View Full Version : Generation III External Engine
- Thanks LS1-Tech !!
- gmmg...cutout?
- true dual
- Hole in header....
- sound clips for you guys, TSP Rumbler vs Sweet Thunder on stock manifolds >>> *VIDS*
- Long tube troubles?
- TSP True duals, stock manifolds, gutted cats
- Do true duals rattle your interior?
- will a '01 TB work on my '99?
- FAST intake install
- FTRA, pretty good.
- help....just installed hooker long tubes....
- true dual setup
- Car Running W/ Vacuum Leak vs No Leak
- Should I get a dyno-tune after headers ASAP so my richness won't ruin my spark plugs?
- manual fan switch
- header help
- ATI 10% Balancer Help - Belt
- Dual cut-outs behind the headers?
- Belt walking off...
- Jet Hot headers
- glue on tips?
- Need Help Asap!
- Stock Bellow Part number please?
- which cold air system is best
- Quick fly by of my car
- ls6 intake vs. ls1 vette intake
- Air Box Question (probably Stupid)
- Will Volant intake work with ASCD hood?
- AC Problem
- ac delco iridiums
- Is a cooler thermostat worth it?
- QTP LT Headers - Good or Not?
- Mac Headers with catted Y Pipe
- U/D Pulley
- 01' detonation issue, Been told it's the MAF...
- cats with true duals
- Cut-out or SLP LM???
- #6 plug tool
- SLP LT's
- what size cutout do i need??
- Ahhh... the sanity of a stock maf.
- should i change my EXHAUST
- Best price for a magnaflow tru X-pipe?
- Free Mods?
- miss the lt1 sound BAD !!!!!
- burnt up altenator
- X pipe
- ASP vs. March
- Lsx?
- Lingenfelter ported TB.
- Intake Question
- Intake seal question............
- just got my hooker headers and Y-pipe...questions...
- need something quiet
- Volant CAI Help
- Bassani TD w/Pasesetters
- Flowtech Warlock Exhaust?
- cutout pics??
- ATTENTION: Hurricane Rita & LS1TECH
- muffler
- x-pipe or y-pipe
- Vic jr/GMPP Carb Valley cover
- Hooker Soundclip
- Tuning after Pacesetter LT, ORY and catback
- 3" pipe
- 24/7 open cutout?
- Installed 2.5" duals / Ported TB noticable power loss??
- Help w/throttle body and IAC
- TSP True Dual Owners - Drone?
- ls6 intake...direct bolt-on for 98???
- What size cutout do I need for my stock c5?
- Finding parts...
- flowmaster only help...
- macs/ory/bullit...
- Hooker Exhaust...need help
- did i kill a cat?
- Borla---keep it or ditch it?
- HELP!!!:confused:
- O2 senssor Q?
- Can you clean an intake?
- Cat removal, exhaust burns eyes, Why?
- Exhaust Packages??
- dynatech supermax's
- victor jr carb intake vs ls6 intake on H/C 346
- ls6 intake
- jus got my 00 Z comp scanned for ses
- Took of Emissions stuff...question
- Slp y pipe and Magnaflow exhaust
- Winshiels Wiper Removal
- Do the Lingenfelter and Shaner ported throttle bodies perform equally?
- QTP install review...
- Spintech Catback
- Cutout Install
- PCV questions
- Which Headers...???
- Stinky smell from vents, do you have the same?
- Looking to do an exhaust build-up
- Stainless true duals!
- Help with choppy idle and surging
- 2 1/2 y pipe
- Borlamouth VS TSP duals
- Ran Open Headers...WOW
- Z06 85mm MAF and TSP 85mm lid
- Mac headers install kit where to get?
- Is plugging the pcv OK?
- Ground Problem
- Hooker to RT y-pipe?
- Pcv home made oil separator
- TPS Sensor Replacement on LS1
- Bullet Muffler For The Loudmouth
- Hooker Vs. Pacesetter
- slp headers
- Question about LG pro L/T's w/ out Cats...
- amw catch can post-installation question
- Hooker LT header EGR connection blew off hole the size of Quarter in Header Now what?
- Just bought Bassani True duals, what headers should i use?
- tsp true dual x pipe
- Does a ported TB actually increase power or just give sharper throttle response?
- Sheet metal intake questions
- Exhaust Suggestions?
- Anymore engine before 12-Bolt.
- HELP! i need pacesetters!
- Spal fans
- Long tubes going on my Z06!
- Are NGK Double Platinum spark plugs worth it?
- wiring harness
- which one is the loudest ?
- ASP Pulley question...Tried to search, but no luck
- EVAP, is it needed on a conversion?
- I could really use some help ASAP. I may be in trouble.
- Header install ?'s, Gaskets, bolts, jacks and stands
- Does GM cover this?
- New Radiator?
- rebuilding a belt tensioner
- Need a new muffler... Advice needed.
- exhaust tips sound?
- Hooker LT's & O2 extensions?
- mid length headers?
- If you get a cut-out what's the point of ....
- IAT Sensor in TB
- Difference in Y's
- Will any LS1 Balancer work on 98?
- poly mounts
- Ls2 coil install onto LS1/6 writeup, anyone have one?
- MAC Header/Y=pipe gain?
- volant or slp?
- O2 code
- Looking for catted y-pipe...
- Poly engine mounts for a daily driver?
- pics of cutout installed.
- GMMG..gettin a hold of the muffler setup
- Random Technology vs. Car Sound
- Headers,ory and only one cat anyone
- Harmonic balancer
- LS1 SLP radiator = LT1 radiator??
- Stuttering/Hessitation....???
- Co2 Intake?
- flowtech or hedman?
- Long tube headers
- A few pics of the lates mods...
- TSP Xpipe questions
- headers=louder
- just installed rumbler and wow
- Bo White Ported Throttle Body
- New MSD Coil packs
- quick dumb question.
- cold air kit?s
- just ordered my new exhaust parts
- Free mod concerns... :confused:
- Various single plane intake pics..... (BIG pics)
- K&N FIPK or MTI?
- Air check valve question
- FLP LT band clamp problem...input?
- Bucking and Surging: Bad Gas, O2 ?
- X-pipe vs. H or I-pipe...
- Car is runnin' like a bat outta hell!
- wanting true duals
- Heat wrap???
- Header Question
- backfire when A4 shifts?
- Putting An Air Filter In The Oil Cap
- custom dual exhaust setups, couple of questions >>
- pictures.....please tell me if this is causing extra engine heat
- Catch can on vent line?
- how do you quiet down exhaust for the street?
- TSP true Duel
- motor mount problems
- Rear Main Seal Plate Help
- Air bridge question
- LS6 Intake
- Hooker AeroChamber's on duals
- Header Install...Backfiring..Misfiring...Help!!
- LS1 Oil Cooler
- LS1 intakes??
- who makes custom headers or do anyone a set lying around
- Aftermarket...radiator and fans
- Header install yesterday, HELP
- Free Mods
- 921 and 918
- Which set of headers for serious FI?
- post pics of pcv mod/ catch cans
- 3" cutout on stock exhaust
- Need To Dump Loudmouth
- Stainless Works Headers
- flowmaster hushpower II
- To those with the Flowmaster merge
- Single chamber flowmaster.........
- how much will longtubes and ory help!!!!!
- bad converters and o2 sensors
- A4 guys + asp/ quick intsall ???
- How to Install Headers...
- Installed Cutout Today - BEST SOUNDING CAR - WOW!!!
- Well I got my LS6 Intake on
- AC pulley noise!!!!!
- Cold air
- coil packs....all the same for the gen III GM motors?
- SLP or Hooker headers w/tsp true duals
- LS1 Motorsports Lid
- LGM vs. Kooks headers?
- Borlamouth...yes i searched
- BGRA installed IAT temps lower
- O2 sensor connector type: Flat or Square?
- DR. GAS Boom Tubes
- exhaust leak help
- Which catback for my Z?
- Magnaflow owners inside...
- Problem with Power Steering after Cam/Intake/Headers/Oil pump etc.
- Who makes the Shortest, high flowing cat
- Emmisions
- volant dual intake dimensions?
- v6 questions!
- I need to quiet down my H/C/Kooks/LSX90/Corsa set-up
- Which intake manifold ls6 or weiland
- Exhaust, Rusting, and Rustoleum???
- new muff
- True-duels and cutouts?
- Stainless Y-Pipe
- How can you tell if your getting false knock?
- !cats and gas smell
- is Exhaust interchangeable between L98, LT1, and LS1?
- magnaflow
- Who has TSP Rumbler + LTs & ORY + Cam
- getting ready to install headers few last minute questions
- How Bad are Mac Headers w/ there catted Y Pipe.
- !AIR lid hole plugs
- ASP Underdrive pulley Question
- Dynomouth vs magnaflow muffler
- Clear smooth bellows?
