View Full Version : Generation III External Engine
- I-Pipe Cost
- anyone running spohn torque arm with the ts@p dual x pipe
- TR55 gap
- got headers in!
- Fan question/Oil pressure issue update
- Alternator problems
- Headers and Exhaust Question
- Can I run one cat?
- Mac Collector Mod
- Looks like rust inside my coil pack and wire
- slp loudmouth w/ gmmg muffler
- To get rid of PCV do I just need some breathers?
- Ever wanted to see a Pi-thon FireLock?
- which setup should i go with?
- charging system problems
- PCV direction
- 02 sensor and 02sim mix up
- intake parts from 4.8 to LS1 intake
- Pacesetter's Ordered!
- quick favor
- Best size cat for custom Y?
- Fitment problems and backpressure question, cutout, need some quick help
- help! where do these lines run to???
- Pacesetter LT's w/ Mac Y/ORP
- Which operating temperature with 180F thermo?
- LS6/90 LSX WOT MAP Comparrison & Install Info
- Headers question for camaro
- Will LT1 catback fit on an LS1
- Just got the qtps installed
- Jet Hots & single chamber flows
- Crap under intake
- wanna change my FLOWMASTERS but to what?
- mac header and ory pipe install?
- FAST TB - Any1 Else having problems
- Need Exhaust Advice...
- Another Pulley Question
- Pulleys
- Where to buy GM Melco Truck Coils online?
- Headers and Y-Pipe
- ? about powersteering pump removal
- What should I gap my TR55's @ for H/C Car?
- Need some direction on where to start
- Pulleys
- Header question
- Header Question
- Whisper Lid?
- 85mm MAF- Worth it? Cam only.
- What kind of C5 exhaust for my 408ci?
- OMG!!! Edelbrock Victors w/ y-pipe and Hooker catback = AWESOME!!!
- headers
- Exhaust scraping
- McCord Cutout Website?
- what do i torque the header bolts to?
- Have any vendors thought about making an adapter plate for the FAST 90MM?
- Header question
- LS6 Intake Manifold SOTP gain?
- Help!!! Car will not start.
- LS6 Intake Install Cost:
- Coil Relocation Brackets
- Ls6 intake part number
- flow tech y pipe
- victor drag header pic
- Will my intake leak if its missing 1 bolt?
- Denso Iridium plugs...
- lost track time with ls6 intake manifold and 160 t stat ?
- Need Y pipe for Jet Hot LTs
- Help,02 sensor circuit high volts?
- moroso spiral flow or dynomax bullets??
- need 90mm intake gasket asap
- Different Intake designs
- Where can I find the Torc Tite exhaust clamp.
- Need help, picking a muffler!
- how many CFM's do i need for fan so engine stays cool
- Has anyone accualy done a side by side???????????
- Header problem
- add cats to ory & magnaflow, or keep ory and get hooker cb
- How did this guy mount his coil packs like this??
- Advice On Cutouts
- 78mm or 90mm LSX intake for stock 346 engine?
- Headers installed... but
- weird noise on decel and gear changes
- When did they start making sfi approved asp?
- How do these match up?
- Motor mount tabs, up or down???
- Fast 90mm intake sealing problems?
- TSP's X-pipe kit
- SES and Header install. Do they go hand in hand?
- Quick Poll. JBA or Kooks LT's
- single inlet/outlet 3" muffler?
- Engine oil cooler kits for LS1/LS6 from LPE.
- Hypertech Powerstats
- Cut-out on Magnaflow gains?
- still need a muffler for the TD setup
- Finally got my intake totally done, but...
- Traction Control problem...
- header install, car runs like crap, PLEASE HELP!
- cutout question
- 02 sensor??
- More advice on installing Fast Toys Ram Air Kit...
- Fan On, Engine Off
- QTP catted Y ?
- GM Part # needed
- True dual dumped people inside
- 00' 3.8L V6 Exhaust.. and mods?
- Inake manifold to Throttle Body ???
- MAC Y-pipe fit?
- Header installation what did you
- Weird Car Trouble!!!
- Help with header install!!!!
- Where do I hook the cutout wire up?
- Hand porting a LS1 intake?
- Help, stumbling after spark plug change.
- pros cons of not running cats
- TSP true dual kit?
- How difficult to remove AIR and EGR? Help.
- Effects of cutout?
- Crank pulley is causing my car to throw belts...
- Swapping 99 LS1 Engine in a 98 T/a
- Header Question
- hookers
- !egr???
- Anybody tried Fram Air Hog?
- Is this a LS6 intake??
- OEM SLP options same as you can buy direct?
- Spintech replacement for mufflex 3.5 ?
- ASP pulley question
- Need the smallest cats possible
- Best oxygen sensor
- ASP pully = harmonic damper?
- LS6 Intake Help! (please)
- 2002 Mass Air Sensor part number
- ws9 hood and airboxes
- Not sure if this is right forum. But Cleaning MAF...
- Exhaust Noise?????
- BBK 80mm vs. LSX 78mm TB's...
- NEED intake manifold help! really bad!
- Best way to get to #8 spark plug?
- Cat Back help
- ORY swap questions
- Underdriven Crank pulley- Safe? Worth it?
- gasket maker for !air
- LQ9 coil packs better?
- Question about gauge wiring....
- Edelbrock LT's, someone PLEASE post a pic...
- Clicking noise from compressor
- Finished whole exhuast install
- Thinking of changing to True Duals
- Question about my catalytic converter??
- What do these red plugs on back of LS6 manifold...
- When should you replace stock plugs/wires?
- Smart to change wires after only 3,650 miles?
- Header install any suggestions?
- Thinking about TSP true duals
- Should I change the plug Before/After?
- tr6 plug gap...
- GM header gasket PN#
- Which lakewood DS loop for true duals?
- Help with headers(EGR)
- MTI Lid install, Didnt fit
- Edelbrock Victor install help
- Still not happy!!
- header install help
- Alternator not charging
- installed a Borla XR-1....best mod ever!
- LS1 coil wiring
- Cutout location opinions
- NEED HELD ASAP!!!! (LS6 intake)
- I need an answer
- black ash coming out of my exhaust?
- difference in auto/manual radiators and....
- whats the best header gaskets?
- Anyone running Borla XR-1s with true duals?
- 3" Duals hang too low, what are my options?
- Too loud! Anyone else running somthing similiar...
- Getting fireworks out exhaust after a hard run
- Poly Motor Mount Install
- LS2 intake under $400 bucks!!!
- What are the best Headers for an 00 SS??
- Is this a Crank PS or Oil Level Sending Unit????
- Blown Header Gasket?
- lsx and kooks headrs help pls.
- SLP dual/dual...
- Exhaust runner length?
- NEW (i think) SUPER INTAKE FOR LS1
- Lowered with LTs
- Cheap GMMG?
- Should I Change?
- Street Pro Cut Install
- Quick header help...how do you remove the O2 sensors from the stock y-pipe?
- New LS1 Intake
- what muffs for duals?
- How Much H.p. Does An Exhaust Add??
- Anyone ever tried this.
- no matter what setting air is on, it comes out all vents
- Please review my laundry list
- Wish me luck....header install
- Best spark plugs
- Exhaust question
- March underdrive Crank w/ Alt Overdrive Pulley Combo ??
- My gauges look like the 4th of July when I floor it
- DOES A 2K1 OR 2K2 "WS6" OR "SS" HAVE LS6 INTAKE???
- Why would anyone select less than a 90mm TB for their motor...read this!
- What sensor did I break?
- What to get next -- goal of 400rwhp
- Plug/Wire change
- Best Electric Cutout
- Pacesetters/ TRUE duals
- LS6 intake question
- Wanted, Smooth sounding exhaust
- question about center mount exhaust????
- ASP Pulley?
- Question regarding Kooks Y-pipe
- Edelbrock Victor Headers
- SS/WS6 Exhaust Tips
- Modifying dynomax bullet meffler - more staccato?
- Custom duals with cats - who's done it?
- SLP y-pipe diameter
- hooker or manaflow muffler
- ? About Plug Wire Problem
- Will the TSP duals bolt up to my stock exhaust manifolds?
- headers
- question about borlamouth? dimension for cutting up LM?
- Magnaflow Muffler
- LT + hi flow cats + new y + SLP D/D
- Vacuum pump in stock AC location
- TB Bypass - 1/4" splice ok?
- Loudmouth on a 408, 2 loud?
- power steering jacked up
- Headers and Offroad Y
- Borla
- under drive power steering pulley
- True duals, here I come!
- Over axle heat shield+ silicone=?
- car go boom!
- My QTP header/y-pipe experience..
- Please Help Me Out
- Catch can bracket
- header install ???
- Got My LS6 Intake On...
- Pacesetter Headers Worth $399.99 Or Not???
- 75mm or 85 mm zo6 maf
- Longtube headers on lowered car
- gaskets
- i need a good muffler
- LS1 intake to either LS6 or FAST 78. Can someone make up my mind for me ?
- asp pulley spun on crank
- What do you guys think about true duals turned into side pipes?
- True dual battel with buddy's
- What LTs with GMMG ?
