PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 [201] 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Gonna get a magnaflow cat-back Unless...
  2. dynatech headers
  3. Worst nightmare come true - Pacesetter LTs
  4. Price: ORY & Magnaflow vs. Custom True Duals?
  5. What do you think the Horsepower will be after these couple things?
  6. Which exhaust setup to go with Longtubes
  7. a/c question
  8. O2 sensor help por favor
  9. Power steering pump problems
  10. Anyone running Edelbrock SDT Mufflers?
  11. extending 02 sensor
  12. VERY poor dyno run
  13. center mount exhaust
  14. Opinions Needed...Loudmouth & Headers
  15. Opinions Needed. Headers & Loudmouth
  16. QTP LT's TSP TD's W/ST's Video!
  17. Vacuum leak - what is this?
  18. How hard install?
  19. Pacesetter ORY to LM fitment issues...
  20. True dual hanger question...
  21. Fuel pump ?
  22. Pics of painted headers???
  23. throttle body port gone wrong!!
  24. Re-wiring on new motor, where does this wire attach to?
  25. harmonic Balancer making noise
  26. Help with engine light
  27. ok to drive without power steering pump?
  28. stock catback and pacesetter y-pipe?
  29. Crank pulley help ASAP
  30. EGR removal question
  31. Is two better than one? (cutout)
  32. Over axel True Duals..
  33. Oil Catch Can mod?
  34. Ticking sound....
  35. TSP true duals
  36. which size of bullet?
  37. Will any shop tune out AIR and EGR?
  38. 5.3 truck intake work on a ls1 t/a?
  39. Edelbrock Victor Headers and TSP True Duals
  40. P.S. pulley
  41. Anyone have loudmouth II
  42. Introducing Katech's new design billet belt tensioner. Now with pulley, same price!
  43. my magnamouth sound clips
  44. Header install problem
  45. X pipe setup
  46. Powerbond Pulley Questions
  47. Oil temp sending unit
  48. Looking for a Sound Clip of SweetThunder Mufflers on thru an LS1
  49. What Better Flowing Muffler to Replace MagnaFlow CBs Muffler on TA?
  50. Is there any differences between the different years' LS1 throttle bodies?
  51. ls1 to ls6 intake coolant lines and plugs
  52. Mufflex exhaust question.
  53. TSP TDs and cats question
  54. Who sells T/B by pass kit
  55. Dynoed Car Today And Happy Man
  56. factory plug wires
  57. air egr removal?
  58. straight pipe
  59. Magnaflow dealers?
  60. alt pulley?
  61. Getting my exhaust installed tomorrow!!!
  62. No muffler sound clips?
  63. made up my mind: PaceSetters . . . . . . Then what????
  64. Oil Pans
  65. corsa exhaust tips
  66. 02 harness extensions
  67. my manifold is stuck!! need some advice
  68. New Intake Manifold!
  69. Coated headers
  70. I could use some help on my LS6 spark plug wires falling off coil.
  71. best cat? (update on carsounds metalic cat?)
  72. Pacesetter and TSP Catted Y help.
  73. What plug gap for TR6's N\A???
  74. Emission Problems.......
  75. Aftermarket Harmonic Balancer Necessary?
  76. QUESTION! Y-pipe crossmember
  77. anyone pass CA SMOG WITH LT's and CATTED Y?
  78. Belt problem fixed... I hope
  79. Best exhaust for a 99 t/a???
  80. What's involved in changing a thermostat??
  81. chambermouth... lol. sound clips?
  82. Bolts with Headers??
  83. Question about AIR and EGR
  84. air removal on 2001 TA
  85. 12v under hood ignition switched power source
  86. BG Ram Air
  87. Air induction lid question?
  88. damn waterpump gasket is leaking
  89. Leaking exhaust
  90. pacesetter LT's shopping list
  91. exhaust problems
  92. MSD 8.5 wires fitment
  93. Base hood... Ram Air intake?
  94. Kooks stepped LT's vs. Edelbrock stepped LT's ???
  95. Which Hi-Flow Cats?
  96. MSD coil packs. Questions.......
  97. So my kooks 1 7/8 LTs dont fit.... help? pics.
  98. Best place to mount the fan control switch
  99. EGR - AIR - O2 Sensors - Motor/Tranny mount FAQ!
  100. Long Tubes and EGR?
  101. exhaust problem...maybe cats?
  102. LT headers and tuning...
  103. Custom Loudmouth?
  104. 1 3/4 or 1 7/8 for big cubes running a Y pipe with a 3" I
  105. Under the axle?
  106. Cheapest place to order Pacesetter LT's
  107. Diameter of stock I-pipe?
  108. edelbrock carb intake
  109. Belts are about to come off the pulleys!!! HELP
  110. Here comes the noise!
  111. Ordering Pacesetter LT's
  112. Uncatted Car Ticket
  113. TSP Catted Y
  114. I need torque specs for header bolts! asap
  115. Help!!! Header Bolt Fitment Issues
  116. NW and Fast 90mm
  117. which will give best HP gains
  118. how low can you go?
  119. DS loop to fit around a mufflex y pipe
  120. exhaust tips
  121. California Emissions
  122. 4" single tips on a ta, pics please!
  123. Question about NW 90mm TB and cruise control
  124. TSP TD ordered
  125. Does Corvette MAF Sensor Change Produce Noticeable Gains?
  126. Is there a difference between the LS6 intake and the LS7 intake???
  127. o2 extension question!!!
  128. More BGRA questions
  129. QTP Headers Rubbing!
  130. What size is stock I pipe???
  131. ground clearance....
  132. another spark plug question?
  133. water temp gauge
  134. what a/c belt for slp underdrive
  135. Electric Water Pump
  136. Would cut-outs help me at all??
  137. Help decide Which single Chambered muffler to go with!!
  138. Question about QTP headers...
  139. Do headers or shell out $225 for a shop to install em'?
  140. Exhaust/Header Question
  141. Quieted down my bullets!
  142. Where to get EGR and AIR block offs
  143. Any1 else with this problem??
  144. Maybe you LS1 guys can answer this
  145. Cutout vs. True Duals
  146. pacesetter LT's w/ ridetech
  147. headers?
  148. ngks v ac delcos
  149. motor mounts
  150. Max power with cats/duals???
  151. 99 frc ls1 swap to ls6
  152. itake question
  153. tsp ngk's and speed incs ngk's?
  154. Best Ls1 Gto Mods?
  155. How to get intake hissing sound...
  156. Pacsetter ORY or TSP ORY
  157. WTF is that RATTLE!?
  158. How do you pass emissions in CT?
  159. pacesetter 00-02 LT's have egr?
  160. Mr. gasket ???'s
  161. dynomax race magnum
  162. Can someone help.
  163. Air Conditioning
  164. Where can I get parts for my stock TB??
  165. Help a Rookie get more HP on his Vette!
  166. mass air flow
  167. odd noise....
  168. Suncoast Hood Kit Questions
  169. Fast 90/90 & stock exhaust manifold
  170. TB question(easy one)
  171. Bellow size..
  172. is this too large a diameter pipe?
  173. Fast 90/90 question????
  174. Exhaust question???
  175. ups man brings the goods
  176. High compression/horsepower guys (what plugs)
  177. slp CME
  178. Lingenfelter intake...good or not?
  179. Exhaust Question
  180. Pics Of Over Axle Duals
  181. exhaust is on, Magnamouth (56k is no no)
  182. AIR question
  183. ?'s reguarding busted MAP sensor
  184. getting fuel injector blown out
  185. Egr Valve
  186. High compression 11:1 and potential detonation
  187. How Can I Make a New Battery Tray?
  188. Difference between 00 MAF and 01 MAF??
  189. Putting In Qtp Headers Now!! Need Help!!
  190. Pacesetters are on!!!
  191. What did you pay for installs?
  192. intake question help
  193. resetting Hypertech VIN?
  194. how can i check my cats??
  195. Steering column clearance with QTP longtubes
  196. Black box next to power antena motor???
  197. Exhaust sound clip ya'll requested!
  198. One-piece from 85mm lid to NW 90 TB?
  199. MAF ends question
  200. pulley
  201. what else shud I get? help me
  202. Egr Issue !!
  203. need a throttle body.
  204. Any real noticable power difference with headers? Like Pacesetters?
  205. BBK 80mm TB disapointment
  206. QTP or DMH??
  207. Edelbrock LT's
  208. need lid
  209. Need advice on what parts to get next....
  210. Fast90/90 vs LS6/portTB
  211. cut out ?
  212. Help With My Used Headers!!
  213. Question on asp balancer/pulley install!
  214. Sneak peek on new stuff i got one.
  215. Removing valve covers
  216. How much $$$?
  217. TSP TDs sound = Me disappointed
  218. Want to get TSP True Duals but....
  219. Header of gear advice
  220. Headers or gears...
  221. Question for anyone who ran Open Headers and went to True Duals:
  222. Questions about exhaust.
  223. Need some quick advice
  224. nick william o-ring
  225. What order to buy these?
  226. Everything needed for a Fast 90/90NW install
  227. Gauge ?
  228. Specific way to route Kwire under intake?
  229. 2.5 tips
  230. Headers/ORY with stock SS CME exhaust??
  231. Help!!
  232. Lets just call this category Exhaust.
  233. Would a catback of a 97 fit my 98?
  234. Having problems with my NW tb..Please help!
  235. LS6 Intake, ANYONE EVER HAVE THIS>?
  236. well i did the TB
  237. Question
  238. question about bassani true dual
  239. How much horse does GMMG give?
  240. Ram Air/weatherstripping Block Off
  241. LT install/Valve Cover paint job **PICS**(56k HELL)
  242. Connecting headers to 2 1/2" duals...
  243. What size true duals do ya'll have?
  244. Hesitation after header installation
  245. Magnaflow Owners Please Come In
  246. pacesetter/Borla non adj cat-back
  247. ported throttle body...who?
  248. Can I get a part # for LS6 MAF???
  249. deleteing tips diferent muffler??????
  250. Y Pipe with no cats and DTCs
