View Full Version : Generation III Internal Engine
- Predator-Z El Torro Cam
- Ls Engine Combinations
- Piston Ring Selection
- replacing Barbell with welch plugs
- re-planning my lq4 build YET AGAIN. (Build Finished pics and idle clip inside!)
- 6.0 lq4 rod bolt strength?
- Crank reluctor help
- just picked this up today!
- Ls6 cam in my 5.3 ???
- Cam and heads
- Procomp rods?
- 2 quarts of oil + rattling noise = worries!
- 90lx 6.0
- 243's and 228r cam swap
- 5.3 cam question
- stock ls1 piston with valve relieves???
- which cam to pick?
- Rod Bolts
- Overheating issue
- Calling Engine builders (simple questions)
- Me and my Buddies almost Stock LS1s
- GM ls1 1.8 shaft mounted roller rockers?
- Another cam selection thread
- Head Gasket Decision
- 224R in A4 C5 with stock manifolds
- Compression issues
- LS7 lifter failure
- Budget daily driver build
- 6.0L Engine out of a 2001 Denali
- Aftermarket Auto Parts Installer Directory
- Flat Plane Crank LS1 Build
- Random Misfires?
- few last questions before i finish build injector and pcm
- Calculate my compression plz
- Help timing
- Help me pick my heads.
- Head choice A.I. 226cc 243 head OR 230cc AFR on 347ci
- LM7 suggestions?
- Preload help!
- diagrams of the oil passage thru a block??
- What could this be from
- Aftermarket Parts Installer Directory
- Oil pressure at 10 psi?
- A large moth or horsefly just flew inside my new LS1
- Need the pros help again, Valvetrain noise
- 5.3l ls6 cam/springs which valve seal/seat?
- tfs head?
- 59cc head too much??
- Anyone 223/227 110 637 640
- push rod size???
- ok, I have a serious question about 4.8L's that are NA.. (LS6 Iron Clone??)
- Which intake
- big mutha thumper cam
- Information on lobe seperation angles, need help!
- Information on what LS Series block I truly have!
- 799/243 heads and Asa cam
- 383 troubles
- Flat top pistons with l92 heads
- What are the best cyclnder heads
- tsp 383?
- ls6 spun cam bearings
- Cams
- LM7 and MS3... next! Bottom end advice needed
- Sqeaking until engine gets hot...
- Opinions on a new longblock
- Who can make my Custom Comp cam?
- blow- by
- ? On crank balancing.
- Help me chose a Cam!!
- please help, changed pushrods, lost power
- tsp torqurer v2 driveability
- 2001 Z06 corvette
- Stock 5.3l piston dish volume?
- 5.3 GM Engine differences ....
- Input on this cam
- Cam ID
- heads and cam hep
- head gasket removal....
- anyone feel like educating me on cylinder head cc sizes?
- 5.3 Cam Help
- What do while its out
- Porting program?
- Spun bearing is confirmed...pics inside
- Prc .650 dual valve spring life?
- Need Opinions Of cnc work on heads
- Need all the tips/tricks I can get!!!!
- Hey all! first post here! Looking at comps 228/230, any suggestions for heads?
- Please look at this cam card and educate me with your opinion.
- Burning oil??
- My LQ4 Build
- Deciding on long term setup, DD/Street.
- your toughts on a TSP MS4 cam?
- Polluter cam which transmission
- LM7 Suggestions
- 5.3 ring gaps the final word???
- Can kit
- Cam Recommendations and Opinions Please!!
- EPS 230 238 or Comp LSR 231 239???
- How's your oil pressure?
- LS1 450-470 flywheel hp
- simple upgrades
- Is it worth it to have my 243 heads cnc ported?
- radiator out for head swap??
- 799 heads on an LQ4
- Anyone know a guide to build LS?
- help.. engine breaking up under heavy load
- plastic discs on LS1 injectors
- Proble with mileage counter camaro 98 z28
- Pushrod Techies Chime In.....
- LQ4 bore stroke possibilities?
- lifter preload experts take a look** video added
- Picked up TFS 220 as cast...Cam suggestions?
- Which cam?
- can stock head bolts be re-used?
- Took the Car to the Track
- cam and spring question
- I put 10w30 back
- help me identify if this is a ls6 cam
- piston swap out
- Gunk removal?
- Ls pistons and rod question!!
- rod big end ID
- Just my luck. Changed oil after an hour of running with new cam. Broken spring.....
- 408 build need help
- LS6 cam advancing for lower compression/boost???
- Looking for opinions on this setup
- 224r & 25% U/D installed. What will 1/4 mile gains be? 224r owners please come in
- need help asap
- pushrod length with different heads
- 2000 6.0 questions
- 4.030 Diamond pistons.......who's got the best prices and availability.....?
- Forged rods and pistons with stock crank?
- 227/235 lsr cam on 243 headed lq4?
- Question regarding lifter bleed down and failures
- 232/238 cam only Ls1. What Size push rods?
- who s running the torquer v2
- LQ4 cam advice, need some help
- replace ls2 rod
- PRC 215 heads owners come in please.
- So the tech that installed my heads stripped a center bolt for my valve covers!!!!
- what kind of push rods and valve springs should i use
- Come in, throw me some input. LQ9 swap.
- 1998 ls1 to 2003 lq4 swap..
- 2000 camaro ls1 dead spot?
- Misfire issue
- Txas Speed 441 Rotating Assembly
- Ls6 heads question
- Lq4 TSP stroker build,need some advice
- 241 head porting
- Timing Chain/gear replacment
- Looking to get ~450+hp need help.
- Best setup for 450-500whp
- TSP Magic Stick 3
- does this timing chain look timed right?
- help me buy goodies
- Stock 862s or stock 241s on turbo 5.3
- Snapped a head bolt.
- Help with some main bearings questions
- Comp Cam Help
- rocker beaRINGS
- Another Op[inion on Cam question!!
- Cam install degree?
- Need some good cam advice...
- 402 high compression vs 383... which one to build?
- building a lq4 for a 71 camaro
- Super Victor Intake?
- Help me choose a cam
- cylinder honing
- need torque monster cam that is spray friendly
- Need help on LQ9 build for a dragster
- i think i may need a new camshaft position sensor
- Which flywheel?
- Changing heads.. PR's too??
- Casting Dates?
- dropping the motor from the bottm,need info!
- 500whp build help
- Which roller rocker to go with?
- Ls1 help! Mods heads cam
- Cam install HELP!
- custom cam grind
- car gets hot after driving about 1mile
- Hybrid LS question: PTV, milling, cam.. etc
- Intake Selection Help Please??
- best cam only
- ls1 rebuild for swap, am i missing anything?
- head porting in michigan
- cut out cat and weld in pipe??!
- Bearing Selection
- Block Logic
- Can I cap off the breathers on my valve covers or is there another solution ???
- Wanna Check my pushrod length math?
- Engine Build to come..
- Patriot Performance "Predator" heads. Any thoughts on using these.
- Pushrod Length tool why less turns?
- Better motor choice? LS1 383 Stroker or LS2 364?
- Ready to pull the trigger on mods, not so sure about labor
- when to upgrade stock rockers?
- EDIT: FINALY GOT IT! (stripped my fuc****crank threads all the way) installing pulley
- TR V3 Cheater cam
- Motor suggestions
- If you've thrown a rod come inside
- 3/8 or 5/16 pushrods???
- 98 SS ready for first oil change, have 2 questions
- Lunati Rods
- 243 heads found on LH8/LH9 2009-2012 5.3L Colorado? On a 4.8L with a LS6 cam?
- looking to purchase an ASA cam
- just bought some 799 heads
- should i.use copper spray on my head gaskets?
- Stock Injectors and H/C
- AI Dart/RHS 223cc Heads?
- hp/tq estimates? on a rebuiltt ls1
- Foreign object in block during cam swap
- Do different cam lobes effect vacume?
- tfs 245 or PRC LS7 small bore heads on 416 cu
- Throttle bogging down, not idealing and TCS not staying on
- Need a little help
- How hard should it be to pull u/d pulley on? How to tell when fully seated?
- oil pump o ring question
- Dynamic Compession with Dart 225
- Degree'ing cam....ICL problems
- How to tell the difference between LS6 243's and LS2 243's
- LS3 help Please
- Cylinder bore / Ring issue
- valve stem seals
- 347 Engine builder problems?
- LQ4 and milled 243's... will tsp v2 fit?
- LQ4 Build - Cams and Heads
- Whats a good heads and cam set up for ls1
- Best cam for 383 stroker
- rebuild or stroker????
- 2000 z28 ses light on will it be in limp mode
- Feedback with lq9 pbuild plan
- Cant put on prc duals with my spring compressor
- Compression for my 408 with this cam...too low?
- uh oh... think i messed something up....
- Lq4 compression test results....question
- AFR/TFS worth it over 243s?
- White Smoke out the exhaust pipe
- Price list..........
- Are ls1 valve locks the same as valve locks off a 317 head?
- Need Piston help!!!!!
- Big backfire n pop after cam install
- Opinions on a budget 370 lq9 build...
- Link Bar Lifters position?
- May have killed a lifter and the engine isn't even running yet...
- New or Rebuilt Engine for a 2001 WS6 ??
- Who has milled 317 heads (Tech)
- ? about ls3 cam
- lq4 tolerances
- Rebuild Tips
