- Will The Yank Stealth 2600 Torque Converter Do Much?
- How do you like the MMS 224 cam?
- Engine Component Weights
- Head clean cost
- stg 2 heads/thunder cam..where shift A4?
- 1.8 Rockers ... Good, Bad, Ugly??? Need Input
- New cam rocks!! Thanks Speed Demon
- Knock Knock till you drop....horsepower.
- Why size is not a bigger is better thing with engines....
- everyone who wants to give great feedback come in....
- Attention "KILLER"
- Attention killer.
- what gains did you guys see w/ Hooker LT's ?
- Amount of advance to grind into cam?
- G5cam, FLP headers, ASP Pulley Dyno results
- What HP increase to expect with this new cam??
- Advantages of Titanium Retainers?
- Anyone have any flow numbers from GTP heads?
- Questions
- Which way do i put the rods in?
- Who has aftermarket high TQ starter
- can I hone a stock block and still accept "new" stock pistons and rings?
- Which bearings to buy?
- how much power to expect out of 382
- cheapest 2.02/1.55 valve ???
- what could have caused this 1mph loss after cam install?
- mti chromoly pushrods too long for heads milled .03 inches?
- What's the highest you can rev a stock bottom end...
- one more time......
- Flow numbers for Stock LS1 Heads
- Horrible Tick
- Which is the stronger engine?
- Did we ever determine whether GM upgraded the rod bolts?
- P0302 Solved, Broken Valvespring
- With a 01 M6, what cam to use with stock motor,heads,springs??
- ARE Valves: Replace 941 Springs with K-750s?
- Planning Mods Please Help
- anyone have RGR phone number
- 382 engines... a few questions
- lower oil vis equals higher revs?
- I'm building a forged 346.
- In your opinion, does this look like a valvespring problem?
- Highest SAFE amount an LS1 head can be milled?
- Need some technical information for engine model
- Dyno Numbers Questionable?
- Question about Comp 'R' Lifters
- Porting Stock LS1 heads
- Broke crank pulley during cam install
- anyone with R1 cam please read
- Should I go with 112lsa or 114lsa?
- Other than a slight hp increase, why mill the heads?
- gm cams?
- Can anyone decipher these head casting numbers?
- Oil pan question...
- Heads question?????
- Question regarding head selections...
- '02 Burning Oil Bad!
- What else needed (including $) for 4xx ci motor?
- Need to compliment the TR 224 cam with heads
- Question about 5.3L Truck Rods
- How big of a Cam on stock heads?
- Lightweight valves? Brands and costs?
- ARE stage 2, & TR 224-112 is installed, Big thanks to Thunder Racing.
- difference in jwis and reinold timing chains?
- 941's and 01' LS6 cam
- Anybody running this Cam or similar? Inside...
- *VALVE CLEARANCE w/ T1 and mill heads 0.042.....
- B1 cam owners....
- New cam in...... Thanks to Judson and the guys at SAM...
- 4.125" Head Gaskets?
- Spring question
- Need help: ARE valves/918 springs a no no
- High rev engine
- New MMS 229 cam, Any thoughts
- What size cam to go with?
- Few questions for a Stage II h/c setup
- how long is a stock rod?
- stock cam and ported heads
- Anyone have Craig's number (GTP)
- ARP Head Studs??
- Oil pumps ?
- Started ordering motor parts...details within
- 112 better for what ? and 114 better for what ?
- MMS218 or Comp Cam 212/218?
- 00 heads will fit on a 98 right?
- Rocker bolt question...
- 6.0 Stage II Truck Heads vs 5.7 Stage II LS1 Heads >
- Lets talk about heads...
- magnets for the cam swap/ TDC method
- Low dyno heads & cam, looking for direction
- PO342, Camshaft Positioning Sensor ?
- 100 Shot What Next?
- Which cam should I get?
- Are my O2 Sensors Bad :SES Light
- What is causing this noise? (Sound clip within)
- Yesterdays dyno results
- Lets talk about oil
- Stock bottom end ATE itself 8-/
- Cam Opinions with my setup
- Can pistons be notched without removing engine?
- Non-ported LS6 heads and all boltons
- Initial Impressions: TR224@112
- help, heads/cam car hard to start
- Anyone have the SLP Dual Roller Timing Chain??
- rev limiter question
- Stage II Heads and 227/227 .591/.591 113 LSA Cam are In!
- Will hand ported heads be as reliable long term as CNC heads?
- ARE heads + T1 cam = satisfaction
- PARTS TO CARB A LT1
- Misfires normal.....?
- Charlotte, NC Engine shop to do h/c work
- what to gap rings at and torque specs for arp main bolts for 382 stroker
- Paging Joe Prince.
- ? CA Smog Legal 450RWHP LS1/6
- ? about T1 and B1 cam
- K&N FIPK for sale anyone?
- Long Block
- G5 cam dyno results
- Sorry....another "noise" question.
- 382 All-bore for Road Race application
- LS6 Heads are on!!!
- Nebie here, easy answers/questions
- Coolant, what do you racers use?
- Getting a TR224
- how much oil needs to be added to my motor now??
- Flow numbers for my new LS6 heads
- CARB CONVERSION FOR LT1?CAN IT BE DONE AND HOW?
- dyno for TR224 cam
- anyone try the tpis thinner headgasket?
- What needs to be done to the engine so I am safe to 7000 R.P.M.s
- bassani headers
- Where can I get my block honed with the LS1 torque plates? Nearest Cincinnati.
- Quick question about replacing oil sending unit
- Heads milled 0.042, what pushrod length?
- NEED HELP!!! What is the problem?
- Are LQ9 heads center bolt heads??
- Oil pressure sending unit and autometer style guage questions
- Front pump seal keeps failing with my Yank 3500 Converter.
- Trying to choose a cam.. High milage daily driver..
- Lifter Question
- 01 and 02' piston slap cause knock retard?
- Any problems with recessing exhaust valves .028"?
- are valve guides replaceable?
- GTP Heads from Thunder racing...are they worth $2900?
- Oil cooler provision?
- Post your cam cards or cam doctor specs
- engine may be shot....how's the 383 strokers runnin?
- Best Cam for A4 3000 yank stealth stall?!
- Misfire Codes with the TR cam?
- 346ci solid roller cam specs
- Will thinner head gaskets change piston to valve clearance?
- Paging Pro Stock John lifter/ question?
- can you get compression ratio from compression #
- Big Motor Poll....V1.1
- Need help Low oil pressure: not pump
- Head bolts
- Camaro Z28 Jaguar XK8
- Question about "keepers"
- can u run an x-er lobe cam on a 111ls
- How do you check lifter pre-load?
- MMS springs? vs comp 918's?
- Anyone with heads milled .030thousanths.....
- Need some input on oil Preasure Problem
- I give up, NEED P/N for 6.0L head gaskets...
- Dyno Results!
- Have cam sounds but need help!
- GM Hotcam
- Done searchin...help with my Cam
- TR224/224 112LSA vs XE-R224/224 112LSA...which would you choose?
- Help w/ SES code.
- Need help from the experts on big cube engine purchase!!
- Advantage of Jesel Rocker Arms over Stock?
- cam help
- Preluber install
- LT1 383ci - How much am I looking at?
- MN6 or MM6?
- Need help picking out heads/cam.
- What's the Open & Closed Spring Pressures on 918's??
- Would Someone Analize These Dyno Graphs
- g5 cam
- Fel-Pro 0.041 in. head gasket part #???
- When replacing lifters what needs to be done?
- Thunder 227/227 111lsa.....Me thinks I am gonna try it
- cam lsa question
- I have an interesting situation with IAC counts after cam install...
- 875-16 lifters please tell me??????
- A BIG thanks to Lou Sr. @ LGM
- Is this a good cam for NOS?
- Valve Springs
- Dyno numbers
- Anyone run a Comp 212/218 cam? Any Dyno numbers?
- Mustang Dyno numbers? and A/F
- What effect would two degree retard or advance have on my b1 cam???
- Possible reasons for popping under acceleration?
- T1 Cam is in!!! First Impressions!!!
- LS6 or LS1 heads??
- Valve covers
- Addressing poor performance after internal engine work (CHECKLIST)
- Bad #'s from Stage II H/C
- Estimate for Heads and Cam
- 112LSA vs 113LSA vs 114LSA for a daily driven A4...which one?
- GM Hot Cam Specs
- cam spec questions...
- I want my LS1 Z28 to sound like a Ferarri, not a Monster Truck
- Results and Dyno Graph of my new ARE 436ci Stroker
- Best way to bleed coolant system, after H&C install?
- 3.42 gears in a 2002 TA (A4) from the factory!!! check this out!!
- Symptoms of rocker arm coming apart (valve train noise issue)
- Any thoughts on the SLP double roller timing chain?
- What part of custom tuning makes a cam car idle better?
- TR224 and PCM?
- 226/218 Reverse Split?
- TR224 cm,4.10s and M6 question...
- Have TR 220 cam, is it worth it to go bigger?
- Need help...'98-'00 FLP Header owners W/I Please...
- Engine Building Question:
- TR 230/224 "reverse split" cam dyno results
- Are the 918 Springs that mucher better than the 941s?
- Question from a bud!!!
- This cam any good??
- Need spring avice on my upcoming setup...(long)
- Buying Camshaft Kit , need help
- Advice installing Harlan Shift light
- rgr heads
- Tell what all to check before I fire the car up, after head & cam install.
- Which cam will give better power ??
- Total Engine Airflow S1 heads,cam,mac headers dyno results:80 hp gain on stock valves
- I need a no BS opinions
- Ls6 manifold port width spec.?
- Idle set screw question
- Collapsed Lifter Suspicion...
- DTC P0302 #2 Cylinder - Has got me stumped! HELP
- Is a roller bearing cam possible in a LS1?
- can you turn cam over by hand without removing rocker arms?
- which mods are next for me
- VALVES, Ferrea 1.55 ex or 1.57 other?
- Greatest torque "under the curve" > 220/220 .530"/.530" vs 220/220 .560"/.5
- how do i line up the new cam dot to dot?
- Whats the best stock sounding cam??
- TR 224 cam- base circle
- Need a quicklist of diff. gaskest on 97/98 and 99+ LS1's....
- New cam.... what expectations
- Paging Fireball (Brian)
- TR 224 cam S2 heads
- Buying springs/retainers... question
- Any problems with Isky 295D valve springs?
- Your Vote.. Oil Cooler or larger BeCool Radiator?
- Broken 941 valvespring; concerned with possible damage
- ENGINE KNOCK!!!!!!!!
- Where can I get a left side head gasket?
