View Full Version : Generation III Internal Engine
- Oil pan?
- AES 399 Short Block
- need a crankshaft
- Taking carbon off cylinders without removing them
- My heads and can package shipped off today, I'm excited! (anything recommendations?
- These mods ok? Lookin for approval
- Checking for a collapsed lifter - How? What do look for?
- What direction does the oil port face on ls7 lifters?
- Which ARP head stud kit for 2001 LS6?
- cylinder 5 missfire
- wot smoke
- Lq4 Teardown and swap into 99 T/A
- where to have intake ported?????
- Getting my Heads and Cam Combo this week, need tips on pushrod measuring!
- information on kooks true duals install
- EL Torro vs. TSP 228r
- ticking/knocking sound....need help with diagnosis
- Installing Harmonic Balancer Tool?
- trc vs. mobile 1 oil
- p0120 code please help!
- Machine shop not comfortable line honing mains
- Ported 5.3 heads on a 5.3 motor
- Debating on an overhaul.
- is it possible to change valve springs without air compressor
- Ls1 Tfs 215's Ms4 Cam- Rod Problem. ARP 2000 bolts
- N/A build hows it look so far
- Which cylinder head dowel?
- 228r and torquer v2 rpm range
- Am I going to regret not putting in an oil pump with cam install.
- best harmonic balancer?
- Best place to buy psi 1511's?
- oil pump ???
- Pushrod Length
- What Cyl. heads
- whats the best shortblock?
- sudden oil pressure loss
- LS1 Airboat
- 2001 silverado 5.3 325 lm7
- Stock valve springs ???
- Cold Leakdown Results - what do you think?
- 2011 L9H 6.2 truck cam fit 98 LS1 camaro?
- LS6 intake vs f.a.s.t. 92?
- n20
- PSI 1511 valve springs.
- injector harness adapters
- double roller timing chain
- ls1 knock sensor question
- 383 or 376
- 1/8 mile Vs. 1/4 mile cam?
- Fast intake throttle body question
- need a dyno tuner okc
- 1.8 Ratio Roller Rockers
- Spark plug effects
- 317 head questions?
- Blown Head Gasket
- crank clearances!
- strange s60 for future 550rwhp
- difference between 2010 camaro manifolds and longtube headers
- Anyone else having trouble getting a GMPP Tall Deck block from Scoggin Dickey?
- got my tsp 408 with ls3 top end
- oil pressure?
- 5.3 resleeve to 6.2
- Can i reuse a a gm ls1 mls headgasket? no start
- What's a 02 LS1 shortblock worth???
- New Springs New Seats?
- budget head choice - cnc
- Torquer V2. 112 lsa
- need more cam/valvetrain advise
- tsp 233/239-.595/.603 cam question
- head and cam question
- Parts list for LS9 cam in 4.8?
- single plane ms3 ported heads
- TFS 215 rocker bolt sealant??
- Is this cam bearing toast
- misfire, low oil, and smoking
- 224r on 114+lsa idle clips?
- 799 Heads / Cam ?
- Top End rebuild questions
- ATI Damper - Non-Press fit?
- Trying to ID LS1 blocks
- Cam choice w/ported 799's
- Any 400+ builds with 853's
- What should i do.
- Every LS1/6 OEM piston is made by Mahle?? 99L744"+" why the "+" in 2003????
- Trick flow 225
- Cam question for 228R / T2 owners
- Does This LS1 Sound Healthy?
- Rod bearing?
- Rod bearing?
- 370 6.0 PRC 2.5 5.3 headgasket.....
- bought ARP head bolts.....what are the small bolts for?
- Math Test - Compression Ratios and Compression Testing
- El Toro cam vs torquer v2... Owners post up info
- Am I in trouble?
- lq4 pistons
- LS1 Catch Can
- Car not reving past 5500? valve float?
- Shortblock from Thompson Motorsports....
- Spark knock
- Getting confused and frustrated on where i want my build to go....
- Help with another lq4...
- cam choice
- Wrong size valve retainers/locks?
- Oil pan/Front cover install
- Help with part number for LS6 pistons
- f14 cam
- pac 1518 650 lift or prc 650 dual kit
- 05 5.3 ??
- installing double roller timing chain...what is this piece?
- Visual difference between Ls1/Ls2
- oiling problem ? *Update*
- LT1 to LS1 swap
- 243/799 heads.. Differences???
- 6.0 time for more performance
- Broken valve spring...what to expect?
- Critique My buddy's rebuild
- coolant leaking from back of motor..
- Is there a way to figure out your base circle on your cam?
- can someone double check my pushrod measurements?
- Help deciding on a cam for my 09 G8GT
- Oil pressure vs heat
- Front Main Seal
- Cam??
- Clearancing / spacing the windage tray for 4" stroker
- Cam Thrust Plate - Oring
- So Im checking pushrod length on TFS milled heads.. Questions.
- Rebuilding ls1
- About to seal the purchase on PRC stage 2.5 heads and cam combo, need recommendations
- Big thanks to Tony Mamo! (wife not so happy about living room!)
- heads vs cam
- TFS 215s PTV Clearance FWIW!!
- Valve Spring advice
- Stroked LS1 VS 416 LS3
- Top End Input for my 408
- 03 Z06 P0336 on stock engine after short drive
- gain swap 317 to 241?
- ? About cam
- pushrod question
- exhaust on 98 camaro
- Building 408 or 416???
- Ls1 cutting out, valve spring-lifters?
- is this going to be a good cam
- Valvetrain knocking
- Corvette z06 problem.....
- Looking for the best heads/cam combo to run 10's
- Need help choosing heads
- LM4 Head Bolts
- are all 706 heads made by Castec?
- 6.0 turbo build help and ?
- Basic 5.3 rebuild questions.
- Quickest/easiest most effecient way to gain a solid 40-60 rwhp? No nitrous..
- LQ4 build help
- Problem, motor was removed, reinstalled and starter problem???
- 400rwhp power goal... need heads?
- Head Gasket thickness.....
- what would be a good cam for my 01 z28
- Main stud and main bolt question
- Cam me
- No oil pressure......
- Sleeper 1/4 mile cam for my setup?
- Machine shop
- ? on my LQ4 build.
- 2004 5.3 need a cam ???
- Help me pick a cam.
- lq4 build questions
- Pining a Eagle crank.....
- UpGrading Stock Rods That Have Forged Pistons Already Hung On Them?
- how does this grind sound
- .086" Preload too much??
- 421 pulling truck build
- trex idle and rev
- 1999 LS1 with a miss
- Lunati springs?
- 224r cam 35^ hp?, Sound stockish on 114 lsa?
- Pistons for 3.925 bore
- 02 LS1 in 69 C-10 Horrible Misfire HELP!!
- Anyone know who grinds this cam?
- Any Suggestions?
- Please help me pick a cam
- 2004 Thermostat Housing Fits 1998?
- Where to buy bushed rocker arms
- 5.3 alum. Block & iron block ???
- Is my block destined for the scrap heap?
- Valve spring Identification Help
- Please help calculate my 427's compression ratio
- New LS1 Shortblock vs OEM block
- 5.3 Heads on 6.0 LQ4??? Should I
- Budget build 02 z28
- Vengeance VRX-4 Cam Kit in 2002 Camaro SS! Pics/Vids/Details INSIDE!!
- LS1 in 1959 El Camino
- ls1 camaro runs hot then cools down
- Piston removal..........
- Porting the Fast 102 intake?
- Caddy Racing Lifters
- stroker kit?
- new engine?
- Which cam is best for nitrous
- New lifters, rocker arms and pushrods needed?
- 03 Z06 lost oil pressure / missing
- At a crossroad
- Couple 5.3 questions
- Piston Decision Help
- Ticking after lq swap and cam.
- PAC or ls2 valve springs?
- Another tap
- One mod just creates another mod needed
- 4.8-5.3 heads
- Auburn gear differential Installation
- 6.0 cam in 5.3
- 228r questions
- Reminder: Don't use a truck pan in a mustang swap
- installation time for new cam, heads, intakeifold and throttle body?
- Spartan build around the corner.
- LQ4 6.0L in a 95 z71
- smashed/bent ls1 pickup?
- My 228/232 cam dyno video!! Finally
- sdpc cnc
- LSA Oil Pump in a LS1
- Help me pick a head gasket w/ my set up; Other Questions
- Core LS1 engine prices
- lq4 stock crank rpm limit vs hp?
- Are these scratches normal? rebored block
- Biggest cam with 5.3 heads
- Cam and head swap the right way - Part checklist
- cam for 5.3
- keep the tfs 215 or go bigger?
- Blue smoke once at operating temp
- What will my compression be??
- Lost Oil Pressure Significantly Mid-Race! Built LS1
- Initial upgrade from stock questions, HPtuners questions
- need help with gremlin
- where do i buy a new floating piston pin retaining ring(snap ring)
- GM Performance Cam for LS!?
- Cam & stall question
- Making it a daily driver again, few questions
- recommendation's for start up after 4 years
- Next hot cam question- What is base circle on the gm hot cam?
- Lunati LS Retro-Fit Rocker Arms
- Sorry but...spec my cam?...LQ9 408.
- help with build sugeestions
- Ackerly & Childs Piston Rings for 6.0(LY6)
- Top of valve worn more than others?
- LM7 with LS3 cam (FREE CAM and parts)
- Crazy Question
- new head cc size?
- Can you get a custom cam to work with ls6 springs?
- 98 LS1 stroker?
- Bearing questions
- need help with oil pump o ring!
- reuse or get new dowel pins for heads?
