- Are cutouts really helping you. Look inside.
- Updated release date for the LSX intake anyone?
- would a loose crank pulley cause a oil leak?
- Gains from cutout
- Dynomouth vs. Magnamouth
- Stock throttle body differences? TCS vs Non
- Stepped Headers?
- New Nitrous Gmaf
- noise after header install
- Magnaflow vs. Loudmouth
- Glue or replace a cracked lid?
- Taylor Thundervolt wires or "409" Race Wires?
- LM-What type of headers?
- Has anyone else installed their own ASP's.
- Intake Question... help!
- X w/ true dual out the back?
- What mufflers with a true dual system?
- X Pipe With Catback?
- Finally it looks like pacesetter straitened out my order questions about install.
- Short belt with ASP pullies?
- what exactly does the ASP crank pulley DO?
- Plug Wires
- cutout/openheader
- Maf
- want loudest or else!
- Christmas...
- Any tips for Mac install?
- Pacesetter install, what is myth, and what is true?
- AIR tubes coming off Headers
- Bauer TB picks up 11 RWHP on the dyno(Stock car)...
- how do i 'key' the crank pully
- Any other Cat Y pipe work with pacesetters ??
- exhaust I pipe
- F.A.S.T. Alternatives?
- ASP pulley causing KR
- spark plugs & wires????
- Stripped Header bolts.
- will a dented cat rob me of HP??
- headers with or without cut out sound clips??
- Oil Pan
- It's almost Xmas time and.....
- Anyone with Extrude honed cast iron exhaust manifolds on their car?
- Anyone ever Extrude hone stock cast iron manifolds?
- Anyone ever used magnaflow exhaust
- What O2 Sensor Part Number or Application fits Long Tube Headers (Like a tahoe etc..)
- SLP's new pulley??
- pulley install question
- Engine Block heater
- Kooks! QTP! or TTS
- SLP Y-Pipe universal?
- What size hose?
- How do I keep the crank from moving?
- under drive pullies
- cut/grind K member with header on the car?
- Should I switch setups?? details inside...
- Pacesetter Headers good or bad???
- Free Ram air is sucking up water and mud
- installing headers then reinstalling stock manifolds?
- how loud is stock exhaust with no cats?
- duel pipe size
- what to do with air tube after header install
- Are cutout's without headers worth it ?
- asp pulley insatll HELP!
- FLP's 2.5" Offroad Pipes
- Corsa Or Loudmouth?
- Dyno results
- Y pipe idea!!!
- Under drive pulley
- pacesetter header ordeal pt2
- Modified Loud Mouth exhaust
- BradWS6' dual exhaust pics (x-pipe)
- Exhaust Leak!???!?!?!
- Anyone compare SLP LT's with Hookers
- best exaust for catless header set up
- Some q's about pacesetters before I install.
- POssible to pass emissions without EGR or AIR
- How low do the pacesetters hang?
- Turn fans on at what temp, with no thermostat??
- Experts come inside. Need help!
- Should I got to stepped Kooks?
- question about wisper lid.
- fast intake question
- LS6 Intake Manifold
- LT's or restall, pulleys, and tires
- pacesetters and best fitting Y?
- After header install
- anyone know how long mac primaries are
- Cooling System
- custom ypipe dumped before the axle vs duals dumped as well
- Need to quiet the car down.. Help me pick a catback
- some good pics of my true duals with dynomax ultraflo mufflers
- How could i free up the restrictiveness of a catback to unleash power?
- Has anyone tried the Holly Ls1/ls6 intake?
- It's cold in here...
- Size and pitch of water pump bolt?
- my homemade true duals
- Removed air pump now vent controls not working
- cut-out question
- Whats up with this, coolant leaking...
- TTS longtubes vs. MAC midlengths
- Need Help
- Whats The Best Exhaust Set Up For An O2 Ws6?
- Trying to make dynomouth...
- MIG & Lathe Ported TB
- A little warning about QTP cuttouts...
- Kooks Ypipe
- What kind of gains do you think I will see?
- Has anyone done this?
- Mass airflow sensors?
- 2 Cutouts or 1 Cutout, yes AGAIN!!!
- what does a dual/dual ...
- What O/R Y will fit with Pacesetter LT's?
- MAF ends for an auto?
- Guys w/ LT's and LM with and w/o bullet, help!
- spark plugs or not?
- help on y-pipe choice please??!!
- Installing Autometer shift lite
- Fernco installed
- Dont Be An Idiot Like Me When Doing Headers!!!!!
- Removing emissions crap ...
- Pacesetter headers for 253.00
- SLP SFC's with LT's
- Are front O2s and rear O2s compatable?
- Interesting review of about 15 mufflers
- Going to do LT's, need a tap and specs please!
- Battery relocation questions
- Questions about cats and ORY's...
- Help? running rich
- Dual electric cutouts- good or bad? Quiet but unrestricive?
- Can't find "how to bore tb" tech article
- With these upgrades, do you think there will be a difference?
- Anybody tried this?(pic)
- Headers In Cali?
- Any "quick" MODs I need to do before dyno tune?
- Just got the DUALS put on
- Results of Header LT research....
- Just installed Bauer Racing Ported TB
- Underdrive pulleys
- ORPs????
- Mecham catback.....
- pacesetters installed
- Whats that smell
- Quick question for LS1 Motorsport Air Lid owners!
- FTRA is the real deal yall.
- how to remove baffles in WS6 hood? Any gains proven?
- Headers and plugs
- Jet Hot header/Hooker pipe have questions
- Need new lid, is the TSP still getting.........
- LT's and burning voolant?
- dynomax bullets vs. round
- Part number for ASP belt ???
- Got one for ya!
- home ported my TB i have a few ?'s now
- What heads with TTS headers?
- Arcing iginition wires
- Run In With Exhaust Police
- KR issue with pulleys? pulley ? too
- exhaust set up question
- Slp Or Hooker??
- Weird Voltage Problem
- Should I see gains this high from LM? I am scared!
- need to know how
- Who has the un-coated Pacesetters?
- Anyone have Harlan shiftlight directions laying around?
- ported/polished/powerder coated throttle body ?'s
- You need to respond to your post...
- Swivel water neck for LS1?
- y pipe vs. true duals with dumps
- WHat is the best header on the market?
- Mac Mid Lenght's Off Road Y And Slp Loud Mouth.
- Anybody with a pic of the Hooker 3" Y pipe?
- BackPressure Question Help
- header question
- Dumb question about coolant
- SES light after SLP header install
- Running a straight-pipe through a cat so the man.....................................
- Flowmaster versus Vortex?
- exhaust ideas
- have SES light...exhaust leak?...have questions.....
- detonation and engine damage?
- shortie and true dual
- price of install
- SLP's high-performance 85mm mass-air-flow sensor??
- head flow question
- 6-cfm x-tra in head flows
- PPC or FLP???
- Question about removing my cats...........
- Spintech Pro-Street in place of LM Resonator?
- gap on plugs
- SEMA 2003 Photos - New LS1 products!
- QTP Headers installed
- Short belt part number?
- Help! 98 Corvette stumbles under load <1500 RPM
- How to hook up at tach?
- HELP!!! Which longtube headers tuck up under the car the best??
- Kool Blue or K&N??
- LS6 intake??? pn 12561184??
- should i get holly powershot?
- Is anyone using a FIPK W/a SLP RA scoop?
- BBK has a new alum intake manifold displayed at SEMA
- what intake is best?
- i changed my plugs and now im running rich, normal?
- Has anyone tried LS1Speeds dual
- TB Bypass |TRouble
- Help with checking exhaust leak
- Is a set of cut out's worth installing on a 2001 SS
- Some interesting dynos/facts about headers
- Best Catback for WS.6
- Confused about my headers
- Does the CME change
- Duals and DS loops. anyone doing this?
- best plugs and wires?
- gmmg muffler size
- Deciding which header....help me, please!!!
- LS6 intake making car hesitate
- new edelbrock ls1 intake
- Magnaflow Exhaust Questions
- True Duals, What kinda mufflers ?
- Anyone have the part number
- WTF!!! High irregular idle!!!
- A nice surprise , if your looking for a replacement y-pipe .........
- NEW header swap Q..(i think its new)
- FLP Headers
- Hooker black LT headers
- durability of elec. cutout?
- slp headers?
- What the heck type pipe do i have, X,I,or Y?
- porting a weiand intake
- Im a little pissed about my pacesetters
- Fan Settings
- PPC headers worth the money?
- NEone have pics of SLP LT's underneath car?
- HELP!!! AIR removal
- Hey im new to this whole LS1 thing
- B+B Triflow exhaust tips...
- VERY annoying sqeek, no idea what it is!
- pacesetter questions....
- y-pipe for stock manifolds and cats?
- durability of the cutout
- exhaust 101
- Pic of true duals on my car with Dynomax ultraflo mufflers
- Slp Headers... Facts
- FLP Headers and True Duals
- MAC midlengths, i have a few questions
- write up for plug in fan mod.
- Header Options to Meet Calif Smog
- Dyno #s for Headers
- Will a 98/99 TB work ?
- Jet Hot Dyno Numbers!
