PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 [197] 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. knocking noise?
  2. stupid exhaust!!!
  3. **Bullet compared to Catted Y**
  4. if YOU fabbed up YOUR OWN true duals...
  5. Ignition Coil
  6. Hooker Exhaust Users
  7. LSX 90mm TB Flange for Sheetmetal Intake
  8. port and polish MAF?
  9. vid of new duals
  10. Loud belt... good replacement?
  11. PCV Venting to Catch Can
  12. Header ?????
  13. Jet Hot Long Tube Headers
  14. Need help with Bassani y-pipe setup (w/cats)
  15. Looking For Exhaust Tips
  16. which manual fan switch, SLP or Caspers?
  17. Cam or Chip . . or both
  18. Cutout setup to loud?
  19. SLP Loudmouth on c5, SOUNDS ??!?!?!
  20. Where to find Injector 0-ring & retainer
  21. Quiet down damn it !
  22. Preventing Rust when Welding Exhaust components???
  23. TB whistling
  24. underdrive pulley question
  25. EGR pipes
  26. o2 extentions!
  27. FAST 78 or 90 Setup for me?
  28. TR6 spark plugs
  29. Porting TB in ILLINOIS
  30. Magnaflow Exhaust Tips
  31. time for duals
  32. ses light after installing headers and o2 sims
  33. a/c tensioner crooked??
  34. still missing
  35. slp pulley?
  36. Help with ls6 swap
  37. LS6 Manifold question (need some opinions and facts)
  38. My Paceheaders and Tsp offroad y-pipe came in today
  39. What Size Is The In And Out Ofmy
  40. Port a BBK TB???
  41. BBK intake help
  42. Cutout question
  43. LS1 underdrive balanacer
  44. Porting and Polishing TB!!!
  45. Help me identify whether this is a SLP/ Dual Dual
  46. anyone besides mufflex make a single exit?
  47. Power steering pump puking fluid
  48. 3 inch true duals
  49. Howto: Quite exhaust to pass inspection?
  50. SLP powerflow
  51. Difference between LS1 & LT1 Magnaflow Catback???
  52. Pacesetters with TSP Catted-Y Pipe?
  53. Damn popo ruin everything
  54. Dynatech Supermax Headers??
  55. Getting LT's...what else do I need??
  56. can it be done? anyone?
  57. Just bought a 99 Z28, What mods?
  58. want to paint my I-pipe...what temp paint do I need?
  59. whats the best exhaust?
  60. Anyone ever tried this? (ctusom TDs)
  61. Shorty gains over stock??
  62. Which fuse?
  63. older qtp collector ?
  64. 160 degree thermo for a 02 z
  65. help please...exhaust question
  66. slack in the throttle cable?
  67. Air conditioning questions
  68. cat bac for 02 z28, what kind and
  69. What the heck is this part?
  70. Removed EGR&AIR Emissons and my exaust got deeper
  71. Oxygen sensors
  72. couple questions
  73. anything else for UD pulley
  74. power steering pump pulley removal ???
  75. Is this a good $60 find?
  76. best new induction setup on my SS???
  77. plug for IAT hole?
  78. LS1 crank sensor type?
  79. thinking of getting duals run out the back
  80. Routing O2 sensor wire?
  81. Swap back to stock exhaust - Help
  82. Best way to access header bolts...
  83. thermostat question
  84. LS2 TB issue
  85. Most HP IN CATBACK
  86. just installed headers and i hear a tapping sound
  87. maf question
  88. Ram air question
  89. Block off plate for EGR?
  90. LS1 harmonic balancer part #; Parts CD?
  91. removing power steering pump pulley?
  92. Just got back from the dyno w/ bolt-ons.
  93. Camaro LS1 Mid-Tube Exhaust Headers
  94. side exhaust
  95. Using just coolant plugs?
  96. coils
  97. Finally....got my Kooks LT's and Y on.
  98. Belt issues
  99. How does Thunder Racing's Ported TB compare to New Era's TB?
  100. ChrisToys Custom Ram Air!?
  101. got rid of flowmaster and got magnaflow...
  102. I anyone running a Pypes Cat-back?
  103. Need Little Help w/ 160 stat
  104. QTP header owners!Help advice needed.
  105. Well I'm screwed, thanks March
  106. Resonator replacement length?
  107. LS1 headers&y-pipe? problems
  108. power steering pump?
  109. Exhaust for C5 with a 402? 3" or 2.5"?
  110. Anybody make a MAF Extensions
  111. After Fast 90 install A/C doesnt work!!Help Me!!
  112. How to hook up sensors and vacuum line to vic jr intake
  113. Running Hotter Than Before after intake swap
  114. Will it ...
  115. Look what I got!!
  116. Best place for flowmaster?
  117. Headers And ORY
  118. need help
  119. TB and MAF question
  120. intake swap
  121. Help me decide. QTP or Kooks.
  122. Ported TB intall question
  123. question on my exhaust
  124. FAST Intake manifold and 90mm NW TB or just keep stock ported TB?
  125. Intake setup
  126. XS LT Headers Came In! *PICS*
  127. Something looks off???
  128. Motor mounts when doing headers...
  129. Synergy All in One product line....
  130. Anyone shaved their stock valve covers?
  131. dipstick tube
  132. sweet thunder exhaust
  133. lost one of the boys today
  134. Need help on EGR bypass
  135. QTP stainless steel cut-out
  136. dumpin slp loud mouth
  137. Cut-out size
  138. Probably a stupid question...NW tb on a LS6?
  139. what is the cause of a Vacuum leak?
  140. Are Headers A Good Idea?
  141. painted headers smoking after install?
  142. Opinions on valve covers please.
  143. How much power are ported TBs worth?
  144. white plug?
  145. Corvette AC pulley and tensioner?
  146. Loud Whining On Warm Start
  147. True duals idea, tell me what you think
  148. exhaust leak question
  149. shorter dipstick?
  150. traction control question?
  151. True Dual Questions
  152. Broken Super Sucker Ram Air??
  153. camaro tips (or lack thereof)
  154. Good shop that installs and tunes headers
  155. header clearance on ls1 blazer
  156. traction control stays off
  157. What lid fits an 85mm MAF and 90/90 setup well?
  158. What part is this?
  159. Motor mounts = pain in the butt IF
  160. Cats 02 Ls1 On A Lt1
  161. Best price on SLP LoudMouth
  162. underdrive pulley ???
  163. Gauging interest TB group buy
  164. MAP sensor problem
  165. Need Header Advice
  166. New 3" TD's Under axle with Powersticks Pics and Video inside!
  167. TB, MAF and Bellows worth it??
  168. Need Help Asap....
  169. Flowmaster Drone??
  170. Drilling into steering column??
  171. True Duals vs X Pipe
  172. cut out with no exhaust
  173. do STB's fit over the FAST 90's???
  174. need help with my lid/bellow selection
  175. Jet Hot Y-Pipe
  176. Call Out To Oxidizr! (MagnaFlow Metallic-Cats)
  177. cats or no cats?
  178. cutout location
  179. cats
  180. Bullet mufflers/resonaters
  181. worth the price?
  182. install
  183. Best cheap set of long tubes for LS1?
  184. ls6 intake???
  185. Retarded Catch Can Question
  186. Oil filler tube...
  187. O2 Sensor Bungs?
  188. Shorties or Longtubes?
  189. Im lookin for a cat back true dual exhaust
  190. sweet thunder with y pipe...
  191. Part # question
  192. Ls6 intake on and now noise?
  193. throwing a misfire code. help me determine the problem
  194. did any of u find ??!
  195. lumina ss headers
  196. Ls1 headers fit different years?!?
  197. Those with Flowmaster 1-chamber true dual set-ups, have questions about fitment...
  198. Are SLP LTs Really Crap?
  199. no supercharger, now what
  200. XS Super Competition Headers(Stainless steel)
  201. best y-pipe with QTP LTs
  202. TSP TD, Sound is awesome but, now its gone, please read
  203. Anyone know which Magnaflow muffler will fit my dual/dual
  204. good ignition for a 402?
  205. Which catch can?
  206. HELP!! cutout ?s
  207. Corsa vs. Magnaflow
  208. flowmaster merge collector?
  209. Flowmaster
  210. Water Pump leaking
  211. what is gc oil? What does it stand for?
  212. Intake options?
  213. eXHAUST CUT-OUT
  214. removing 02 sensors easier when exhaust is hot or cold?
  215. ported LS2 intake questions
  216. Options for different mufflers only...
  217. Puff of Black Smoke?????????
  218. AC belt on LS6/7?
  219. slp vs. k & n
  220. Descreen MAF??
  221. I take back everything bad i said about QTP...
  222. Ignition coil connector
  223. Typhoon Intakes
  224. How to contact Shaner for ported TB?
  225. hp
  226. SLP Air filter clasp
  227. Emissions question??
  228. Tach problem
  229. Egr Hole
  230. how much power loss with flowmaster...
  231. intakes and throttle bodies
  232. Intermittent skip
  233. Anyone seal Airbox to hood & !belllows?
  234. problem with car after installing ls6 intake and fuel pump
  235. ATI damper. 10% underdrive or stock?
  236. quick stupid question
  237. ground kit
  238. Best Headers for gains besides kooks and QTP
  239. ses lightbuld went out
  240. Stainless steel
  241. Cats vs drone
  242. about to get headers...cats or no cats??
  243. Alternator U/D Pulley
  244. cold air intake worth it...
  245. Magnamouth Muffler
  246. what headers to get?
  247. e3 or brisk performance plugs
  248. Headers under the axel?
  249. Which Headers Jet Hot,Hookers,QTP???
  250. XS Headers air pipes removed
