View Full Version : Generation III External Engine
- 1st ls swap, 1st start questions on testing wiring
- Starter okay or ??
- Electric water pump
- Group 78 battery.
- 6.0 into 99 Silverado with 4.8 Flexplate gap 1/4
- Small Miracles
- SLP y pipe
- Hotwire Harness question
- Where to order an H pipe??
- TKO 600 VSS connector
- Welding in EGR provision on passenger side for long tubes, can it be done?
- What fuel setup does anyone with a built motor run?
- Rear cover alignment?
- fourth gen camaro intake manifold clearance
- No fuel at schrader valve
- Summit Racing Rear Cover - Any good?
- 04 chey 1500 newbie question
- Engine Replacement
- EVAP Canister Purge Solenoid
- Switching LS6 to LS1 intake...yes...What do I need?
- 05 lq9
- Power steering rack bleed question
- Should I buy this ? Ls6 intake 90mm TB & fuel rails
- Oil pressure sensor
- LS1 heater flow for expansion tank
- LS6 intake VS fast 90?
- new Intake and TB. IAC will not come off 0 counts
- Hooker Blackheart Exhaust review
- Be Cool Radiators
- are stock manifolds the same?
- Best Cold Air-Intake??
- Custom LS1 Electric Water Pump
- Intake Gasket Sealant?
- Another header/exhaust suggestion post..
- Should I hold off on assembling motor?
- Plastic covers wont stay in place
- wanto make sure i get all the water out
- Need to find quieter mufflers for true duals :(
- Using used lifters with a used cam!?!?
- Are 1-5/8 Short Tube Headers To Small....
- Stock ls1 or ls9 head gaskets?
- My air filter solution for a 4150 TB
- What are these connectors to?
- 1998 Camaro Z28 Electrical Problem
- NW 92mm on FAST 102?
- ok, what am i missing?
- 4l60e transmission wiring question.
- 98 ss engine codes
- Throttle Body recommendations?
- AC not running cold? HELP
- Bone Stock 01 or 02 Ls1 tune
- Installing 4" Mufflex Help
- Ported truck intake?
- LS1 tune up?
- New Mechman Elite 250 squealing LOUD
- VSS output from PCM
- Thanks to WS6 Store
- LS 7 Motor LS 4 Heads on it.
- which to go? and should i go? 3.90 , 4.10 gears
- Intake Swap Lost TCS and Got code p0108
- Cats / o2 Sensors / exhaust HELP
- Power lost from fast intake swap??
- Anyone using the Weiand 300-111P for LS1?
- Car won't start help!
- Heads for LQ4
- Ls3 exhaust on ls1? Does it fit properly
- will this steam vent setup work??
- Results are in! Ls1- PRC 2.5 LS6 / 228R Cam! *431/410*
- Ls1 wiring
- Making Custom Throttle Cable Bracket for MSD AirForce Intake
- I hate titles
- CBR Alternator Relocation Question
- Engine Vent with new Holley Valve Covers?
- Stock or PRW SFI flexplate?
- Oil Leak
- Are ARP 7/16 Head bolts ok on a 402 on Spray?????
- SFI Truck Balancer Stock Diameter?
- lq4 / truck accessory bracket torque spec ?
- A/C compressor from 5.3 truck same as LS1?
- T56 swap , now limits at 4500rpm??
- ARP crank bolt with oil on it?
- 4150 Throttle body questions
- Will knock sensors fit under a fast LSXRT?
- Fast 92mm port seals
- 2002 ws6
- Help!! Accidentally bought ls3 valve covers
- 2002 FBody LS6 Intake Question
- Ignition coil testing, brands and is it a knock-off?
- Weird all of the sudden major idle issues
- I hate titles
- Ls4 injectors ? Rail on ls1
- Bullet vs Powerstick
- turbo 750 hp flexplate and driveshaft?
- 1999 z28 ignition leads
- Quick maf question
- ASA racing ECU P/N 12480054 tune
- Ideas on issue
- 02 Camaro SS Specs???
- Any one use dr gas mufflers or boom tubes?
- Melling oil pump
- Fast 92 and WARR 92mm TB install issue
- Y pipe to cat-back fitment
- Knock sensor issues?
- your thoughts/ valve covers
- what the? wow.
- Running Rich
- Question: Lt1/ls1 t56 rockland std gear conversion
- bad oil pressure sensor?
- LS Swap Clutch Hardware >?<
- TB Question
- Header Noise
- eBay buys, Oil Cooler adapter, GlowShift gauges & more
- Dumped true duals
- Power Steering Pump?
- Holley intake manifold won't seal.
- could i have had any issues from this?
- would I need a CASE relearn?
- I LOST 20ftlbs. And 5 hp!
- Does throttle body orientation matter? 'Custom' intake issue
- Convert 3-wire (4-way plug) '04 Alternator to 2-wire?
- Br7ef plugs and rough idle
- Aftermarket Accessory Brackets
- Busted fast intake
- LQ4 Throttle Body IAC Port
- EGR question...
- Recent Rebuild 5.7 Won't Start. Missing Ground Back of Passenger Head
- Ms3 Gold box in a 2005 (gen 4) GTO with a gen 3 LM7
- New exhaust
- Fast 92mm intake
- Exhaust clearance?
- speed engineering headers and y pipe
- Easy Way to remove excess oil?
- 04 gto brake booster
- Best aftermarket fuel pump?
- another issue
- Sound Deadening
- FAST 92MM Intake on a 2002 SS Camaro
- Set me straight on Spark plugs....
- Help me solve my oil consumption!
- Egr block off question
- clicking sound and now locks don't work
- metal bracket on intake
- Iac ?
- Question about front covers
- Engine Wiring Harness
- Holley Hi-Ram Rear Port Question
- steam pipe vs plug question
- waterpump rubbing against ac belt
- Alternator Relocation Bracket - Looking for specifics
- i nere need your ideas
- Can exhaust sound be unbalanced with side exit?
- Axle Dumps on 4th Gen
- Radiator Fan Assembly replacement
- Fully ported LS1 heads (#806) on a. LR4
- Bellhousing dowel diameter LQ$
- question about amount of coolant
- Ls6 intake manifold fitment
- Be Cool Radiator install in a 2002 WS6
- just curious
- heat wrap lt's before install?
- Trying to quiet down my car
- cleaning throttle body
- Odd thing happened the other day.
- H/C Install checklist with a few ?'s
- Need for tune or just bolt on? - C5 throttle body 78mm to a newer (01-) 85mm.
- Cathedral Port Head Flow
- LS2 E40 24x 3(?)pin Alternator problem
- LS6,LQ4 PVC valve set up with an LS1 intake
- So you want a light exhaust?
- Where Does This Wire Go
- Reluctor help
- 6.0 to 700 help!
- Injector Opinions - Injector Dynamic or Fuel Injector Connection
- Lost AC part while doing cam swap
- Need help choosing my new exhaust...!!! 99 z28 m6
- FTP 98MM Lid + 85MM MAF or my current set up? Going to install 92mm FAST Intake + TB
- PCV ground strap/ LS6 PCV conversion
- Long tubes and x pipe coming soon
- K member captured nuts in frame rails
- Where can I find this part of the harness to convert back to OEM TB?
- 01 4.8 alternator wiring diagram
- under drive
- LS1 Overheating.. Bad Tstat?
- double check pcv routing modified lq4
- Need a bit more power
- Need to Relocate IAT - but need a new IAT
- FAST 102 Stock LS1
- Gen 3 ENG, Gen 4 Harness
- catch can
- How to install Dorman Ls2 intake.
- What gains to expect going from old Fast intake to Fast 102mm LSXR
- 2 hose questions
- Vacuum port size on a Nick Williams 102 TB?
- Car started screeching very loud HELP PLEASE.
- Lq9 harmonic balaner advice
- Which codes pop up when you delete egr and air?
- FTP98MM lid to 00WS6???
- Anybody run Spintech Pro Street 6000s in True Duals?
- Need O2 Sensors For Catted Y-Pipe
- Vacuum leak coming from???
- oil leak culprit?
- 2" header fit oem k-member?
- Ls to bbc water pump adaptor
- Hissing sound 1998 Trans Am
- Injector tick/knock (vid inside) yes injectors can knock!
- maf questions
- Lets talk spark plug wires
- resonator on turbo C5???
- Swapping from LS1 to LS6 intake & FAST 102 later. Recommended Steam tube kit?
- throttle body coolant lines
- A/C Line Repair
- Tsp y pipe supports
- 1997 C5 Dip Stick
- Question/Help W/Exhaust Upgrade WITH Center Mount Exhaust
- ls6 vs ls2 coolant crossover
- TSP catted Y - rich smell
- LS1 stock alt & starter wiring size?
- Intake manifold for 2500hd truck
- Texas Speed Y pipe question...
- best way to clean an LS6 intake
- Need Help. Oil filter adapter question
- Complete noob needs help with pushrod length
- Fast 102 with Holley fuel rails
- Dual gauge dash cluster bezzel
- Switching 241 heads to 5.3's. Headers?
- Smoke on Deceleration
- Belt part number needed help please
- Total upgrade cost LSXR102 vs MSD Airforce 102
- another ?, intake removal
- LS6 intake upgrade Ac Delco?
- Looking for tick perf. batt. relocation instructions?
- LS1 intake
- Got my HioSSilver ported MSD!
- NW 92 Fitment on FAST 102
- thinking Holley hi rise interested in hood clearance
- best dry flow air filter?
- Ls1 engine harness
- Throttle Cable Bracket
- Switched power block?
- How to NOT mount a wideband sensor
- Exhaust set up advice
- LS1 to LS6 Valley cover swap question
- Headers 241 heads vs 243
- Where can I find this part?
- Bolt sizes and a few other questions..
- Flowmaster Scavenger Headers
- Oil pan replacement, 2001 Camaro ss
- Which ATI damper for truck accessories
- cut outs
