PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 [205] 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. dual or single cut out
  2. strange pcv system.
  3. Valve cover/coil bracket conversion
  4. Vert & LT?
  5. Coated or not?
  6. Stock Y pipe diameter
  7. What crank pulley besides ASP?
  8. Am I in the right spot
  9. You asked...Dyno #'s with "over-axle" true dual exhaust(NO X-PIPE)
  10. With or w/o AIR and EGR?
  11. Hooker COMP headers
  12. How far can you stretch stainless pipe ?
  13. lots of oil in intake and maf
  14. Replacement Water Pump Input/Feedback
  15. GROUND WIRES ON THE ENGINE...installed LTs and need some help...PLEASE!
  16. Debaffled WS6 hood yesterday
  17. i need some input on alot of things
  18. TSP True Duals
  19. Opinions needed _PLZ
  20. Spark Plug Wires
  21. What can i gain with a LS6 intake and maybe a tune?
  22. New to this need help???
  23. Anyone have a picture of under an F-body with Dual/Dual?
  24. bolton gains?
  25. oil cap elbow
  26. cutouts hurt??
  27. Dyno Tuning a must after LT's .....
  28. SLP cold air induction package worth $$?
  29. Header purchase
  30. powerbond pulley
  31. Big Brown came!! duals are on *PICS*
  32. exhaust and gas mileage... myth?
  33. 90mm Pre Intake Tubeing
  34. ADDED SOME SLP LONG TUBES and STRAIGHT PIPES and now the car will not idle????
  35. missing bottom cover!?
  36. Cheap/free mods
  37. what are effects of bad o2
  38. Fuel Pressure Gauge
  39. o2 sensor on the exhaust
  40. Headers?
  41. headers for a 301 cid pontiac
  42. cutout question
  43. What size plug for side of air lid after AIR removal??
  44. which 02s, and egr plug
  45. C5 LS1 wiring diagrams to convert to LS2 TB
  46. Muffler only losses?
  47. O2 sims or extensions
  48. explain how a breather system could be bad
  49. Spark Plugs Question
  50. H or X Pipe?
  51. Part numbers
  52. H pipe ?
  53. Rear 02's
  54. whats the best intake manifold for a 98 ls1??
  55. Slp Lt's
  56. So, mufflers do have a "break in" period, right?
  57. Bad O2 sensors, or just ORY pipe?
  58. Thanks
  59. Pics of my fast 90 painted with a ported 90mm n2o ring.
  60. o2 sensor help!!!!!!!!!!
  61. Straight pipe exhaust /Stock Manifolds/Y Pipe
  62. What Y Pipe for QTPs ?
  63. ls1 or ls6 intake?
  64. Emission Troubles?
  65. pipe bending
  66. Need help - headers on a stroked turbo build
  67. Mac Headers and ORY..Hp Increase? How much?
  68. header ?
  69. Oh the sweet sounds of
  70. march instructions say tighten to 240lbs then loosen & retorque to 37lbs?
  71. Bellhousing bolt holes stripped!!
  72. Kooks Headers w/ Emissions
  73. do i NEED a tune right after LT install
  74. GMMG chambered exhaust?
  75. Exhaust Leak at Header b4 and after a New Gasket??
  76. Header Gaskets on 1999 LS1
  77. True dual mounting quest. needed ansa ASAP!!
  78. ls1 plugs
  79. fast 90 throttle body questions
  80. Replacement LS-1 Thermostat Does Not Fit
  81. What are the ideal fan settings, for both fans, for a Vinci 170 degree thermostat?
  82. Air lid installation - how to get the iat sensor out of the old resonator?
  83. stock fans CFM
  84. Thinking about QTP
  85. Volant CAI?
  86. Air Conditioner removal help
  87. Anyone using solid motor mounts?
  88. Two cables on throttle body?
  89. FINALLY, i ordered my exhaust!
  90. Materials Needed To Port A Fast 90
  91. Ls6 To Fast 90 Intake Swap Help
  92. Will this stuff fit?
  93. Anyone heard of Extrude Hone for intake manifolds?
  94. Egr Air!??????
  95. Free Ram Air - Cut baffle, or remove entirely?
  96. ect and crank position sensor wiring question
  97. ASP pulley worth it?
  98. HeLp Please
  99. PCV delete
  100. Header Gaskets
  101. AIR! removal and fuse help please
  102. I want a catback that is quiet..
  103. Any one else tried this???
  104. How much will the Hooker hurt me?
  105. belt part # for ASP underdrive
  106. Header gasket melted
  107. bad parts?
  108. Loud Exhaust
  109. Portmatching a Victor Jr
  110. need part #'s for gaskets
  111. hedman or pacesetter headers?
  112. When your crank pully gets loose.....this has to be common....
  113. What makes more power?
  114. Why is exhaust quieter?
  115. Pacesetters or Edelbrock headers?
  116. Bigger intake than LSX90mm?
  117. MagnaMouth Track pass sound clip
  118. How much install time on SLP Headers & LS6 intake
  119. K&N filters is crap...
  120. how fast??
  121. flipping intake
  122. Borla vs Dyno vs Magna vs LM2 Muffler
  123. Y pipe vs Y pipe
  124. Got my GMMG !!!
  125. longtube headers install
  126. Header Brand Question
  127. Lucky or Not?
  128. Do I need a PCV valve with a catch can?
  129. A4 guys with UD Pulley
  130. need some long tube techs
  131. O2 Extensions For Jet Hots??
  132. Hows this for an exhaust
  133. Headers, period.
  134. Ported throttle body
  135. Do I need a PCV valve with a catch can???
  136. O2 sensors Q...
  137. Finished the Throttle Body
  138. Holley 90mm throttlebody....
  139. exhaust
  140. ?'s about dissasembling throttle body???
  141. Post pictuers of your exhaust tips on your Formula.
  142. Can a functional hood scoop and an FTRA or SSRA work at the same time?
  143. headers a must
  144. high flow cats
  145. 2.5'' vs. 3'' ypipe
  146. Slp Bullets??
  147. Pacesetter Q's?
  148. 02 extension routeing with long tubes
  149. FAST Manifold w/ stock heads + cam?
  150. Exhaust
  151. Where to get EGR and AIR blockoffs
  152. Y pipe question!
  153. magnaflow cat-back vs magnamouth
  154. is hedman worse than pace?
  155. ORY vs. Catted vs. ORY w/bullet
  156. how is everyone doin longtubes
  157. Synister Power Steering Pump Pulley Question...
  158. SLP LM + ?Headers
  159. Has anyone done this?
  160. Spark Plug Question
  161. TB Spacer???
  162. Alternator Installation please?
  163. custom cat placement? pros/cons?
  164. Spark Plug Read
  165. Problem installing new idler pulley
  166. LS2 stock bellows for LS1 90mm
  167. Help with high rpm!!
  168. oil pressure sensor
  169. ngktr55's
  170. Mufflex Y-pipe Feedback.
  171. Forced induction, Macs vs. Kooks?!?!?!
  172. Buying GMMG cat-back, owners come in here
  173. Nick Williams 90mm TB
  174. SLP Cold Air duct
  175. Cats removed, Why does it run like crap??
  176. slp y pipe
  177. Mufflex install has begun...
  178. MAF Sensor
  179. WTF...can't find a damn part anywhere
  180. FRA with SLP HO Hood, do it or not?
  181. imco muffler on a fbody
  182. nick williams 90mm tb replacement blade
  183. O2 sensors
  184. AIR & EGR removal
  185. Oil in Throttlebody
  186. Pacesetter Problems
  187. Y-pipe question
  188. BG Ramair parts?
  189. MAF question....
  190. Z06 Maf
  191. Sleeper Exhaust for a 02 SS
  192. Longtube Question
  193. Temp sensor in the drivers side head.......
  194. tsp rumbler vs. loudmouth
  195. help!!!
  196. Weird Exhaust Question????
  197. bottom pics of fast intake
  198. WOT activated cutout??? possible...
  199. loud pop
  200. Rotten Egg Smell After Catback And Lt Install
  201. I need TD Pics, parts info, etc
  202. intake manifold valve
  203. Quick Help Pls? Header bolts broke in head
  204. CUSTOM CUT-OUT - Sweet
  205. ARP Header Studs??? Really Worth It???
  206. Dynomax race bullet vs twisters
  207. Horrible squealing!!
  208. True duals on ebay??
  209. !AIR... what are the benefits???
  210. FAST intake install problem
  211. are fumes a problem w/ the tsp td's
  212. Napa gold /WIX part# plz
  213. anybody know where I can get cats that have gone bad to hollow out?
  214. GMMG anyone???
  215. Does anyone have installation instructions for a BMN window switch
  216. Solid motor mounts????
  217. FAST intake result
  218. one final queston be for buying LT headers (air/egr)
  219. Just Ordered True Duals
  220. Removed Air System...issues?
  221. Suggestions on making my SS' sound ROAR
  222. Exhaust Question involving SS SLP Package
  223. Oil breather for the valve cover...who sells them
  224. carb set up
  225. long tube install :(
  226. looking to quiet down the exhaust..
  227. Heater cap off....
  228. Ported throttle body
  229. Header Bolt Size !!
  230. Exhaust
  231. Got rid of my cats today
  232. Mid-Length Headers....need some help?
  233. What do you notice after LTs?
  234. Anyone using Tranzaman00s air intake?
  235. Plug Gap
  236. Tell me what this is Please....
  237. turn-downs or no?
  238. Pass. side heat shields
  239. Best/Largest throttlebody for an LS6 intake?
  240. Part Number Please
  241. Side Exit Exhaust???
  242. anyone ever get rattling after poly motor mounts
  243. Who else sells the LS6 intake collent pipes and plugsfor the ls1 to ls6?
  244. Just bought duals, major question... input please
  245. gains from a cutout or cutouts...
  246. QTP Header Question.
  247. SLP headers, y-pipe and cats...
  248. need maf that will handle 750hp
  249. sweet thunder?
  250. slp optioned center mount catback
