PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 [209] 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. What I need to complete an LS1 to LS6 intake manifold swap?
  2. offroad headers
  3. Corsa or TSP rumble setup?
  4. Home Made 02 sims?
  5. What's the best puller for LS1 crank pulleys?
  6. Should a New TB Go On w/ an LS6 Intake?
  7. stock or pacesetters
  8. Those with homemade ram Air for Camaros
  9. Gms Maf
  10. Need alittle HELP guys
  11. How many people port stock TBs?
  12. what gears should i go with?
  13. ? about cats and tsp TD's
  14. Ceramic Coated headers?
  15. headers& emissions question
  16. 02 sensors
  17. LS6 intake extras??
  18. porting maf ?
  19. need help with cat placement on hooker ory
  20. Corsa vs. slp
  21. so, what connectors...
  22. y-pipe or true duals w/x-pipe
  23. whats louder
  24. TSP questions
  25. Had my true duals put on today..
  26. throttle body opening mod
  27. what to plug in the lid??
  28. Best deal on Hooker aero chamber muffler 21729HKR
  29. "Stainless Works" F-Body exhaust specials!
  30. good god this rattling is annoying!
  31. Catted Y for pacesetter LT's?
  32. TPS max voltage with throttle stop grind mod
  33. How many inches are my pipings?
  34. Has anyone ever tried a mechanical O2 fix instead of sims?
  35. dual cut-outs with kooks
  36. Where to find Carbon Fiber Mat
  37. Headers
  38. Can i borrow your CARB #?
  39. Other than TR55's
  40. Gutting Cats...?
  41. LT Header Question?
  42. The Rasp Sets In
  43. Holley Aluminum LS1 intake manifold ?!?!
  44. Last header related question, I promise
  45. Better than an X or H pipe?
  46. y-pipe question
  47. hotcam through 3'' cutout
  48. Exhaust sys
  49. Who's Got Air Restrictor Plates??
  50. help with headers
  51. NX 85mm throttle body?
  52. LS6 intake
  53. dynomax bullet vs. moroso spiral flow?
  54. anyone running spintech?
  55. Pacesetters, catted y pipe, LM...coming
  56. good spark plugs?
  57. ws6 lower air box on an SS?
  58. SLP 2OTL Question
  59. Exhaust Leak (Help!)
  60. MAGNAMOUTH in tunel :)
  61. march performance pulleys????
  62. I was searching for corsa tips and came up with this wtf?
  63. a/c compresser 95 lt1 to ls1 98??
  64. LT install prices?
  65. Hooker areo vs magnaflow stock replacement
  66. Need help with exhaust decision....
  67. laugh at me
  68. Motor Mounts causing this?
  69. What ever happend to...
  70. Xcelerator Muffler?
  71. cats, ypipe, catback ?
  72. what size cutout
  73. Exhaust sounds like sheeeetttt!!!
  74. ground clearance, and rattling
  75. o2/headers need help
  76. How long will the cats last if i !air with stock manifolds?
  77. Accubab 75mm throttle body
  78. Header install
  79. spark plug debate
  80. Teach me about spark plugs.
  81. Quick Header Questions:
  82. Vibration after TR55's and Mounts
  83. QTP vs Pacesetter
  84. Jet Hot Long tubes w/cats and Y-pipe????
  85. idler pulley ?
  86. DS coil packs are not firing
  87. Has anyone ever tried running a cutout capped with spacers?
  88. What do you all think?
  89. Trouble with my Corsa muffler...PLZ help.
  90. AIR valve...Oh no!!
  91. operation loudmouth quiet down?
  92. back pressure?
  93. QTP Headders installed... info for others
  94. Need help on stripped valley cover bolts
  95. headers exhaust..SES light?
  96. mulfflex y nightmare.
  97. Borla vs. Corsa
  98. Exhaust Manifolds...
  99. Exhaust Manifolds...
  100. headers
  101. Dialetic grease on sparkplug wires
  102. Hooker Header Install Help Asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  103. corsa waaay too loud....cat/ resonator?
  104. Random Tech's or .......
  105. those with Ebay catch cans...inside?
  106. keep or ditch flowmaster?
  107. what size is the PCV tube that goes into the intake(catch can)
  108. Front 02 sensors same as rear?
  109. y-pipe question
  110. Flowmaster for the C6
  111. Cats, o2 Sims, or o2 delete from PCM
  112. This is how I fixed my Y pipe banging... *pics*
  113. VIDEO! You asked...here it is. Burn em up!
  114. Smooth Bellows
  115. electric waterpumps
  116. pacesetter nightmare!
  117. Header/Ypipe install major problems
  118. Borla non-adjustable cat back...
  119. Under the axle true dual guys, come in
  120. Headers Leak !!
  121. throttle body and intake question
  122. Mufflex Y-Pipe
  123. quiet exhaust, plus cutout.
  124. Possible to repair ls6 composite intakes?
  125. hooker y pipe help
  126. how did you get the silicone gasket out of the fast intake?
  127. Resivour Stud
  128. What do you think of the Magnaflow Y-collector?
  129. slp and pacesetter lt's
  130. Does running an open cutout hurt anything?
  131. Exhaust for my bird?
  132. MTI TB question!
  133. stock unported VS Ported flow (CFM)?
  134. best spot for cutout
  135. bellows
  136. Coolant Temp Sensor Location
  137. Slp Lid...
  138. For The Love Of God!!!!
  139. Headers 02 question
  140. Header bolt size please.
  141. smooth bellows
  142. air box lid o2 sensor wires pulled HELP
  143. electric cutout questions
  144. Does anyone make an exhaust like this? Or has anyone tried it?
  145. No clue how to wire DMH cutout
  146. need ory for slp longtubes
  147. ls6 horse power.is it worth it?
  148. Small fitting on rear of intake
  149. Mufflex bump stop hanger.
  150. Spark Plugs
  151. DIY True Duals
  152. Exhaust clamps
  153. Best Headers for the Buck
  154. "Urgent Part Needed"
  155. Mufflex Y
  156. Spark plug question
  157. MSD wire ?
  158. Where to get a hooker catback
  159. TB question
  160. What ORY to go with HOOKER LT, and BORLA CB?
  161. NE1 Sucessfully Used a FilterMag on T/A's????
  162. header install w/ jack question
  163. are all stock LS1 mass air meters the same
  164. Magnaflow or Corsa?
  165. what size cutout????????????
  166. Just to make sure Im not crazy (CEL light Question)
  167. muflers
  168. So i broke a header bolt.....
  169. Just got a Hooker catback put on my LS1, very quiet! What went wrong?
  170. Problem with under pulley.........
  171. How to remove front bumper
  172. are these cats good..
  173. SLP Dual Dual guys come on in
  174. Truck PCV. is this the one
  175. Oil Pan Gasket
  176. Air lid install help
  177. !AIR! Question How to block vacuum line?
  178. Doing my FAST 90 tomorrow....
  179. Quick ? on LS6 Intake
  180. borla exhaust 3"?
  181. should I get rid of the AIR and EGR?
  182. need some help..
  183. those with custom built y-pipes come in
  184. Pulling out my motor Help!!!
  185. headers and ypipe install
  186. Catback
  187. Spark Plug Wires
  188. What kind of Cats in the TSP cat Y-Pipe?
  189. which oil catch can kit ???
  190. port your throttle body yourself
  191. pacesetter long tubes and ory
  192. BBK intake manifold guys were you at
  193. LS6 dual or single exhaust?
  194. TD newb question
  195. Please help the exhaust dummy (me)
  196. coating on tsp true duals
  197. Loud Mouth 2!!!!
  198. Squeaking Belt? Maybe Idler Pulley?
  199. Which Spark Plugs
  200. Sound clip of my Trex & SLP Dual/Dual
  201. Used SLP LongTubes???
  202. How I MOSTLY fixed my banging Y-Pipe
  203. T-stat Size?
  204. Headers and Ypipe installed but there might be a problem
  205. Need Pics
  206. GMMG Chamber Exhaust
  207. How does Dynomouth+LT+ORY sound
  208. Cut-outs (did you pass inspection)
  209. how much torque do the motor and tranny mounts get?
  210. Thanks QTP and NW!!!!!!!!
  211. chambered exhausts
  212. Lid Question
  213. TSP duals
  214. Stock MAF vs. SLP 85MM
  215. 02-00 intake swap
  216. PICS of completed True Dual (over-axle) exhaust w/ Edelbrock LT's
  217. reuse intake gaskets?
  218. 78mm vs 90 mm intake
  219. Dynatech SuperMaxx System A++++
  220. Should I replace the motor mounts
  221. Cooling Fan question.
  222. few ?'s about the fast 90mm intake
  223. Need some information on what to do for throttle body?
  224. DMH cutout... where to install switch and what's involved?
  225. Finding exhaust leaks
  226. Starter and 11.75 to 1 compression?
  227. Slp Dd
  228. New Lt's + Service Engine Soon light = Bad? Why is my light on?
  229. installing headers very soon....just a few ?'s
  230. Need Information on Edelbrock Headers
  231. headers
  232. Header and exhaust questions
  233. diferent years ported throttle body
  234. Radiator Upgrade?
  235. Done with exhaust 3" to 2.5" true duals over the axle (lots of pics)
  236. TSP doesnt fit together??
  237. No one makes the exhaust I want?
  238. Pacesetter LT,TSP ory, Mangamouth pics
  239. how to adjust the throttle body cable?
  240. Hooker
  241. arp harmonic balance bolt on backorder for a month??
  242. Help Locating Squeak
  243. pacesetter y bang?
  244. cut-out cap!!
  245. timng cover
  246. Descreening stock MAF?
  247. Cats off, running rich?
  248. Throttle Body Spacer on a LS1...Any reviews?
  249. Oil on outside of spark plug?
  250. Anyone running a dumped Y-pipe?
