View Full Version : Generation III Internal Engine
- GM CNC LS-6 Head failure
- Did not cut block for LS6 valley cover install
- P0506 thrown code and power loss
- Did 3-2 misshift, now have ticking, but not p-rods
- another LS6 cam question
- Almost ready to start my car! just some questions.
- Cam?
- Yella Terra rocker arm install howto done
- help, problems with cam swap
- Tell me what you think about this cam???
- Flow #'s for stage two heads?
- 230/238 cam What Do ya Think?
- Valve seals
- Futral Motorsports 347 solid roller is in!!!!!!!!!
- how to remove crank timing sprocket?
- Starter wiring need help....
- Oil pump question
- How clean do you get your block before..........
- Rough guestimates on removing engine?
- Best quality and price for a cam?
- LS2 and LS7 discussions
- Crap in Exhaust!
- Cam upgrade or LS6 intake?
- Cartek Stage II, G5x2 A4 dyno results
- Installing engine....with or without headers?
- Has anyone tried these yet?????
- final checks before install.....
- Oil Leaks on New Motor Need Help?
- TR 230/224 cam
- whats this cam worth (hp wise)
- Anyone using Patriot Performance Heads?
- What 6.0 heads are on the Hummer?
- What do you think of my compression test?
- I need opinions on choosing a cam!
- Degree the cam
- Dyno tuning at ARE on wed. My cam will peak at???
- Help!! What is this strange noise??
- New Engine Help Please...
- dilemma Any Suggestions?
- bent pushrods and slight knocking after N vs. S...
- GM Hot Cam Question
- Ticking noise after head install
- LS1 Connecting Rod Length
- AC Recharge.....How much Refrig.???
- Is anyone using this cam yet?
- Z MAX additive BITES the dust
- What ya'll think of this cam grind?
- Yella Terra's - Couple of questions on install...
- Oil gets darker = Car running rich?
- Cam install, how long????
- Something broke?
- Which cam is for me
- Grenaded motor at shootout
- What's better lpe cnc ls6 heads vs. gtp, cartek,
- New Cam, New dyno results
- Which cam for blown LS1?
- 918 shims
- Abs. Speed S2s with TR224 cam
- Need Felpro Head gasket ASAP
- G5X-2 Through True Duals [videos]
- are the head bolts only 10mm?
- cam spec comments
- Which gears for TR224 112, 6sp?
- What's this???
- How much to make it a 427
- 98' ta parting out
- Installing cam tomorrow..advance retard straight..
- how much for 11.1 CR.....
- Pistons
- Any advice for removing carbon buildup on pistons?
- 1st Post...question about ASA and Hotcam...
- Educate me about Camshafts
- TEA heads pull 435hp
- opnions on ported tb and maf
- ASA Cam
- just another heads question.
- Changing Valve Springs
- Like to try new things? Look inside!
- 224 vs X1 Cam
- GTP - piglet cam??
- Figuring out pushrod length ?
- is this too much cam for me
- What to do before starting a brand new motor?
- LS6 valley cover - anyone releive cut the cover
- Hotrockers w/variable lift
- Does the ls1 oil pump have to be primed? how?
- Expert please read ...Is this LS1 worth $5000
- Oil Pressure issues with new engine...
- Yella Terra's are installed
- MTI C2 cam inside
- timing chain slack???
- How to fly cut the pistons ?
- 382 w/ MMS 229 v2.1 cam?
- Dyno numbers you won't believe!!
- ARP Head Studs - enough room to pull heads in car
- Easy way to install lifters...
- anyone here put an ls6 in a camaro?
- Got before and after dyno graphs of your cam?
- HEY! Why can't we...
- Head milling and Pushrod length
- cams
- ARP HEADS BOLTS VS STOCK
- Installing cam next week need one last....
- Will Yella Terras reduce my P/V by more than .005?
- Where is the oil coming from rings or valve seals
- How much timing are you guys running with the G5X-
- Anyone running the scoggin dickey springs/retainer
- Hotcam vs. 02 LS6 cam
- Stock cam numbers and other questions
- anyone runnning a 224/224 .581 114 lsa w3500 stall
- Just installed a Z06 cam in my 02 SS!!
- Clay checking piston to valve
- Need Opinions On Adding LS6 Heads To This Combo
- problems after cam install-MAP codes, and cyl #1-
- SDPC single spring and titanium retainers?
- Holes in pistons, cracked rings...................
- Recieved TR 230 today
- my TEA flow numbers and
- Cam question?
- spark plug position....?........read>>>>>>>>>
- arp head and head studs?
- Daily driver/road race cam grind on a 114 LSA...
- Darton Sleeves
- Who here is running a Futral cam??
- Piston to Bore Clearance(Reckless)?
- bent pushrod??
- R1 cam for heads/cam car?
- where to get LS6 valley cover for cheap?
- Casting number for my heads?
- What Race Fuel should I use?
- how much can stock rods with good bolts handle?
- Gas mileage??
- Solid Roller Guys please chime in!!!
- Installing my rockers tomorrow need help
- Anyone use Crane ( 99846)valve springs?
- Got My RMS SII 5.3 heads today!
- Rev 1116 Valve springs
- TR 224 -114 LSA or TR220-114 LSA
- Anyone measure P/V clearance change w Yella Terras
- Rollmaster Question
- Cam or LT headers?
- cam install houston
- piston/valve clearance
- Darton Sleeves
- What eles do I need?
- price on lunati 383
- REV 1116's or Comp 918's?
- cam install
- dimple forward?
- ARP head bolt tq Question
- Opinions: Lunati vs. Comp Cam
- Catch can needed?
- need help please ! !
- 5.3 heads from a '00 gmc, good??
- Best ET cam with LS6 valve springs?
- Royal Purple or Redline, which one??
- cam? for these heads
- 1.8 rockers?
- 6.0 Head Question
- anyone installed the 8.1 vortech yet?
- Head Gasket Question
- What injectors, oil pump, and timing chain..
- cams and tuning
- Which Timing Chain
- Does anybody plan on making a 300cfm intake?
- how much hp do these cams make?
- TEA heads
- 2002 LS6 heads vs Ported LS1 heads? Worth upgradin
- ls6 vs 5.3 heads
- Daily Driver stock verter cam?
- how much hp would stg 2 heads add to my combo?
- Help!!! overheating
- Question about not setting the LS1 to TDC
- re-installing rods/pistons few ?s
- how do you feel about this cam?
- VTEC
- ZO6 Heads and Cam?
- where to ofset grind?
- 427 Stroker... 3 ways to go.
- solid roller vs hydraulic roller...differences?
- Got NE valve spring install tips and trick
- Quick cam advice
- Raughammer's cam info page?
- Biggest cam in an A4???
- Have some cam questions
- Drilling out TB Q's???
- Just wanting to clear up some 6.0l stuff
- How bad would it be to have stage 3 heads on a 346
- TR's "Old Man" cam
- Patman! > Lubrication Engineers ("LE") oil
- Anyone used the Katech valve covers?
- how much horsepower do i need
- How much compression can you run on 93 octane?
- B1 MTI cam to a C2 MTI cam,Any gains?
- Cam install, extended wait, lube ideas.
- camposition sensor?
- Custom Cam Grind off of G5X2...
- Who has an ARE 436ci stroker motor?????????????
- new cam recomendation - up from F1
- Need help with Vibration dampner pull off!!
- help
- Cam Swap... what else do I need?
- lock converter for A4 dyno run?
- Another G5X2 Successfully Installed!
- valve train noise
- How many quarts of oil?
- Who has the most powerful LS1/LS6/C5 Stroker?
- lingenfelter GT2-3 cam or LT?
- Head Install question
- New Engine Pics Before the install... !
- Advancing my cam 4 degree's,Help!!!
- Powerband?
- how to tell the diffrence....
- 5.3 cranks
- break in process???
- LS6 Block
- Tr224 112lsa
- 4 inch stroker crankshaft
- Spohn Solid Motor Mounts?
- G5X-2 Install A Success!!!
- .581 lift and milling heads?
- 405.5 RWHP 385.1 RWTQ
- Gentlemen with MTI C2 cam enter here
- Ordered a 242/242 595 112 Cam
- G5X2 with an auto?
- ? about heads
- didnt know heads had to be machined?
- Micrometer technique when measuring camshaft lobes
- GTP stage 2 flow numbers??
- What do you think this will give me?
- how smooth does your ls1 idle?
- Do I need another PCM?
- Looking for a cam *DELETED*
- Need some advice...snapped a ring..
- Anyone deal with Nasty Performance?
- Burned Motors????? REBUILDABLE????????
- 85mm MAF or MAF ends with stock MAF?
- What's the best cam for a 427 stroker....
- Ran the 1/4 for 1st time with untuned ASA cam
- new comp cams?
- Factory Main Bolts/studs
- Diamond pistons mailing address needed
- Engine stress??? TQ VS RPM????
- TEA 5.3L heads are here, flow #'s inside
- milled 5.3s?
- Diamond Pro select rings....top ring????
- x 1 cam and 5.3 heads milled .030
- Good Replacements for Plastic Pushrod guides ?
- Tourke specs????????
- Anybody have exact dimensions of LS1 block & heads
