View Full Version : Generation III Internal Engine
- UPDATE--Here we go! 98 Z28 LQ4 Swap-- Pics Inside!--Video Added!
- 402?
- Lq9+Polluter Cam+150 shot=?
- Another build question.....! :eyes:
- Checked pushrod length... Now I'm really confused.
- Low RPM Misfire/Hesitation Issue
- 243 head shaving PTV Questions...
- Cost of going Forged
- Scorpion lifters
- is this sound normal**vid inside**
- is passanger head coolant plug bolt with zinc coating a bad idea?
- Good cam for stock 243 heads...
- Just a little thought of NO2 after getting heads ported. JUST A thought.
- Texas speed porting price?
- oil pan capacity
- Ls1 Crankshaft question
- Who's running T&D shaft rockers?
- Difference between LS6 oil pump and GMPP high Volume Pump?
- valve size on 5.3 heads want to go bigger
- Pulling the trigger on heads, questions inside.
- First Pics PRC 220cc As Cast Cathedral Heads INSIDE!!
- Cam Questions
- Cam Questions
- Good turbo cam
- Blower Cam in NA LS1
- Absolute best flowing heads w/ stock angle rockers
- deck height question
- comp cam ID
- Cam for z06
- OK Land Speed Heads is my decision anybody ever use them?
- PTV clearance question
- Evap Purge valve manifold cap
- engine build ?'s
- LM7 with LS6 cam HELP!!!!
- ls1 vs ls3 vs stroker ls1
- ring gaps....
- 317 heads with an L92 Cam.
- Who's using voodoo or comp cam Gold roller rockers?
- Clearancing for cloyes double roller + Melling HV pump (Pics inside)
- 92mm or 102mm throttle body
- Trick Flow pushrods and Patriot Gold Extreme Valve springs....Good?
- help identify crank in 408 rebuild
- Lifters need to be bled ?
- LS6 valve seals, which color is exhaust, which color is intake?
- 5.5L LQ4 or LQ9?
- Cylinder flex honing
- LS1 Egr Valve testing how?
- A new car
- really need some help read evrything i could before posting again
- rocker arm and bolt set
- what else should be done with a basic cam swap?
- bearing question
- 243's or milled 317's
- Got my FAST 90 on today
- Which rings for my LQ9 build?
- Jeep LS1 build, i need suggestions
- misfire after head swap
- 5.3 went down ...
- Can these heads be used for port/mill work?
- Suggestions for engine build
- Help, no start issue
- Which valve springs?
- Oil pressure specs for those who want to know.
- 224r
- Correct part # for coolant plus for ls6
- 383 vs 347 longevity
- TFS 235's fit a 4.010 bore?
- High CR cnc'd 241 vs cnc'd 243?
- new valves in 706's
- tsp 408 build questions
- Timing chain and oil pump for 408?
- what horse power to expect??
- VSS Signal info pls: Audi RSS6 swap help
- When are arp main studs needed?
- Thinking about a 421" LQ4 Build.....
- Stock LS2 piston and rod ?'s.
- LS6 / Z06 CAM Question
- 6.0 plug locations
- Need machine shop
- Head torque specs
- 317 heads/LS9 Head gasket/which pushrod
- milling ?'s 243's
- Soon to be LY6 clone...
- Engine Swap Question. '09 G8 GT 6.0 into my '00 WS6 T/A
- engine bearings
- Question about motor I just bought
- Cam Recommendations
- help needed please guys
- How to remove oil pressure switch on back of block?
- Cam suggestions with 11.5-1 cr 346 ??
- Michigan Machine Shops:
- Texas Speed 224R 581/581 Cam
- Quick question on milling heads?
- magic stick 3
- 5.3 Build..cam/head/stall choice
- 853 heads any good?
- Power Steering Delete Question
- 383 Stroker crank installed in stock low mileage LS1 shortblock...waste of money?
- Fuel Economy Build
- LS Engine Rebuild/Machine shops in Central Ky
- Need help doing work on my LS1 PLEASE....
- First engine swap... come in and give me advice
- Lsx-L92 5.3
- Compression check results - where to go from here?
- tr224 cam question please help
- Scotch bright pad on heads and mating surface's
- So I have to choose a headgasket and a cam... some info needed...
- pair of 241 heads value ?
- Cam suggestions?
- ARP head bolt problem
- 4.8 bad cam bearings
- Blown headgasket? (preliminary pics)
- My new 402 stroker build list.
- Cam Selection...Stock Stall...(Please Look)
- trick flow stage 3 cam?
- specs on 5.3
- bore questions
- Stock rocker arms
- I used a green roloc disc on my block, wtf.
- machine shop question
- Wiseco told me i could use either rod....
- afr 215cc vs. prc 215cc
- Vrx3 valvespring decission
- I cant get this cam in for the life of me.
- Broken PAC Valve Spring
- Another 5.3 turbo camshaft question
- Anybody used FELPRO Head bolts ?
- are 20 mile on the clock LME cylinder walls supposed to look like this?
- Installing heads soon....
- lq9 piston help
- yes, no or maybe so???
- Ok should I choose PRC stage II or AI 226cc
- Tall, fabricated valve covers for LS6
- Low oil pressure (video)
- Nissan 240sx fuel pump and injector sizing(ls6)
- Does this sound like a hell no! head porting
- ls1 c3 corvette air cleaner setup?
- Power making a4 cam still streetable
- Will too little preload cause valvetrain noise?
- ID an LS6 cam
- anyone running a vrx5 cam?
- 4500 flange intake
- Destroked 6.0
- LM7+LS6 cam+shaved heads pushrod question
- heads help
- Another problem?
- Whats the deal with the lxl lobes?
- Autozone/Fel pro gaskets good enough?
- flywheel bolts keep turning. am i screwed
- tach signal?
- I know it is asked alot but I need some fine tune help
- suspected miss at temperature, bad lifter?
- Clean the pistons?
- Cam w/ centrifugal supercharger
- How much is too much
- who is running AFR's or TF's? what kind of #'s and times you all have?
- Aaaaahhhh! My rockers are touching my retainers!!
- What can the 12556333 intake be used for?
- about ls1 stroker
- porting to suit cam size
- Smell of Gas in Oil
- Piston ring compressor
- Rod bolts!!!!
- INDIANA: I need an engine shop
- '98 pontiac trans am vacuum problems
- cam card question TEXAS SPEED PLEASE LOOK
- oil gauge
- Buy used CNC'd heads or factory and send them off??
- Advise on LS1 build
- Wiseco Junkyard Dog Pistons
- Need advice on TFS 220's
- Forged 383 Build List, Suggestions Welcome
- whats better LS1 383 or just going LS2
- Sudden Loud knocking
- does anyone have a video of a grand am cup/showroom stock cam?
- 98 camaro battle
- Oil Pressure on First Start?
- Oil pump o ring question
- LQ 408 Stroker
- Corvette LS2 60 link timing chain on a LS1.
- Cam for carbed 5.3 w/ 4.8 flat top pistons and .035" milled 706's?
- Cam retainer plate broke
- valve train noise
- Ls1 Head and cam opinions please
- ls2 vs lq9 block for a 350 shot
- Cam help
- what to expect? stock cam w/243's & ls6 intake
- Small hole at edge of sleeve
- Rod question
- bigest streetable cam
- L33 rebuild cylinder smoothness ?
- So after totaling total cost for a 799 head swap I've decided...
- 4.100 or 4.125 on 5.7
- 2002 Camaro Z28 build in progress
- Used PAC's
- ms4 cam in a daily driver
- R.i.p. 02 z28 camaro a4
- Any Help to ID 2 Engines.
- overheating need help plz
- Cam Swap Tools
- 402 lq4/9 v.s. 383 lm4/7
- Stock Sounding 380rwhp? $2.5k what mods?
- Stock 6.0 rockers in L92s?
- pocket porting stock ls1 heads
- Now that I have the 799 heads I need a list of everything needed for the head swap...
- Connecting Rod selection
- Difference Between Stage 1 & Stage 2 Heads
- ARP Head Bolt ??
- Torque Specs
- $4000 budget
- What heads come on the L33 vin code B 5.3 H.O.
- cheatr cam
- LS1 burning oil after WOT
- New Camkit and Upgrades!
- Cam walked have some questions
- Is a little smoke normal from oil filler neck?
- need knowledge from others. Cam stuff.
- FI stock motor build ???
- So I'm getting some 799 heads and I have some questions.
- crack cap rods!!!
- oil pan- is this a problem?
- 5.3 gasket set question/LS1 intake
- Opnions on Comp Adj. Timing set
- What head gasket? 5.3, 4.8pistons, and 706 heads milled.035"
- Any Suggestions Before Build Complete?
- Is it a good idea to put on some 317 castings on my cammed 98 ls1?
- DCR help
- SDPC Charity Auction For Rosie Ceralli **CNC 5.3 Heads**
- What are the absalute best single beehive springs?
- Oil pressure problem...
- pushing my luck?
- reusing factory piston rings out of 1k motor
- wanting 350-375 rwhp
- Stock rockers on 625 lift cam.
- engine builders tell me what this is?
- Explosion in 1st gear
- Another Cam suggestions thread
- Lq9 PTV clearance?
- Need Help! Custom Cam/LS6 Heads, Clutch, or Fast 92/92
- need 400-450 to the wheels wut to do
- LQ9 deck surface
- Ok to handport 243's?
- need help building a 5.3
- Is it worth swapping to Carb style intake?
- Is it worth dropping money on stock 243 castings?
- vengenance racing cams
- motor swap
- Torquer V3, Streetsweeper HT, Custom EPS or Streetsweeper
- yella terra scores a 0 in service 5months still no replacment
- What cr should I go with
