't loud...
- Quench formula?
- Will the Pacesetter Y-Pipe fit Jet Hot LT's?
- what thermastat is everyone running
- magnaflow or true duals
- Throttle body isssue
- Intake
- What Do U need for Header install (Pacesetter)
- Open headers car runs like crap
- cool heads..
- New exhaust, shaking?
- Power Steering
- Which plugs/wires
- Flowmasters
- Tucking up GMMG tips
- new Ls1 ignition coil wire harness
- F.A.S.T 90mm intake porting?
- Going the LS6. what do i need to know?
- semi-unique exhaust thread
- Relocation ignition coil kit
- Corsa clones how long are they?
- *Pic's of my new used exhaust*
- Cut Outs
- Valve Train Replacement
- Clearance
- Here's the COOLANT article from Master Technician magazine
- muffler hanger missing catback installation
- Bought A Ws6 Hood
- Jet Hot LT's
- Turndowns?
- Installed ls6 intake 2 days ago
- Whats wrong? Help.
- TPS sensor O-ring gasket?
- Quick ?
- Gravy Pacesetter install tonight
- Mass Air Question.
- where to buy a Moroso Spiral Flow?
- whats the difference???
- Help me please
- Getting ready to delete the AIR on my 02. Anything else?
- changing pulleys
- new exhaust
- which Y pipe w/ pacesetter LT's
- O2 Question
- Stainlesworks Chambered catback
- TSP True Duals questions inside
- TPS Y-pipe Question (Cut Out)???help
- long tube header clearance
- Cat Back Exhaust flow limitations
- Ls6 Intake INSTALL
- LS1 Intake to FAST 90!
- Good o/r y that bolts to stock manifolds
- intake manifold bolts(ls6)
- Pacesetter LT's, TPS ORY and Cut outs NEED HELP FAST!!!
- 1 Chamber question
- ls1 240 exhaust q's?
- True "Duels"
- WTF Autozone? The two Bosch 13111's aren't the same at all.
- jet hot y pipe is kicking my ass
- 02 ss w/ls6 intake factory???
- qtp headers and tsp true duals?
- homade cam tool
- Meziere water pump running hot!
- Cat's Clogged - Best Option?
- Which Y pipe with QTP and SLP D/D
- Negative battery cable
- Price of Over or Under TD
- MAC MID Hardware
- ls6 part numbers
- seem to recall a thread where there was list of all screw sizes/bolts etc...
- what to do next
- Mamo ported 90, extremely impressed
- Pacesetter LTs & TSP Ory installed
- Coil Relocation Packages
- ls6 part numbers
- Catted Y-pipe
- Header install - Some not documented useful tips!
- compare the dynamax bullets to others
- Victor intake ?
- Odometer's frozen/speedo doesn't work
- How in the hell do I remove a crank bolt from a longblock that's pulled??????? ARGHHH
- more exhaust questions
- QTP electric cutout controller.....
- LS! Question
- new true duals
- cut out
- Intake Question
- Meziere water pump, thermostat?
- Linelock back to stock
- Headers Headers Headers!
- true duels or slp LM
- Few Questions need answered Please!!!
- Pacesetter
- A/C Help
- air pump removal???
- edelbrock performer manifold for ls1
- SLP Pulley Removal
- NW 90MM Throttle body and IAC
- removing valve springs
- 6.0 injector size??
- which is quieter. bulllet or spiral flow
- inside belt
- long tubes & ory installed, now exhaust pops
- How to take a TB apart?
- Need help asap w/ PTB!!!
- TSP True duals, Break them down for me.
- Thought I might.........
- Which aftermarket harmonic balancer, underdrive pulley, and dampener?
- slp dual dual muffler question???
- bypass mode
- How do i get to the air pump to remove?
- O2 sensors not fitting into Pacesetter Lt's??
- Getting exhaust put on on Monday, need this question answered pretty quick...
- Pic of LT1 vs LS1 radiator core
- New Muffler?
- Muffler?
- alternative to expensive qtp cutout controller
- sponsors selling corsa catbacks
- Headers Leak - New header bolts put in?
- HELP! Broke a header bolt off!
- Fast Toys Ram Air???
- Catch can help please.
- Tap end of stock fuel rail for NPT fitting?
- Which True Dual Muffler is Quieter
- BBK VS. Fast 90/90 setup
- QTP headers/Kooks y-pipe/Spohn solid motor mounts
- Cherry bombs (yes im serious)
- LS6 swap questions
- Hooker Catback?
- let try again with a pic - what is this?
- Those with banging Ypipes...
- bely routing
- Clearance pics of TSP Duals w/Sweet Thunders
- breather filters
- LS 2 intake
- truck coils
- 2002 trans am ws6 M6
- Pacesetter y pipe or TSP ory pipe??
- stock y-pipe
- running without cats smell?
- header fitment ls1-ls6
- where to buy tb blade?
- quieter exhaust?
