View Full Version : Generation III External Engine
- Raven Exhaust
- Jet Hot Warranty Question
- Keyless Entry Problem
- Bought used electric cutout, need assistance with the toggle
- When Cold, engine sputters ...
- What Catalytic Converter Does Kooks Use?
- SES Light + High Fans on Full Time = ???
- Spark Plugs
- Gains from ported LS6 intake?
- Pacesetter LT / TSP ORY install
- TB question
- hooker or flowmaster
- Dual cutouts vs. single cutout on OFY
- Mac header mod pics please??
- Just finished my exhaust setup and I am very happy
- cut out?
- Shaner S3 Rocks!!!
- Anyone with Dyntech headers...opinions?
- Who has gone Cat-Less with the exhaust?
- Kooks/GMMG or Hooker/Magnaflow
- Issues with QTP catted Y and SLP SFC's?
- post true dual pics
- Throttle Bodies by years?
- Gasket for FAST....GM, FAST, or Felpro?
- N/A high 10s-low 11s plug gap?
- Stock gasket with new slp headers?
- borla or loudmouth
- Loudmouth hiss?
- wtf is this?!?! do i need it?! help!
- FLP V clamps
- Oil Pan Questions
- WOT Issues
- pacesetter install Q's
- dynomouth w/ carsound cats??
- SLP 85mm MAF caution
- Know Of An Out Of Sight Catch Can?
- Idle problem after plug change, Drives great though.
- Tax money mods:)
- Whats Louder
- QTP Stainless Cutouts
- add 2 mufflers to a rumbler/LM?
- LS1 Air Pump and EGR valve
- why ory or cats?
- Stock LS1 Intake's
- Hooker Headers Blocked off plates
- anyone have LS6 MAF w/ 75mm lid
- Shop installation question
- Race headers
- Restricted Intake Motorsport Conundrum...
- Cut-out cap blow off! Where can I get another one???
- Mac Y-pipe Prob!!!
- Supercharger Sound From Air Lid
- FLP headers and cats/ TSP's x-pipe
- cut out
- Exhaust Leak!
- dumb question: port exhaust manifold?
- Full exhaust at home
- Stainless bolt kits junk or not?
- Gates Belts
- getting ready to weld on the new exhaust!
- SLP Exhaust Question
- Sound clip of my duals
- Qtec electric cut outs
- ahhhh! help me with this rattle!
- First drive: Fast 90/90 - Hmm.
- Cats for my ory???
- FLP headers to True Duals
- ASP UD Pulley Question
- Corvette exhaust on a Camaro.... can it work?
- QTPs Installed
- going to install long tubes need a bit of advice
- Stupid Question , but I got to know
- What do I need with headers?
- Weight reduction?
- electric cutout wiring - accessible power?
- Video / sound of under axle true duals
- Spark Plug Wires and Plugs
- need help ...
- Will Autolite 403s even fit into an LS1?
- o2 sensors
- how to make ls6 intake work on 99 SS
- beware of knock off headers
- Y-pipe fabbing...few ???'s
- QTP's and KOOKS
- My true duals sound clips...
- will ORY vibration through rubber hanger cause KR?
- Smell from ORY
- What I need?
- Taking my A/C out
- where to go??
- Catch can
- GMMG.....Change in sound
- What to do? In a bit of a bind..
- HELP! Hooker LT post-install- BAD MISSFIRING, 02 codes, no power, running pig rich!!
- BBK Intake
- LSx intake on my '99 (what do I need?)..?
- Porting tips for FAST 90 runners?
- Headers for lowered cars.
- thinking about changing my exhaust...yet again
- Magnaflow carsound cats? are they any good?
- Best Ignition wire...Taylor 10.4mm 409?
- Who put cats back on their exhaust??
- Flopro Twister Sound Clip?
- 4 inch exhaust?
- FAST 90 and cam sensor problem
- Y-pipe and Borla V's X-Pipe and True Duals
- rear 02s on catted y pipe
- Is the ASP pulley balanced?
- 4 inch intermediate pipe to a 4 inch cutout.
- Question about headers and transmission
- air/fuel question???? need help
- Jet Hot Headers
- LS6 Intake Swap causes oil Consumption
- Anything I should know about before I take apart LSX 90mm Manifold to paint?
- QTP headers
- slp passanger side header intall question
- pacesetter lt's?...
- Question about removing AIR system???
- Ls1 Intake Manifold
- SLP LoudMouth II
- Have GMMG, thinking of Corsa.....
- 11's in SoCal?
- Denso It16 Vs Tr-55?
- LS2 Coils on a LS1?
- Z06 Intake:
- Stock manifold gaskets...
- putin in headers need help
- Loudmouth, Rumbler Decibel Levels
- ASC reversal module problem....
- strange occurance
- Newbie LS1 mods ?s
- 2 questions regarding headers for 2000 ss
- 2 step help
- What Plugs/wires T-rex Cam
- header help
- exhaust?
- who still has their AC system?
- Maf?
- question on LS6 intake swap
- this might be dumb question, but
- any other restrictions i need to consider?
- Who has lt headers and your aftermarket plug boot rests against a header tube?
- Need a Ypipe
- Need Radiator P/N Help Please
- 99 throttle cam in 01 TB, TPS voltage ?
- QTP Headers,ORY,GMMG With Borla XR1 sounds GREAT
- Gains With 90 LSX & TB Stock MAF & Lid
- RPM Jumps
- Exhaust too loud
- Ported Throttle Body Issue
- QTP Y with jethot's longtubes? DID NOT FIT!
- Radiators
- LT headers-Y pipe
- Ported TB
- Maf????
- TSP True duals and Dynatech headers??
- Header Flanges
- Using catch can or converting to LS6 pcv
- Little Help
- Help: torque specs for header bolts ?
- Which Is The Best Option??
- Throwing SES light with Jet Hot LTs and Cat Y pipe?
- true duals DREAM setup
- Personal Best After S3
- Muffler question
- Kooks Headers
- TSP True Duals
- Does anyone know anything about this sound clip?
- Ok help me out here.. Rumbler vs LM in the sound department
- 78 or 90mm LSX
- spin tech exhaust
- Lt's or Mac mid lengths?
- Spark Plugs
- THE COMPLETE VIDEO/SOUND 4 clip :idle,revs inboard,music from the outside,cruise in 6
- VIDEO + SOUND Revs from the inside & idlefrom my Z06 after mods & tune
- which muffler to put in i pipe to kill rasp???
- VIDEO CLIP OF MY 2002 Z06 406rwhp @ idle after mods and tuning
- valve cover part number
- PS high pressure bolt wont come out
- header ?
- Rear end or headers?
- QTP Y pipe
- Vacuum Pump Bracket
- Intake Manifold Gasket ?'s
- Does anyone here have a Stainless Works exhaust ?
- muffler
- Vararam Air vs WS6 Ram Air
- K&N, Donalson radiator support?
- what exhaust?
- Anyone try any of these?????
- is a ls2 intake worth it
- LT's, Offroad Y, SLP Dual/Dual??
- Can a Tune Wait
- True Duals out the back question.
- power steering blew, need advice
- Does a LS6 Intake Package come with a new MAP sensor???
- Buying headers...should i divulge in 7/8kooks?
- What size guages do you guys use?
- edelbrock headers and Y pipe
- Well, I'm about to order Magnaflow
- UD Pulleys other than ASP
- What diameter is the I pipe?
- Stainless Headers
- other electric cutouts?
- Those with TSP ORY
- which is quieter? 18 in. bullet, 12 in. borla xr1??
- Thinking about true duals
- getting tach signal
- is there a oil filter i can change every 5k?
- will a borla exhaust from a 95 lt1 fit my 02 ls1? please help
- More exhaust Q's
- Hooker Y-pipe question
- Thermostat - does 170-175deg exist?
- Anyone install a LS1 Canton Oil Pan?
- Bad Knock Sensors??
- Exhaust opinions
- How bout a $70 electric WP?
- LT1/LS1 exhaust interchangability
- 1 3/4" QTP HVM LT's, Dual Elec ORY, SLP 20TL Pics
- Poly motor mounts??
- Anybody else need longer studs on cutout?
- Important Info needed....
- Custom y-pipe?
- B&M transcooler leaking???
- Anyone run into complications while installing the Accurate Machine Works catch can?
- need some input
- TSP Rumbler Help!
- whatchoo think
- Homemade volant intake
- Where to buy oil temp sending unit?
- FAST intake & TB question?
- Hp gains on 2002 Z06
- Iac
- Funny Noise
- LS6 IM swap
- new exhaust, pics!
- upper radiator hose w/o cooler ?
- FLP lts,y,cats,Loudmouth changing to Magnaflow..keep cats?
- qtp headers
- for all those: who were considering a bullet muffler on the end of there y, some info
- Borlamouth Ideas, Looking for Input
- Weind/Lingen. manifold bolts and gaskets???
- magnaflo catted y vs ory
- Mac catted Y question
- ? best headers for 99 ls1 z28
- homemade hangers
- Orderd Pacesetter Coated LT'S
- What headers and Catted-Y to pass emissions
- radiator
- How hard would this true dual system be to fix? (pics)
