View Full Version : Generation III Internal Engine
- cam suggestions
- Estimate push rod length
- 383 ls6 trade for a ls3..
- ABSOLUTELY crucial to have stall and gears with cam swap?
- EPS 230/230 .600/.600 113+2, anybody running it?
- need some suggestions on what heads to run on my ls1 with 228r cam
- custom grind cam for carbureted forged 347 ?
- Cam swap 5.3
- Not another "H/C" thread
- How much for a built LS1 engine?
- Will 9.5:1 n/a be annoying?
- Will ls7 valve springs work on my ls1 heads?
- Ls1 valve dished area?
- 4.8L cam replacement 99 Silverado New body style
- How many RPM can a stock bottom end take?
- Texas Speed
- 99 Z28 build
- Are LS series engines naturally quieter than sbc
- What do I need to buy?
- Need Help! LQ9 Runs great until reaches operating temperature?
- need advice on a fast budget head swap.
- Tune or stall problem?
- speed inc si6 cam installed
- Cam Only Project(DYNO Numbers Added!!!)
- Light wear on cam? with PICS!!! come inside...
- 383 stroker
- What replacement rod to use
- Looking for head specs... Milled 853 cc #s
- Stupid Question: Bolt Reuse?
- Rod knock or flywheel loud tapping.
- Heads advise and help !!!!!
- Cam and Stall
- link bar lifters......which ones?
- Cam only plus some
- Displacment decisions
- Fast intake bolts?
- Ptm 102 mm tb cable driven?...
- what do you guys think of the port job on these heads???
- New Build Solutions, read and chime in...
- YANK 3000 stall?
- help identify ls1 rods
- lq4 compression w/flat top pistons
- lifter stuck!!!
- to do heads or not? talk me into or out of them...
- Engine acting up on WOT
- 3rd gen ls1 swapp kits.
- Engine Tear Down
- Cam question ?? Help guys
- DIY LS1 Head Porting at home can Help
- heads for 5.3 combo
- Cam Help on a Nitrous build
- Beehive springs and Stock cam
- Head Stud Install, May Have Stripped Block Need Help ASAP
- installing studs and heads, double checking things
- stroker PCV system.
- Installing cam in a 155k mile longblock
- 370, trex cam...what heads\intake
- PRC stage 2 799 heads 59cc or AI 241 205s 62cc
- ARP oil pan bolts...
- 6.0 216 crank in a ls1 5.7 ?
- Curious why/how this damage occurred?
- Spun a Bearing...could a faulty oil pressure sensor be a reason for failure
- Heads/Cam Help Please
- Building my first gen iii, i need help/info...
- Tell me how this Comp cam would perform in a 408 with ls3 heads and intake
- Rocker/Pushrod Install Question
- 5.3 to ls1 questions
- another P0300 Issue
- Is this safe on a stock bottom end?
- 6.0 crank in 5.3
- need help with budget heads
- Pushrod and preload
- How to Comp Trunion upgrade using a vise
- 6.0l LQ4 pistons? where can i find a stock flat top replacement?
- What rings and bearings to use?
- Its tax season and im new
- Need cam advice for a 5.3
- Would this combo theoretically be around 11:1 compression?
- Torquer v3 what heads work the best
- ls9 camshaft question
- best bang for the buck ls1 rod ?
- Combustion chamber size
- How to achieve correct surface roughness on block deck/heads
- Correct pushrod length for GMPP ASA cam
- how high can i rev this cam i bought
- Budget head choices
- How much compression can you get out of 317 heads on a 408 with a decent size cam?
- Removing oil filter
- 5.3l with 243s how much to mill???
- prc 227 heads with jesel rocker shafts ?
- FASt 102/102
- Bought heads for my CTSV. Now I need a cam
- LS1 Intake gaskets
- LS Engine Swap - Need Suggestions...
- AC Delco-parts = GM-parts?
- When to go colder plug than tr6 N/A
- Got my H/C/I but what oil pump, lifters, etc?
- head milling
- HELP PLEASE I Need a cam verified.
- 01 Z28 Camaro - Heads n Cam decision...
- location for my shift light on my 98 camaro
- TFS215 head on bigger than 408?
- LQ9 Build Suggestions
- light rods and pistons for a normal price
- ARP rod bolt resizing
- LS6 cam in a 5.3 is it worth doing?
- single row adjustable timing sets
- BTR - Brian Tooley Racing Spring Kits: .660 Platinum or Extreme
- What valve springs? Need help quick (DD)
- LS1 to LS6 PVC Conversion Questions Guru' Please Help
- Help with pushrod length!
- Parts List for Heads/Cam Install?
- Heads that flow well on the exhaust, or intake? Which is better?
- How would ported 5.3's or 243's with TSP giant cam perform in a 408?
- Anyone running a Tick Street Heat cam?
- Attention all gearheads need advice
- Replace those stock lifters!
- 230/234 112 + 4 idle clip
- Tubo 408 build, cam suggestion?
- Cam selection help
- Lookin for a sound clip..
- Intake Removal Question
- Could you please help me with pushrod length
- general Ls6 lifter cup question
- Anyone used EPS's LS Single Plane Cam
- honest oppinions please
- Spark plug gap question
- 4.8/5.3 genIII question?
- What kind of rockers should I run with PRC 215s with bronze guides?
- I talked to 3 sponsers...4 cam options to choose from. What would you do?
- Need some cam swap injector help
- stealth/ small cam thread
- Engine lift plate template or basic measurements anyone ?
- 383 questions
- Are these overpriced?
- LS1 Rocker Bearing broke, what now?
- gen iv in a 99 TA
- Random Misfires on Cammed Trans Am
- Help Diagnose this Exhaust Smoke
- C5R chain or double roller?
- Am I missing something?
- what weight oil?
- 5.3 rocker arms
- 5.3l biggest cam install
- ughh flycut or not
- Oil pump?
- Need Help Deciding on Idle for Tune
- Heads and milling question
- lq4 questions
- ZR1 crank in a LQ4?
- Need quick help
- Piston slap after fully warmed up
- Vic jr, Proflo xt or something else?
- Wrecked 5.3L (Engine Autopsy)
- Valve C. gaskets blew out. HELP
- ls1 vetter with ls6 top end what all is needed to do the swap right??
- 59cc Heads?
- ETP 215 Head's??? Anyone Run titanum valves???
- Wich head gaskets should I get?
- 2000 SS SLP input on purchase
- 02 LS1/T56 45,xxx original miles (whats it worth)
- Hot idle knock
- stock shortblock lq9 build, prc ls6 2.5 head or ?
- Heads on cam degreeing
- Comp XR269HR-114 for 5.3 questions
- needing a little engine build guidance.
- my LQ4 build plans and a few ?'s
- People w/ EPS cams, post your setups
- Head Options for Mild Street Build (Ls1)
- Pushrod Length Suggestion
- timing chain question?
- Time for some winter upgrades/suggestions
- Cold engine start up Tick. LS1
- Long hot starts
- 408 rattling noise. Long story but would appreciate your input.
- 5.3 Truck Cam Question
- Recommendations LS6 build
- Ordered custom cam surprised with new specs but looking forward to how it runs
- 5.3 to 5.7 ?'s... Mostly hp & reliability..
- Dropped Valve resulted in serious carnage
- 00 SS what do you think
- Odd oil pressure
- 6.0 lq4 bad vibration
- Harlan Sharp SLS17 Users Questions
- Stage 2.5 PRC Heads Help!!!
- ~230+ cam with shorty headers & no cats? Who has done it or has results?Overlap okay?
- gas mileage
- What Models/Yr's are 243/799 heads on?
- Could this be bad valve seals?
- Does anyone have experience with ProPower Performance?
- Fast 90 Intake
- Major oil leak!
- Replacing my 5.3 crankshaft what needs to be done?
- My reverse split tr230 cam and budget heads?
- Melling oil pump rebuild kit??
- Motor not starting after ice storm, Starter? HELP!
- MAJOR endplay problem?
- ls1 oil pressure ???
- LS7 crankshaft in LS1
- Piston slap teardown
- need help setting Wipe and preload.
- Lq4 no oil pressure
- LQ4 Block, GTO Oil Pan, which windage?
- rotating assemblies best bang for the buck
- Misfire problems. Please help
- How much do you gain with hollow stem valves?
- Replacement Heads for LM7
- Crank pulley installer tool
- LQ4 W/Eagle H beam Question
- Can overlap increase octane tolerance?
- will this timing chain work
- Cam recommendation?
- Opinion needed on Ferrrea Valves
- Chain Damper
- 408 need plan checked
- Why is the clutch making this noise?
- waking up an ls1
- Critique my LM7 build
- Ls1/Ls6 Pistons?
- lq4 gasket question
- Anybody use Same Main & C-Rod Bolts on rebuilt eninge?
- 799 milling
- 2002 8.1 in foxbody?
- miss fire
- Will I need to flycut? (EPS Cam, TEA 5.3 Heads)
- Lq4 swap plans & problems
- Ls motor help!!!!
- Pulley Damage, would you run it?
- LQ4 Cam options
- best driver cam?
- How much can you mill before intake issues?
- ls9 cam dyno results lq4
- LS1 3D CAD for SALE!
- LS6 bottom end?
- Shaner S3 throttle body
- 262/250 555/534 106lsa
- Help! Metal parts in engine oil
- 2002 LS1-what trans to use 4l60e or 700R4
- Little help for this WS6 Noob??
- 0 oil pressure... NEED HELP FAST!!!!
- Should I buy this Fast intake?
- need help im planning a 5.3l and 4l80e in a 95 suburban
- Brian Tooley Valve Springs???
- PRC 227 Questions?
- Crankshaft q/a
- 2004 GTO ls1
- LS7 Lifter & AFR Head replacement w/ Super Vic???
- ls2 timing chain question
- Has anyone seen a spun rod bearing using ARP rod bolts?
- Lifter replacement necessary?
