PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 [282] 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Anyone know where I can get the Hose that connects to the...
  2. Kooks True Dual 2.5" Bolt-On Over Axle Setup, Need Feedback
  3. Pics of GMMG Oval Tips on WS6?
  4. How Would My Z Sound With One Bullit?
  5. Noobie looking for info on exhaust and intake
  6. Another GMMG question
  7. Cutouts and FLPs
  8. 4" Stainless Steel Mandrel Bends?
  9. How much HP loss?
  10. where to put the cut out
  11. LSX Intake?
  12. gmmg exhaust clips
  13. True duals or GMMG?
  14. pacesetter headers, stock maf 2002 z
  15. Magnaflow 4 inch catback
  16. Good Exhaust Setup?
  17. Mac headers and high flow cats
  18. Need a pic. of the fuses under the hood.
  19. Anyone with GMMG catback in Orange County or LA?
  20. Those with pacesetter headers.
  21. Anyone else make a electric cutout besides QTP?
  22. How much ground clearence will I have if I...
  23. The lip on my battery tray keeps braking.
  24. Magnaflow or Borla to replace Loudmouth resonator...
  25. Sound clip please
  26. car shut off. TB maybe?
  27. cutout too big
  28. ? for those w/ true duals & bullets
  29. borla XR1 muffler
  30. SLP Exhaust ?'s Please Look
  31. Starting problem, ignition delay
  32. Cutout Rattling
  33. Need suggestions on exhaust for 422
  34. Electronic cutouts
  35. GMMG Questions, make me buy one!
  36. Another CUTOUT question...
  37. added Kooks now 451rwhp
  38. Rich or lean without cats?
  39. QTEC Electric Cutout Broken?
  40. Flowmaster collector vs. Magnaflow collector?
  41. Will this Sounds Good?
  42. SLP loudmouth with headers and no cats
  43. GMMG exhaust
  44. Poly motor mount??
  45. Just headers ?
  46. What is the best headers for 383 engine.
  47. sealing up the air lid.
  48. how much coolant?
  49. help**header flange warpage?
  50. TB hole....what to fill it with...?
  51. F-body Alchohal Injection
  52. Hp?
  53. Few Questions
  54. ASP pulley worth it?
  55. LT's, Off Roads, and GMMG?
  56. Question about SSRA
  57. engine/trans removal questions....
  58. How are TTS LT Headers???
  59. Belt squeak...Crank pulley?
  60. HP gain from removing or bypassing Power Steering
  61. 02 extensions???
  62. Which Mod should I do next??
  63. long tube with no tune
  64. SLP Muffler Vs. Flowmaster HELP!
  65. Rear O2 question
  66. removing EGR and AIR
  67. Large mufflers with true duals and ground clearance?
  68. 1/5/03 FYI: FAST Intake Manifolds are starting to ship
  69. throttle body question.
  70. Serious Drivetrain Problems....
  71. Random Tech Metallic Cats
  72. Horspower question
  73. Will 2001 Headers work on a 1999?
  74. Egr and air tubes block offs.
  75. Exhaust set-up question?
  76. New SS Induction is complete. Video inside..
  77. Jet hot headers/ hooker long tubes
  78. Boring a LS1 Throttle Body
  79. Which ASP Pulleys?
  80. Uh Oh... What sensor is this....
  81. Dyno numbers from yesterday!
  82. ASP underdrive pulley kit
  83. electric water pump= HP ?
  84. Flowmaster Catbacks
  85. battery not charging. exciter wire? help please?
  86. BBK or Port my TB
  87. Quality of dynatech's new stainless LT headers?
  88. Headers?
  89. MTI throttle body
  90. Kooks Headers.... Stepped Or not
  91. Centermount hooked up to borla
  92. ORY pipe bangin under seat.
  93. True dual who sell's them
  94. Gmmg Vs True Duals?
  95. Thinking of LS6 intake, worth it?
  96. Header Bolts and Gaskets
  97. MAC mid length headers
  98. LS1 to LS6 Intake Conversion guru's inside!
  99. really weird power loss and misfire prob, help please
  100. Considering losing the cats on my WS6!
  101. Odd Rattling During Revving???
  102. flow for stack ls1 intake?
  103. Header Gaskets?
  104. HELP! Poly. motor mounts winning battle!
  105. Truck & F-body alternator the same? Would it work?
  106. Who Makes a Nice Catted Y????
  107. Intake Gasket?
  108. cutout and power loss?
  109. Car runs great after new plug install, but....
  110. Any quality probs. w/ Corsa exhaust?
  111. as promised **Video of True Duals**
  112. PPC vs QTP headers
  113. Help With Harlan Shift Light
  114. solid motor mounts?
  115. pics of true duals
  116. My car is ticking after Pace Setter install
  117. Rough Idle Cure
  118. Pacesetter install done :)
  119. all these true dual exhaust threads are driving me nuts!
  120. autometer gauges ?
  121. Any Dyno #'s On Kooks Lt Headers
  122. F-body fans question?
  123. Anyone had experience with both?
  124. I know this comes up alot but I need advice on headers. Pacesetters, or hookers.
  125. 6.0L TB, what size is it?
  126. After Market valve covers?
  127. Car hesitates at start up
  128. Freakin Temp Guage sensor broke off in the block
  129. Better Y pipe cure rasp?
  130. forgot belt size
  131. hedman universal x pipe
  132. fast intake
  133. Buying headers
  134. How tight do I tighten the spark plugs?
  135. Will I Need O2 Simms??
  136. Blinking SES after header install
  137. Temp. Sensors
  138. Started my Pacesetter install
  139. Want to rid myself of the Flomaster, need some help
  140. Frustrated....... to say the least!
  141. Another freakin problem (fans wont turn off)
  142. GMMG, to be or not to be?
  143. Car wont start after header install. HELP!
  144. Found a surprise when changing plugs.w/in
  145. Boom tube pictures
  146. Check out this x-pipe kit I just ordered!
  147. Need Tach Help Asap
  148. ? about filter before the MAF
  149. header install question
  150. Which to get first, asp pulley or ported tb?
  151. Borla catback?
  152. I making my own ram air induction for my SS.. pics inside..
  153. Jet hot cats should I yank em out?
  154. shorty header question???
  155. Opinions on exhaust
  156. Bassani Muffler Question?
  157. Poly Motor mounts on the way.
  158. X pipe true dual fitment with BMR driveshaft loop??
  159. Need A Question Answered..
  160. Quick Power Steering Question
  161. Calling all with mufflex 4in
  162. Re-installing Crank Pulley
  163. Mac vs. Pacesetter
  164. Hooker LT's vs. Pacesetters
  165. What all to buy?
  166. Sound clip of my true duals (Moroso Spiral Flows)
  167. Stock Muffler Diameter??
  168. Detailed Description On Kooks Headers Install
  169. GMMG Is On!!!
  170. Pacesetters on. Now car vibrates like hell
  171. Which mods first
  172. OK.. Another question about header install
  173. i-pipe
  174. Best exhaust with MAC headers and o/r y-pipe???
  175. ORY-pipe problem...
  176. Boom tube has arrived.
  177. Weind leng. intake gaskets
  178. Just to make sure..(02 sensors)
  179. March brand dampner
  180. trumpet manifold set-ups that use the existing delphi PCM
  181. Nitro Daves:January Install Specials
  182. Where to get X-Pipe??
  183. dyno run from true duals (kinda big - 1024x768)
  184. Best exhaust for a 9 to 10 second car?
  185. what is your favorite bolt on mod?? come on in
  186. jet Hot coated header help ???
  187. Belt Tensioners?
  188. throttle body ?
  189. Pacesetter header bolts?
  190. Accessory brackets F-body to Vette'
  191. HELP!!popping and missing after header install
  192. still gettin oil sucked in, everyone help!
  193. Hooker cat-back and rust??
  194. cutout question
  195. ATI Damper
  196. Need some help with driver side header install
  197. What Kind of Gains From LS6 Intake on Cammed LS1?
  198. Magnaflow Catback?
  199. O2 Sims question
  200. Battery fitment
  201. headers w/o o2 sims
  202. changing from a flowmaster to a hooker
  203. Best Headers?
  204. Stock catback compatability: will 94z fit a 98z?
  205. Just installed FLP LT
  206. oil dipstick
  207. Autometer Tach
  208. Tools Needed For Header Install?
  209. stupid question about the 160* T-Stat
  210. LS1 to LS6 Intake
  211. Borg-Wagner Spark Plug Wires? Please, answer ASAP.
  212. Fluidampr
  213. Fast Pcv Help!!!!
  214. Next range hotter than AC 41-931
  215. Going to do it myself now...(Header Install)
  216. O2 simms Question???...
  217. Good Thermostat for a 01 SS?
  218. 95-105mm throttle body VS. 4 barrel throttle body
  219. Help, want LT's, but need muffler advice 1st
  220. Cross brace under y-pipe?
  221. !egr block off plate
  222. Fitment on air lid?
  223. 180* t-stat WTF
  224. Duels exhaust with stock manifolds?
  225. !egr removal?
  226. Creating an LS1 exhaust website, give me ideas
  227. new exhaust installed
  228. Coil Relocation.. Need pics/help
  229. torque header bolts too?
  230. Installing FLP headers, any tips?
  231. 1 7/8 Headers
  232. 3" true duals vs 2.5" true duals
  233. Do Ceramic coated headers perform better than stainless steel because they're cooler?
  234. Header Question
  235. ls6 intake swap gone wrong
  236. sleeper exhaust set-up
  237. header gaskets
  238. March pullies?
  239. SS Hood Or GMMG Exhaust
  240. Need help with header install
  241. valve covers
  242. throttle body help.
  243. my new exhuast parts (thanks santa!!!)
  244. Need a throttle body
  245. Getting rid of EGR
  246. HELP: Where can I buy dual CME Tips?
  247. can headers really hurt my ws6
  248. Gauges flipping out.
  249. A/C Removal?
  250. LS6 Intake Manifold
