View Full Version : Generation III External Engine
- Where to get plug wires in custom length?
- Holley Manifold Gasket glue????
- Hooker LT input needed.
- Stripped air tubes off and no SES lights yet.
- Short belt?
- Injector sizes? Are 2000 different from 2001?
- Casting # 12560894 Intake Manifold = 2001+ FBody?
- Need help with fuel system problem
- Durability of headers
- Back pressure as related to low end torque
- Performance gain with cutout!??! help me!!
- RECALL.....AUTOMETER Fuel pressure gauge
- SLP Exhaust, Did I get ripped off?
- Lowered vert w/ Hooker LT's come inside...
- Electronc cutout
- What is the ID of the stock catback...
- What the hell is this part that broke off behind my intake manifold???
- which muffler?
- Fuel pressure regulator
- Carsound cats,magna-flow?
- Good Deal on CarSound Cats > Check it out >
- Lots of Hookers now sold > What ya useing for Cats?
- Hooker install problems??
- why not do this.....response to "The answer to Why Backpressure Doesn't = HP!"
- How to get rid of rasp between 2200-2800 on borla?!?!!?
- Just bought Macs, What else do I need?
- Mac headers and cracked welds
- Stock Exhaust
- How to replace o2 sensor
- A lid that fits the LS6 maf?
- Descreen MAF.. Y???
- How do you know when its time for bigger injectors?
- who else thinks we have some pussy-ass horns?
- Need switch help
- does any one have dyno results of loudmouth??
- New Stealth High Flow Air Box Assembly!!
- Can someone help me out?
- What did i break???
- best way to seal flp's using v-clamps
- Any1 w/ MACs & Loudmouth? Come in please...
- Water Pump Question!!!
- LS6 intake question
- ??HPP3??
- Has anyone installed a catch can in the PCV system?
- exhaust cutouts
- is this a good combo all at once?
- doing throttle stop grind mod-help with readings??
- pace MAF on heads/cam car?
- catback exhaust weights
- Where can I get a Baker Hose?
- John B.... look inside got a question for ya.
- bad sound??
- What wire do I tap into to hook up my Air/fuel guage
- High Tq starters...whos got'em
- octane booster
- Carsound or Random tech. cats?
- 2 quick questions
- MACs or LTs...
- BLACKWING
- shaner
- idea for crankcase evac
- Is this hurting my 4L60E?
- Air restrictor plates? need help.
- Mac's VS. SLP long tubes
- Walbro 255 ?????
- Cold Air Mods
- Installing a 160* t-stat any tips I need to know about?
- Macs or Hookers???
- Just got my Holley Intake manifold..few questions...
- Removing A.I.R.
- false knock?? could this be?
- Question about installing ls6 intake
- ls-1 edit system
- New Wires & Plugs Question
- Mac Headers w/ ORP and Magna flo exhaust.
- o2 sensor dilema??
- Port the back part of my MAF?
- 160* Thermostat, who's running one ???
- PCV update
- Borla vs. Corsa
- Just did the !FRA mod
- Ported Tb Problem, Urgent
- OE MAF 5.19 sq in Vs Whisper 7.06 sq in.
- Camaro SS Exhuast size?
- Power difference between equal length and longtube headers.....?
- smaller belt modification...
- Borla vs SLP y-pipe
- Hooker headers/ y pipe question
- spark plug wires
- O2 SIMS OR NOT
- Stock plug wire boot fell off!!!!
- need opion! true duals?
- Stock Fuel Pressure
- What is considered the "perfect AFR" ???
- borla owners thinking of a cutout inside
- Stock fuel pump.. Whats it worth? How much can it flow and support.
- Problem with idle after porting TB
- Mufflex 4" too big to pair up with Macs???
- T.B. question
- Who uses torque straps
- Damnit......Can I fix my radiator?
- Need a little opinion help Hooker Y or X pipe?
- Removing fuel rail. NOT fuel rail covers. question
- Bad @ss Ported TB/MAF/VC....Pics!
- Who has aftermarket high TQ starter
- Idle problems...
- The answer to Why Backpressure Doesn't = HP!
- Exhaust installation
- arent our cars set up for back pressure???
- what's the best fuel system cleaner??
- Just installed hooker LT; car runs rough
- Holley Annihilator DIS Ignition Vs Stock GM
- OK. LT question #6,573 for this board...come on in!
- How do you bleed air out of coolant system
- HOOKER Y PIPES ARE IN STOCK!!!
- Paging Slow Hawk
- Installed Hooker Lt's..car backfires now....
- What is the Timing Tricker Mod?
- Fuel Pressure Question
- offroad y-pipe w/ no O2 simms please help
- lower oil vis equals higher revs?
- Anyone have a source for cheap oval tubing?
- Duals w/ no crossover vs. Dual cutouts
- walbro 255 inline fuel pump leaking
- xpipe with REAL mufflers
- Stu how are those MAC's working for yea???
- do they make aftermarket COILS for ls1
- Surprisingly high dyno #'s through a 12 bolt rear end!! DYNO GRAPH INCLUDED!!
- Anyone heard of split-flow race muffers?
- 2001 FireHawk Question
- Problem w/ Thermostat install
- 2nd quietest catback????
- Will I need O2 extensions with the MAC headers?
- Bolt on question?
- Hooker LTs > Stock GM header bolts may be too long
- 3" or 3.5" for 475rwhp blower car
- HELP !!! Starter Problems
- Fuel rails, which ones to go with????
- X-pipe or Y-Pipe, I cant find one anywhere....
- Banks exhaust group purchase
- Hi temp RTV in place of gaskets?
- Burger Motorsports Ram Air
- hooker longtubes and y pipe?
- Need advise ; trying to break 11's
- Plug question
- Anyone that has purchased LS6 Intake w Coolant Pipes/Plugs
- LS6 intake - with or without EGR mod?
- All SLP dual/dual owners inside please...
- What epoxy to use to fill area in tb and how do I raise the coil packs?
- FTRA vs. WRA vs. SLP CAI vs. !FRA?
- Need help with Headers.
- dyno numbers
- Paging "GeorgeC", Crankcase Evac Pump Info Needed
- Using 28# injectors in a 99'
- flashing SES light
- 1 7/8 Grot owners come inside
- MAC Headers??
- true dual exhaust question
- Confused with upgrades
- What mufflers would you run with an h pipe and an x pipe? And why?
- Balance question?
- New LS1 Engine Available!
- Are my O2 Sensors Bad :SES Light
- Is my fuel pump dead?
- Hooker Ypipe any updates???
- is the tornado a gimic
- Best plug wires?
- Pics of SLP LM with single tips
- Pace Performance step-headers
- Flowmaster Collector
- What gains from these mods?
- PORTED TB
- Need help with dyno #'s
- Shhhhhhh Whisper lid question
- HELP install air/fuel gauge
- AIR Check Valve SES Light
- Bassani Off-Road Y-pipe for stock manifolds
- Hooker Lt header & ORY pipe help...
- EGR and AIR question (disable question)
- looking for mac header install doc
- Egr questions ! Please Help
- Some Holley Intake Manifold Pictures
- Question on my Mac Headers.
- Billet Valve Covers!!! Check out the link!
- GMMG questions
- When do the fans kick in ??? thinking about getting a HPP3.
- OIL COOLERS
- Need Help Fast
- Difference between asp and ati crank pulleys?
- quick help please
- bassani headers
- Need some info
- tried search. What psi shoudl AC system be at?
- Headers dilemma...which ones,what kind...
- Bassani Header- WTF? (Cartek Dyno)
- 346 w/ open headers?
- 2 questions (exhaust and cooler)
- HELP: Did bump stop mod,now The Tb blade doesnt touch
- Passed emissions with T-1 Cam!
- Ready for header install, but...
- Gutting cats?...
- Clutch?
- Injector/fuel pump equation?? Need help..
- Grotts Headers
- Muffler Choices.
- N E 1 HAVE Stock Y pipe 4 sale?? or headers??
- Mac Header Help
- Opinions on full exhaust choice
- Indexing spark plugs....
- Iridium Spark Plugs: Pros and Cons
- LS6 part # complete engine
- Can I pass Emissions????
- How I sealed my Dynatechs
- Paging Freak....Hooker LT question...
- Hooker Header Help?
- Help with some bad knock
- AIR Tube
- For those of you with hooker LT that didnt receive...
- Spark plug experts within
- jet hotted holley intake
- CAT BYPASS?????
- Header collector problem.....
- SUPREME INDUCTION MOD TEST FIPK vs SLP OE
- Preluber install
- clutch drill out
- which lid has better fit
- A little screen help
- Mellowing a "Loud Mouth"?
- Need Help: Horn won't stop blowing
- mass airflow
- Dynatech Merge Collectors...
- SLP Engineering OE airbox lid for all f-cars
- installing LM & Y-pipe....need tips
- DynaTech Headers???
- any headers which offer decent gains that can work on stock cats/y-pipe? for a 2002?
- Installing gauges
- A/C Pressure switch / Fuel Level gauge problems
- Another Lid Question
- Just removed the air tube and air pump. Now where can I...
- MAC's+Loudmouth?
- SHORTY HEADERS???
- Quick question about true duals
- header gasket Q.....
- Carbon Fiber Valve Covers
- true dual exhaust for 2000 SS?
- good street legal header y-pipe combo?
- Having offroad y-pipe installed-no o2 simms plese hellp
- Mac Headers and Cutout
- WEIGHT REDUCTION
- Nasty gas mileage...
