View Full Version : Generation III Internal Engine
- Will my cam pair good with my heads?
- AI spec cam
- Damage to lifter body
- 2000 LQ4 Rebuild, Overbore Taper and Torque Plate Shift
- Did I find a head gasket problem?
- LS1 preload (not LS7)
- Gen 3 Ironblock + Gen4 Rotating Assembly
- Pushrod length opinions
- Budget heads are they good?
- Heads opinion
- 5.3 or 6.0
- Camshaft Identification and advice
- Some good lifter info
- How freely should cam rotate, new cam bearings ,
- Even and odd bank pushrod length difference
- L33 5.3L build questions
- Too much open spring pressure?
- Which timing chain?
- Cylinder Head Availability
- polluter, tsunami, ms3, streetsweeper
- Need to see if I need to even check my ptv
- LS1 with stock heads and cam (and n/a), how much power is realistically possible?
- misfire no ses light
- LM7 on the stand dumb or smart to replace lifters and some other parts?
- Morel 7717 getting louder
- LS1 Valve covers
- This motor ran what do to?
- Melling's oil pumps
- Need help!!!!!!
- Lifter choices
- 5.3 LM4 with flat tops and 862 heads - valve and cam questions
- Ptv contact cammed ls1
- End play with coated bearings
- Coated cam bearing question
- strange ls oil pressure
- Blower LM7 build Questions
- Spark plug questions
- Lq9 oil galley damage
- LQ4/799 heads question
- LS cylinder head gasket
- PTV Clearance Advice Needed
- 243 chamber volume
- How screwed am I? Cam journal scoring [picture included]
- Daily Driver 406 LS2 Build for 02 Z28
- LS9 head gasket 5.3
- Imperfections in cylinder head, is this alright to run??
- Valve Train Tick Diagnosis
- LQ4 build advice
- LQ4 Cam Bearing Install
- Slow oil pressure drop with time
- best spark plugs for n/a e85
- Low to no oil pressure at warm idle
- 5.3 Gen 3 delayed knock when started
- Can I run 87 octane
- Broken Head Bolt 1998 LS1..........
- Help with 5.3 cam selection
- Ls1 fresh rebuild oil pressures
- CAM Sensor hole not smooth, and BONUS info on O-RING
- 5.3 LM7 ENGINE NOISE - Rodknock? Piston Slap? Rings?
- E85 - whats it take and is it worth it?
- 6.0 LQ4/LQ9 build, what camshaft?
- 243 cylinder heads on a gen 3 lq9
- PTV Clearance with BTR Stage 4 cam
- I drilled out exhaust bolt hole, hit water jacket!!
- Small scratch in surface of FelPro Head Gasket
- Cybertruck "chop"??
- Gen III Cam bearing oil clearance question
- Frankenstein M115s?
- 2005 4.8L all of a sudden spews out all the oil BAD BAD BAD!
- 2000 LS1 Engine rebuild
- Rod bolt question... again
- How much lift can a stock 706 head handle?
- CHE Trunnion Kit update…
- Gen 3 6.2, 823 heads, L92 intake cam questiom
- 5.3 overbore 0.020 rod and piston question
- Slow bottem end knock and blowing smoke 370ci lq4
- ATI dampner install questions
- Windage Tray Nuts
- Ls1 valve seal color
- Plug on cylinder head gen 3
- 4.8 Cam/Push rod question.
- 5.3 lm7 build sheet
- 346 to 383?
- Need help on 5.3 lm7
- LQ4 build
- Timing chain position inspection
- Measure Pushrod???
- Machining mark in intake ports
- Ported 853 or stock 706 heads?
- Pushrod length?
- When to go roller rockers?
- 5.3 cam questions
- What to upgrade?
- Oil Pressure Issue LM7
- e85
- Main Crank Bearing Clearance
- Oem+
- Building LM7
- First Cam Swap - Any feedback on Hawks Cheatr Cam?
- Double Checking my Pushrod Length Measurements
- Educate me on shimming springs
- 408 build
- Engine ticking and turned off while driving
- Graphite gaskets okay or buy MLS?
- cam swap gone bad.
- No idle after cam install
- Yella Terra roller rockers
- Melling/TrickFlow Timing Chain Damper Adapter
- Need help with 6.0 pistons
- PD Supercharger Cam
- Gen 3 iron block camshaft bearing question
- Need help asap truck won’t run
- Lm7
- Rebalance needed ?
- Rebuild 6.0 crank pulley adventure
- Lingenfelter GT1
- Gen 4 24x Reluctor Wheel Questions
- LS1 Timing chain advice
- BTR TK002 Trunnion Kit Side to Side Play
- Cylinder head question
- what head gasket to use
- Experience with Howard's cams?
- Biggest cam inside of a built 5.7?
- Different springs on intake and exh
- Dart shp ls next oil pump
- 07 2500hd freshen up.
- Fast 102 Intake 92 or 102 tb
- Break in oil
- Engine builder tiers
- Engine Storage Outside
- Durabond Cam Bearing Quality Issues?
- what lifter to buy
- help im missing something about push rods
- Doorman Harmonic Balancer
- Lifter turned in plastic holder
- help with push rod lenght
- LQ4 truck build
- Best LS7 style lifters for the $$$
- bolting down crankshat question
- Modest Power for my Gen 4 WS6
- 2003 gmc 2500hd LQ4 dropped lifter?
- Need Opinions on What Rout to...
- help with change of compression effects
- Autocross/Road Race Cam Debate
- Whatta Sleigh, eh??!!!
- 01 Trans AM LS1 noises
- Optimal Quench, LS1 to LS6
- Engine Oil
- Looking for cam recommendations
- did I just kill my engine? High RPM oil pressure.light came on
- Budget performance on a lightly modded LS1
- Cheap DOD/AFM delete gone wrong
- LS1 Oil Capacity Question
- Engine swap?
- Sudden loss of oil pressure
- Baffle in Valve Cover ...remove?
- Tsp shortblock-which heads?
- Merry Christmas and Happy New Years Sale at SacCityCorvette!
- Cam Recommendations, Iron 383
- Swapping springs vs new heads
- Trickflow really let me down
- What Rockers are These?
- Cylinder Wall Ok?
- Start of 5.3 build
- lq4 cam journal to bearing clearance
- Which block Do I have
- 5.7 LS1 with a goal to make 425-450rwhp?
- 2003 heads on 2005 5.3
- 5.3 LM7 Cam Selection w/Trick Flow 205 Heads
- Cam question for LQ4
- Lifter preload
- Main bearing clearances HELP
- 408 Stroker 1500 WT spec.
- Opinions , trash talk, oil pressure f$&
- Bronze guides and factory rockers
- Gen III LM7 Cam bearings size.
- L59 Top End Refresh, now pushrods are too long?
- Cam suggestions for LQ9 with 243 heads in a 68 Cadillac
- Guessing time to rebuild
- Mk3 supra with a 5.3 head and cam question
- Please come check our new website for Black Friday!
- Crankshaft radial play
- Gen 3.5 rod and pistons
- Timing mark question
- 5.3 L33 Autocross Build
- BTR red hot cam + GMMG exhaust input
- johnson reduced travel lifters vs short travel lifters
- Cam my ls1? or swap to ls3?
- Can you guys listen to my engine please. 2003 c5 z06 ls6
- New 5.3 build. Machining questions.
- oil pick up tube not fiting
- Gm Performance LS364/450 VS LS375/430 Base to swap in
- Cam upgrade
- Spring presure and lifter life expectancy?
- Camshaft input
- Camshaft challenge results
- 5.3 Build Questions
- TSP Chopacabra with stall converter
- Flat Top Pistons
- New LS Goodies from Summit Racing
- LQ9 Cam Shaft Questions
- Gen 3 or Gen 4 Aluminum 5.3 Block Questions
- Question> 7.400 pushrod is 7.417 ??
- I think I messed up.
- Oil Barbell
- Need Help; LQ9 piston identification
- Gen 3 L33 performance help.
- 5.7ls1 to 5.3lm7 swap
- 862 head milling question, how much?
- 243's or 317's ?? For 6.0 in a C10 truck.
- head gasket 5.3
- 5.3 gen III ring gap
- Should I go with a bigger cam?
- 24X Neutral balance
- Anyone try Comp Cams XD-A pushrods?
- Oil pressure
- Valve springs
- 5.3 Cylinder #8 Pitting, Would a hone clean it up?
- 4.8 ls mls head gasket
- what sorta compression did i end up with
- octane question for a daily build
- Lm7 bored to 6.0 with 4.8 crank
- Will a LS1 with 806 heads run on 04 GTO ECU?
- GM low oil pressure troubleshooting guide.
- Loud ticking/tapping after driving for a few minutes
- LM7 build, first LS swap attempt.
- ARP 234-3724, head bolts
- Anything to gain from cam swap?
- Gen 3 6.2
- engine misfiring p0300 codes after lifter job (sorry if posting to wrong forum)
- What year block do I have? 6.0 - 3003 on front
- LS1 - Pre Install (drift engine)
- What lifters would you run?
- 5.3 spare motor storage
- Help with engine RATTLE noise
- How would this "custom" cam perform on a 5.3?
- Aftermarket cylinder heads worth the $$$ in a boosted app??
- 4.160 Cometic Head Gasket for AFR 215’s on 346?
- 1.8 ratio rocker arms on stock LS1
- Getting 4" crank. Will this be in issue?
- Melling oil pump spring selection
- Need advice on upgrade choice
- Pistons with a cross on them....
- Help with internals!
- 408 Pistons with quench.
- Valve starts moving when checking lifter preload - pushrod length check
- LM7 Build Questions
- Cam choices
- COMP Trunnion Upgrade
