View Full Version : Generation III External Engine
- Mufflers with duals?
- 2000z28 manifolds vs. 2002 SS manifolds?
- lid and slp bellows?
- Thoughts on "spaghetti" LT's vs "straight" LTs's
- SUPER SUCKER RAM AIR
- Best bang for your buck?
- MAF End Help
- No oil pressure after intake install
- Dyno Tuning
- Please Help Shifting Issue
- Justin Sutton xpipe
- flp 3 inch collar clamps for headers and cats, f_ _king rediculous!
- Battery Tiedown???
- Fast Toys Ram Air vs. SLP Ram Air
- hooker LT's
- Header/SFC clearance & running rich
- Do all headers create oil issues?
- My future setup?
- Stupid intake question
- Ticking Noise!!!
- LS6 vs. Holley Intake
- Big tube long tubes?
- pics of FLP's...
- Duals w/ Madman Torque Arm?
- LT1 spark plug gap ????
- y-pipe
- True Duals?
- spark plugs
- Do I Have a Intake Leak?
- Car throwing a code! (PO420)?
- My thoughts on MAF screen
- LS6
- Simple question
- Power Steering Cooler Install Direction
- 6 banger camaro
- 2000 Firehawk - No Crank
- Belt size help
- HOW WOULD THIS SOUND?
- Are headers really that big of a deal?
- Volant intake system?
- dual qtp's and sfc's???
- Anyone know of /have pictures of pulling lt1or ls1 with the transmission attatched?
- Header question
- Questions about the A/F ratio with my TPIS headers?
- ASP pulley and overdrive alt??
- Powermaster starter for LS1
- Z06 maf on Truck?
- Megs tips They look great, whos got em??
- NEED HELP POOR DYNO RESULTS!!!
- Is 3" Overkill? Yeah, maybe.
- A/C delete?
- NEED IDEAS!! I need some help on what to do to my Auto Z28
- ASP Pullies
- Headers
- Who makes 1.75 step headers?
- SLP vs Edelbrock headers
- New LS1 Induction for F-bodies!
- Jet Hot LTs, did your melt the heater cover?
- Best way to get rid of exhaust resonance.
- resonator????
- Cut out worth it?
- need help with CAI >>>>>>>>>>
- I Know you have been asked this before ..... sorry
- engine specs on 2003 5.3
- Black exhaust tips?
- 160 or 180?
- Help with HARLAN 2 step and trans brake application
- Problems with cutting off catalytic converters
- Considering JetHot's....
- How do you make a fuel cutoff switch?
- Free Mod? Smoothing inside of stock airbox lid?
- will headers.....
- Speed Sensor, signs of a bad one?
- anybody seen these duals?
- NEW Borla muffler just released to replace stock LS1 muffler....
- is Ceramic coating really worth it ?
- SLP exhaust vs Corsa Weight
- Engine temp gauge.
- PORTED MAF WITH TRANSGO
- Egr Mod
- Corsa exhaust is falling apart!!!
- Bolting your headers to a custom Y-pipe / X-pipe?
- On a head cam w/hooker LT's and stock muffler how much would i see with cut-out insta
- KOOKS headers?
- mti 422 #36 ford injectors OR #42 lucas?
- Holley Intake
- Flow Tech X-pipes any good?
- Ported T.B. problem
- SLP LM w/ gutted cats sound clips
- Gauge wiring questions?
- Mac or LTīs
- Ported TB gains on bolt on car?
- LTs and Y vs lTs and x with duals
- What is stock injector size??
- Flowmaster mufflers bad?
- buying 02 SLP ramair kit, but i have a 98 TA.
- what size injectors will I need
- problems after MAC install FIXED! :)
- where can i get an x pipe
- Jet Hot Headers emission question?
- PAGING Bret Bauer
- This is probably a stupid question...
- Fuel System Help ASAP
- Who has Grots & SFC's?
- QTP Catalytic Y Pipe Info and Pics
- Which Cat-back?
- Gauge Questions??
- Horsepower upgrades? Best options for new body 2002 Trans-Am
- Does the SLP aftermarket Lid out perform the OEM Blackwing Lid??
- what to do with $2000?
- Need cut-out advice.......
- Has Corsa fixed the problem???
- Need a quick, educated response please.
- Exhaust Question
- would headers hurt me
- Steering funny after Header install...
- Roughly how much more power with Grotts over Jet Hot or Hooker LT's?
- Headers
- What makes the Grott design (QTP&PPC) headers worth $500 more than Jet Hot LT's?
- True duals...2.5 or 3"?
- High(er) Octane
- Alternator relocation bracket
- How did you hook up your catch can? Pics?
- How to gut cats or know someone who will
- Will Dynatech headers help me or hurt?
- 99 and 01 engine differences?
- Hooker cat-back problems
- Question for you QTP Electric Cutout users
- Minimal gains with Mac headers and MAFT
- Car won't start, need help diagnosing the problem.
- Anodized Red TB PICS!
- C5 Exhaust...
- If you have TRUE DUALS, please come in!
- SLP Header corrosion?
- How much lower down coating REALLY lower header temps?
- Eng Sensor Fuse under the hood???????
- DTC P0128 - Engine Coolant Temp (ECT)
- Porting LS1 intake
- CAM SWAP HELP
- Y pipe cutouts
- For those with dynomouth...
- What does the MAP sensor do? How to hook up to new intake?
- NGK tr-55's?
- Any experiences with PPC Headers?
- I live in Chicago, if I remove EGR, do I pass EMISSIONS???
- How to get belt to stop squeaking?
- Quick question about cooling system....
- turbo kit for camaro
- Disconnecting fuel line, with no tool
- Whats the difference in Holley/LPE intake revisions...
- FLP Headers complete kit, or Hooker Coated Headers?
- Headers?
- car in garage, wires everywhere, tach needle D.O.A. please help
- AIR INTAKE MOD.
- LT's help!
- Disconnecting fuel line without a tool
- how do i rid of EGR?
- QTP cutout & Borla
- Difference in 96-97 and 98-02 catbacks?
- Strange Intake Question
- LS6 Part # Confusion (???)
- headers and muffler question
- My 2 cents on my bolt-on's so far
- WHAT IS VATS
- factory driveshaft Q's.......
- Dynatech LT's, cat delete, true dual, dynomax bullets.. NO GAIN??
- stock ws6 rim key? how to get one if you dont have one
- Need to gain 4/10 in quarter, what will it take?
- Paging sheet metal intake owners
- mac headers no track gain????? help please
- Need help on Not LS1 Problem 5.0 camaro
- Please help, car is acting up.
- Spark plug install. How long typically/
- Ported TB's generally richen a car right?
- How much will loose.
- How to Dyno a Car with vig 3200 stall
- Can someone TOTALLY explain GM top engine cleaner
- Air/Fuel Gauge install ?????
- K/N FIPK ???
- What is the meaning of WOT run ?? please
- Car won't start, need some help.
- Part number or where to find gasket for K&N Filter
- FTRA & BG Ram Air kits
- Fuel Pump question
- HEADERS INSTALL ON LS1?????
- Dropping Cradle... A few quick Q's
- I need a quiet 3.5" muffler
- ac compressor
- intake manifold bolts
- Best Ported TB? Shaner S2? Bauer? Thunder Racing?
- Dynomouth or Borlamouth?
- OK to paint ASP pully?
- Any AC experts here?
- Where can I.........
- Spark Plugs
- park Plugs
- ASP Pulleys? Pros/Cons?
- My new Siemens Deka injectors came! (pic)
- Coat cat-back to protect from road salt?
- Need help with vaccum problem when I removed AIR and EGR
- Fuel pressure regulator question(s)
- Any of you guys runing Custom Fuel Rails?
- Any differences between 01 LS6 intake manifold and '02-03 Intake manifold?
- Anyone running the PPC headers?
- QTP or McCord?
- GUTTING OUT THE CATS..
- LT Headers & no cat question?
- Got True Duals today!!!
- ASP pully insallation question.
- Is a ORYP to stock 2002 Hawk exhaust w/ LS6 motor worth it?
- What can I expect to see from an LS6 intake and Pulley on my H/C setup?
- Stock exhaust manifolds - room for improvement
- Quick ASP Pulley (crank only) question...
- Headers
- Unplugging engine wiring harness?
- "TICK, TICK, TICK" go my headers....
- Best way to weld cats onto ORP?
- Tuning after LS6 manifold?
- loudmouth ??
- Its been asked before.... but lets see if we can get a final answer.
- SES light = Messed up CATS?
- SS Tube Size
- AHHH! Exhaust leaks still?
- How to hook up stock air pump for evac system?
- 16volt battery question
- Need thoughts on whats wrong with my car.
- LS6 intake part number?
- tuned length header extensions???
- anyway to 100% leak-proof LT headers?
- so now what does everyone think about their supersucker?
- Throttle body bump stop mod done
- Running rich after Ported TB installed
- mac's vs uncoated hookers
- removing coil packs..
- Having problems with Idle?
- Can't maintain fuel pressure at WOT or turning right?
- EGR and Air...if u deleted it inside
- QTP cutout question?
- Dual Cutout question
- All those with the SLP 85MM within
- Y-PIPE RUBS
- Plug ? w/ new setup.........
- Having idle issues with new ported TB
- Anybody have an AIR pump go bad????
- Access to generator "sense" terminal
- removing WS6 hood baffles
