View Full Version : Generation III Internal Engine
- Help.
- Another spring install thread..I'm I all set as a DIY?!
- Are there some LS6 heads later than 02 from the factory with black valvesprings?
- So I flycut my pistons.....
- ls truck heads question! need help please!
- Adjustable Fuel Pressure Regulator
- L33 with add-ons -what RWHP will it make?
- What was GM thinking /too many grooves on rod 4 brng tang
- Torquer V.2
- loud ticking from passenger side after cam..
- p1153 code
- Blue LS6 springs?
- Cam help please!!!!
- Installed my G5X4 Cam - Video Inside
- Cam install, 4L60E, no deceleration when let off gas pedal?
- How much plug gap is too much?
- need some help with a head selection, lq4 based
- Weird "BANG" Noise from possible top end(ish)
- Which way Torrington bearing?
- .041 head gaskets..any graphite options? or Cometic alternative?
- How bent does a pushrod need to be to make noise
- upgrade 243s
- Patriot stage 2 LS6 heads and Raptor cam????
- Which vendor has a set of 4.130"x.040" compressed cometic gaskets in stock?
- oil pump pick up tube ****UPDATED PICS***
- Zero Oil Pressure
- ls7 lifters and eps comp cam
- arp head boltswhare can i get them
- cam and head install complete now a little help
- 02 Ls1 A4: Audible Knock Losing Fuel Pressure
- What cam would you suggest? Please Help
- Fresh build need recommedations
- help identifying stock LS1 camshaft 0262
- help with new cam set up
- heads and cam parts question
- Injectors for Mild 5.3 Build
- Patriot Stage II 59cc with 227/235 comp cam
- Car stumbling, running rich and backfiring?
- Car uses oil looking at rebuild!!
- RE: Got that missfire fixed with my cam.
- questions for building up a 98 ls1 for drifting
- Cam size question
- friend just bought a z28 wants a cam help
- Need help on cam choice.
- Anybody running Trickflows with a F13 or F14?
- Got my timing cover off and got problem
- Water Temp, How hot is too Hot???
- New Engine Break In at home?
- daily driver???
- Do dual valvesprings hurt cam lobes?
- Is this too much chain slack?
- Help me make sure I measured my pushrods correctly
- ok need help
- who to let design cam
- lm7 heads on a lq4
- Ls1 head bolts
- Best heads and big cam for LS6 resleeved 441ci...4.125 x 4.125
- How much PTV clearance is required
- Blowing on nos test run
- Effect of compression ratio?
- Finally got my cam only torquer 2 going...
- Afr heads spring preassure
- Katech rod bolts?
- Valve Spring Retainers
- Crank choice
- Engine balancing??? 6.0
- Can this be saved?
- Pushrod
- My dilemma. Need everyones input!
- nasty motor sound
- No oil getting to my rockers but pressure on the gasuge
- push rod size ??? help.
- More accurate oil clearance check/ 2 pieces of plastigage
- LS6 crank pulley installed
- Which heads are better for a strong street car, LS6 or L92???
- 243 heads on lq4 - pushrods?
- Dual valve springs and stock retainers
- Ideal Oil Pressure
- Torrington bearing for timing gear
- Lost and confused
- push rod question.
- Intake manifold leak
- Low oil pressure after 3 short laps
- Sodium filled valves.... Worth it?
- 80k motor what to do
- do you need extensions when using the Bosch 13111 O2 sensors
- MS3 Cam, 243/799 Heads, LS6 Intake - What else is needed?
- Lost Bolts
- EPS Cam/Sprngs Break in Procedure
- Cheapest vendor for complete Motors? Possibly trans?
- Pulling the trigger tomorrow....on a cam
- good replacement Bearings and Rings?
- thinking of getting this cam
- Need Short Block advice: replacing LS1
- Ls6 or Victor Jr intake ???
- cam and head swap on 5.3
- Better cam for spray???
- 2001 LM7 fuel rail connectors
- summit racing?????
- Double check my pushrod measurement?
- LQ4 engine with LS2 Top End
- Head Selection
- Spun rod bearing and $2500, what to do?
- Increased valve diameter..
- ls6 cam question
- My engine is back...
- 1.8/1.82/1.85 rockers - good, bad or ugly?
- Will stock valve stem locks work with Patriot Gold retainers?
- Oil Pressure or lack there of. (Dry Sump)
- About to give up on this car
- Procharger - STS - Or N/A
- heads and intake for ms4 cam car
- Pushrod length?
- Anti seize-aluminum heads
- How much Power should this Torquer v.3 Combo make at the wheels?
- Cam installed finally
- Need help h/c set up
- biges T/body with Weiand Intake
- manual fan switch help ??
- 408ci roots blower build
- coolant crossover lines question
- '01 Z28 bogging down during mid-throttle
- Cracked Block
- ls1 to ls6 conversion ?
- Head bolt torque #9 bolt
- I know, another CAM advice thread
- Rings For Diamond Piston 4.030??
- Callies H, H-I, and I Rod Strength?
- Fellas with the TSP torquer 2 cam chime in.....
- Best brand cam??
- need help checking ptv with clay
- Wiped cam lobe and damaged lifter
- Help! Camshaft bolts breaking!
- Ls2 timing chain in a Ls1?
- PSI valve springs??
- Oil pickup tube girdle: gauging intereste before I have them made
- Injector Horror Story (Internal engine related)
- Ls1 heads cam tune question
- LM7 will not start.
- Another stock rod bolt question.
- Anyone running world warkhawks new 15 deg.head with their cam.
- 2000 ls1 high mileage rebuild
- cam numbers???
- ring ?'s
- resizing cracked-cap LS rods ?
- Slight over look now I need help
- Can I remove water neck from pump?
- Piston ideas for a LQ4 build.
- Budget N/A LQ4 build for hillclimb/sprint/circuit car- What would you do?
- bent push rod...whats a good chromemoly push rod ?
- Can a LQ4 Block be Dry Sleeved out to 4.125 Bore?!?
- I bought a ton of new parts..........
- lq9 and what cam
- head gasket
- Connecting rods
- tr-55 plug gap ?
- 99. 5.3 stock build. ls6cam??
- 500+hp?
- Need Opinions
- Pushrod lenghth ?
- ls1 engine noise = bent push rod .... now what ??
- Outer main bolt hole stripped (thrust bearing)
- LS6 block 2004 revision
- 02-04 LS6 Cam
- Vindiactor and 243's question
- JT's C5Z Exhaust and Cam Build
- Mast 275 cath ports
- Cam bearing question, please help.
- 98 Z28 fresh heads & cam - Would like some opinions.
- Trunion upgrade jig?
- cam bearing...should it be replaced?
- LS1 Build
- What stall for a 231/239 cam?
- 408 opinions on the build please
- PAC dual valve springs
- ticking from passenger side
- Quick ? starter bolt size
- Cam Advice
- nitrous on an eps 230/234?
- installing front and rear covers
- Stock Rocker Tech!
- CNC LS1 heads or LS6's
- LS-1 383 build opinions?
- LQ4 (LS2) 4.125" stroke 427ci kits- Where from?
- Piston ring powder
- Best valve springs for 228r cam from tsp?
- Bearing Vendor
- Biggest cam !!
- stock ls1 rod resizing
- Good and bad about the 6.0
- Cheater cam w/ everything else stock
- Stock lifters with cam swap?
- LS1 383cid | PRC 227 | EPS Cam | TEA Vic Jr..Build Thread !! (UPDATED WITH DYNO)
- Cam ???
- Gurus, need suggestions on pushrod length
- head cam set up
- new cam thats nitrous friendly?
- Base Circle Measurement Data: TR224 vs. LS6
- help!!!
- where to buy valve seats and seals for bronze valve guides.
- Look at this plug, isnt this too rich?
- Would 873 Cast iron heads work with a 5.3 block/crank and 5.7 LS1 rods and pistons?
- Hissing sound near intake/injectors
- ls6?
- WHat is a good Head/Cam package?
- Un-freakin believable. I will be da@#ed!!!
- fuel mileage?????
- front crank seal
- Do I have valve float or no? Dyno graph inside, need opinions
- rebuilt 383 stroker LS1 knocking noise help!
- Is a stock o-ring a good replacement for a melling 10296 oil pump.
- New problems crop up...
- Rocker arm choice
- What's the largest cam i can run on an ls1 with stock heads?
- LQ9 With LS3 top end, back fires after warm up!
- 5.3 heads
- Cam question
- building a 6.0, thinking about 5.3 heads...valve clearance question?
- Rebuilt motor zero oil pressure help!
- LS6 Cam question
- Replaced Cam, Now misfiring
- Need help with oil pump I just got....
- Need help, . . been out of the game for awhile
- GM ls7 lifters failed
- need to know bolt size or part number
- choice of 2 cams, which one?
- Newb Question, I have searched A LOT
- ls6 cam?
- antifreeze in oil and loud knocking
- Stroker piston used on a normal stroke
- Need a lil help car running bad now
- anyone spin a ls2 chain above 7k?
- Fuel sending unit?
- 160 Thermostat reflash???
- stay with dish pistons?
- What camshaft is the best to make around 390-410 rwhp?
- Comp Cams Valve Spring Compressor
- oil pump rebuilding
- spring size ?
- Almost done with cam/spring swap butttt...
- noob thread just a quick ?
- Coolant flow - heater valve set up
- third gear grind!!!
- spring guide for my cam????
- Help cant decide on what to put in car
- Springs for Turbo Car
- not torquing rocker arms to spec
- Another newb question - writing on my crank???
- Need some help with my 5.3 build.
- Best heads for me ???
