PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 [120] 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. cold air
  2. Exhaust Poll, Keep Magnaflow bullets or without?
  3. post your valve cover pics!!!
  4. Tune after Header install?
  5. MS3 in a DD
  6. Sound Clips of my GMMG, Custom O/R Y and Flowmaster Merge
  7. ASP balancer. What size bolts for balancer puller?
  8. arh wideband placement
  9. torquer v2 clip
  10. Come Check It Out!
  11. Bar codes on factory heads
  12. My custom trueduals *lots of pics*
  13. Air leak?
  14. vic jr work with L92 head?
  15. Fast 90/90 install problem - 2500 rpm idle after install
  16. I need Pics and some advice!
  17. Header Question
  18. Will a harmonic balancer help the motor live longer?
  19. Need opinions
  20. started my ls6 intake swap, few q's and pics
  21. will it help?
  22. heads
  23. Wht to coat AN lines / to prevent chafing?
  24. Misfiring and Shaking
  25. HELP! cooling fans not working!
  26. Oil Gauge Bad Readings?
  27. Gauges cluster question
  28. what is it with gm running coolant through the t/b?
  29. F!#!ing Spark Plug
  30. Misfire/stumble issue (vid inside)
  31. Car is smoking! PLEASE HELP!
  32. ARH 1-7/8 install
  33. how to tell what year a motor is, casting number
  34. Cobalt Gauges
  35. How to mount catch can with EGR in place?
  36. LT/ls6 intake swap car runs amazing!!!
  37. harmonic balancer bolt sizes? 16m, 24m
  38. Need some advice after plug and wire swap
  39. Different LS1 alternators?
  40. Trans won't kickdown & RPM's Off
  41. Ligenfelter oil sender block
  42. Few more videos of my MS4/Borla XR-1 combo
  43. i am getting a slp y-pipe keeping the cats will this make a sound difference
  44. Odd misfire, no check engine light, happens after car runs a little
  45. Egr/Air Removal
  46. Billy Boat exhaust clips?
  47. HELP! Header install!
  48. Want to see some intakes*************************
  49. Will LS2 coils fit an LS1?
  50. Stock Oil Pressure Gauge Not Working??
  51. My Painted LS6 Intake
  52. Car shifts at 4k after LT install??
  53. Will a Magnaflow Race Series Muffler quite down my car?
  54. Pulley pullers...
  55. Cleaning out oily intake manifold
  56. Cam help for ls1 67 camaro
  57. Borla exhaust question (pipe missing??) stock y
  58. Difference between going over or under the axle for True Duals????
  59. No hookup for hoses on NW TB?
  60. Is this Deal from Texas Speed any good?
  61. What muffler for my single 3.5'' exhaust?
  62. Engine Harness Debate
  63. MEZ ewp question
  64. car wont start anymore
  65. JAAM owners, what do you think of your mod so far?
  66. Dr Gas Street Rod Boom Tubes
  67. 90mm TB, Will the stock bellows still fit?
  68. MS3 or MS4
  69. coolant flow
  70. Catch Can Drain to Crank Case
  71. What do you think ?
  72. cutout question?
  73. cam/dyno tune question
  74. Uptate on the QTP Dilema!!
  75. Oil pressure sensor.
  76. hissing noise at engine shut off!
  77. For a true dual setup does this sound good?
  78. LT header installation by unbolting mounts and rotating the motor?????
  79. New Exhaust Clip
  80. Reaching my 400rwhp goal
  81. HELP on this set up
  82. maybe some help
  83. Any true dual kits taht work with an M9 rearend?
  84. What does an 02 TA have for cat back?
  85. ls throttle cable wheel adapting to 4150tb?
  86. Making my own intake system?
  87. problems after install
  88. compression ratio question
  89. remove cooling fans???
  90. How Tall Are They
  91. LS6 Intake install ?'s
  92. Found out i have 1 853 head and one 241 head!! How bad is this?
  93. exhaust leak or valvetrain?
  94. Guestimate my power....
  95. Do Loudmouth 1 And Straight Pipe Sound The Same???
  96. Ploy Mounts..direction??
  97. Removing stock cat back?
  98. got my Kooks headers, a little disappointed
  99. FAST intake TB opening porting?
  100. Race Proven Motorsports TFS 215 RPM-3 Cam
  101. How Much Rwhp You Get From Kooks Headers
  102. What head casting do i have?
  103. Strange TR55??
  104. Which catted Y apart from TSP?
  105. OFF ROAD y TO CATTED y
  106. will 243 heads fit on a 99 ls1
  107. Can I use the newer t stat in my 2001
  108. 2OTL Pics
  109. Where can I get a 3.5" Y-connector?
  110. Need A Cheap Place For Mandrel Bends
  111. Muffler Problem ????
  112. TSP Rumbler exhaust tip suggestions
  113. Camaro's w/ Hooker Catbacks..........
  114. New belts for SLP Underdrive Pulley?
  115. Do It Yourself Heads/Cam Swap....
  116. HELP!! what else so i need for this motor?
  117. Need GM Part# - Passenger side exhuast Mount insulator
  118. Bad oil leak from rear of the oil pan????
  119. QTP Y pipe, does this look right to you guys?
  120. LT header gains with H/C setup
  121. thermostat
  122. For those with TSP ORY
  123. Stainless Steel Works headers install problems
  124. headman headers
  125. Need QTP Y pictures
  126. My car Doesn't like the Serp. Belt....
  127. NEED HELP!! Cant find Vacuume leak!
  128. Which Maf Sensor????
  129. need exhaust help!
  130. How long did it take?
  131. Is a loudmouth enough?
  132. Where can I get flanges to weld onto my headers?
  133. EGR Block Off Plates
  134. ram air
  135. Is my exhaust holding me back
  136. Anybody got this y-pipe?
  137. Header Help
  138. Billy Boat Exhaust
  139. Quick Question
  140. side vent exaust?
  141. any way around the knock sensors?
  142. does the 01-02 fbodys still have air and egr?
  143. 3 shops denied putting on my tsp catted Y WTF????
  144. What am I giving up-
  145. What does a LS1 longblock weigh?
  146. Need part # for valve cover bolt (center style)
  147. radiator
  148. can someone give me a list of the companies that make y pipes for stock applications
  149. Couple cutout questions
  150. EMISSIONS ANYONE from KC, MO Lee summit area
  151. PLEASE HELP, Electrical Problem, Gauge Cluster Going Nuts!
  152. Belt Tensioner Deal
  153. GMMG to factory CME
  154. Header installation questions?
  155. Removing MAC midlength headers
  156. my to do list...y pipe fix, magnamouth
  157. New Magnaflow CARB legal cats put on this weekend.
  158. Carb Question Ls1
  159. some quick manifold help
  160. Need LT's, but which ones? ARH or Pacesetter?
  161. Does this look like a good 3" to 4" Y pipe?
  162. PCV Ground Strap?
  163. 2.5 TD exhaust non-mandrel
  164. PCV question
  165. slp ud pulley
  166. Buying an LS6 Intake off an 04 GTO.
  167. New Exhaust Is Underway
  168. Patriot ls1 heads?
  169. Borla mouth?
  170. tb bypass question
  171. Pacesetter ORY
  172. Mac mid's come on in!
  173. Replace intake manifold gaskets
  174. Header Help-Poor performance
  175. what kind of y-pipe or ORY for a lowerd car
  176. Bassani true duals 02 formula install
  177. Need a better throttle body and MAF..help?
  178. Fast 90 vacuum plumbing on an LS6
  179. V6 Radiator???
  180. Percy seal-4-good issues
  181. hooker polished stainless steel headers
  182. which ORY should I get for coated pacesetter LTs?
  183. my ultra z hood
  184. Where to purchase mandrel bent pipe??
  185. Just installed the kooks today!!!
  186. 93-02 V8 NGK TR55-IX Spark Plugs
  187. what bolt on should i do next...best bang for the buck
  188. Can I replace a small part of my Maf?
  189. TSP Rumbler X-pipe TD's?
  190. Hooker super comp 1 3/4 headers
  191. Belt #'s
  192. getting LS6 intake from 02 car, what do i need?
  193. Different LSx intake manifolds???
  194. Another Air Removal Quesion
  195. another mileage thread! =P
  196. clutch and LTs
  197. whats louder, loudmouth or true duals??
  198. SLP ram air duct
  199. LS6 intake for sale
  200. Trickflow Heads: Questions
  201. Question about AN line connecting to fuel rail as mine just blew off the rail.
  202. MSD Plug Wires
  203. Is this SLP LS6 intake missing something???
  204. 2.5" or 3"?
  205. bumper support delete mode any pics anyone, how much weight saved?
  206. ypipe bang!
  207. Need some help to modify my 2002 ZO6
  208. Need a high flow cat....
  209. SLP Radiator epoxied cap came off, what size/expoxy to use?
  210. What to do with my wires?
  211. power gains
  212. Modded stock rockers?
  213. SLP Lid
  214. what catalytic converter is on these cars?
  215. intake help
  216. Who Has Modified The 92mm LSx Intake to 95mm?
  217. IMCO PRO cherry bomb muffler for the f-bodys
  218. Can't get to that last spark plug wire???
  219. Emissions - Anyone from Arizona???
  220. Sweet Thunder Flow..?
  221. Where can I get this? (pic inside)
  222. can't decide... need help!
  223. Is it true that....
  224. msd 8739 HELP!!!
  225. Whats the best sounding stra8 through muffler
  226. power steering delete?
  227. MOD LS6 to fit EGR?
  228. miss question....exhaust related?
  229. what's the weight diff between TSP duals and 4" mufflex?
  230. LS6 intake ?
  231. Question about removing baffles in WS6 hood with K&N FIPK
  232. cam sensor
  233. H/C/I motor...SLP MAF or Z06 MAF
  234. SLP Fan Switch
  235. Bolt Ons......how Much Off E.t?
  236. Catback Question??
  237. Another LS2/LS6 intake question
  238. Can anyone explain to a non-mechanic how to change the water pump?
  239. Anyone run the cheap 1 chamber ebay mufflers
  240. NEED help picking a muffler!
  241. LS6 intake question
  242. question regarding longtubes and ory...
  243. Got my long tube headers... pics
  244. Knock sensor low voltage = retard timing?
  245. engine wiring harness
  246. Problems caused my my Aeroforce...
  247. I need a new lid and smooth bellow!
  248. Headers still bang with poly mounts???
  249. rocker arm stands
  250. ls7 exaust manifolds
