View Full Version : Generation III Internal Engine
- Comp ratio and PR length question
- LS Valve Train Noise Sucks! I challenge the aftermarket.
- Alum 5.3l Road Race build
- how much rod bearing clearance/ mild build ported pump
- 00ls1 01lq4 combo questions
- Bad cam eats lifter, need help choosing new cam!
- 243 heads
- Heavy smoke, need all info i can get!
- Compression Ratio Help
- Replacing lifters with cam install? PITA?
- Oil pressure at idle going up
- what Head bolts do i need??
- Stuck intake valve ...really???
- Anyone looking for a great cam deal from a sponser....
- Timing Chain broke today, any guesses?
- are my rods on right? HELP
- Help with compression calculator!
- pushrod ballpark
- are these the right spring shims???
- New Valve Spring Break-in Procedure?
- 8.7 camaro ???
- Questions on an LQ4 Build....
- is this block any good?
- whats going on with my spark plug ( picture inside)
- New motor smoking. Details inside
- loud ticking
- LS6 Mahle PowerPak Piston Kit
- Major problem, advice needed please!
- Ls6 243 heads. HELP ASAP.!
- V12 LS, anyone know who made this?
- Valve Stem seal Spring
- Cam Buying Dilemna
- lq4 243 combo tech question - ideal scr and dcr
- Help me think of everything
- Bad thermostat = ticking noise?
- Road Race/Hill Climb 346/347 build
- Which is which?
- LS1 to LS2 Swap problems
- chain slop.
- New build on LS1
- What's needed to do a 5.3 swap in a 4th gen T/A?
- need help with head/cam
- Who ports heads?
- Pushrod Length Question
- lifter ?
- Busted Ls1 Short Block
- 243 and 799 heads
- 408 ls1 ??
- Cam ideas?
- Bang for the buck heads?
- P0327 and P0332 codes
- 1.8 harlan sharp roller rockers and cam choice
- Timing chain and oil pump a must for cam swap?
- Good Result From Small EPS Cam
- Getting a lq!!!
- Lower oil pressure
- Evidence of valve float?
- 6.0? or fix my 5.7
- Valve Spring Micrometer
- Looking for an LS shop recommendation in North Dallas/Collin County area
- H/C combo
- 98 model crankshaft question
- LS6 cam in a 5.3
- Another Cam Question
- Cam input..
- GTP stage 2 heads flow numbers?
- Whats common cause for a stock LS1 to have a vibration???
- LS1Tech Members VS the Pros on Cams recommendations
- LS2 bottom end in an LS1
- Lq9 with 243 ?
- PAT G cam
- swaping engine
- Help me Identify this Cam
- Valve spring questions
- LS1 oil pump volume
- Would retarding this cam benefit me? Cam card and dyno included
- 5.3 oil pan w/ BMR K-member
- Ls6 rollers and pushrods
- GM graphite or GM MLS
- 37 chevy ls1
- 11.5.1 CR + stock 346 =??
- Check out my cam bearings (PICS)
- What Cam? custom or shelf, let the people decide.
- Looking for Local Tech
- Ls1 build questions?
- LSL/XER cam for my combination?
- Need help!!!!
- what sponsor has the best price on patriot gold springs?
- Intake manifold pressure
- ARP bolts needed for spray cam and heads
- LS6 heads on 98 engine...
- Possible oil pump swap ls3
- wiseco pistons and nitrous??
- AES 390 or AES 408?
- Head gasket ?
- TF215 with TR224?
- solid roller cam
- vrx5
- eps 226-234 cam and tfc 215s
- Cam Decision
- How much should I be looking to spend on an LQ4 / LQ9
- LQ4 build
- Cam question
- Cam and head
- Help with emissions cam...
- Re ringed motor and metal flakes???
- 5.3 rattle
- 99' 5.3 With clearance issues at crank
- Which heads to use?
- Heres My Build.... should a do a bigger MAF sensor now before tune or is stock fine??
- 241 heads, porting question
- My car has issues
- Why no gains after head install?
- 98 ls1 block????
- need cam help
- 5.3 heads
- Futral F14 or MS4?
- truck pickup = 1 bolt... fbody pickup = 2 bolts?
- comp cams double springs #26926......question?
- Some good vendors...
- AFR heads
- 2002 trans am idle hang 4.5k
- do i need a breather on valve cover
- build thoughts
- Cam Help
- Who has broke 700rwhp
- Smoke... Help please!
- oil leak/consumption
- ls1 camaro
- Torquer v2 on a 111LSA with 6.0 and T56
- LS1/BMW Lower end knock
- 2.02 valves on a 5.3?
- what coolant
- 5.3 cam choice
- Help With Rocker Arms
- Cam Clearance ?
- PRC stage 1 heads (or the springs off of them)
- Bore to piston clearance??? Help
- rebuild kit, cam. need advice
- Cam Dillema C5 Corvette
- 243 and 799
- LS1 or LS2?
- Have GTO. Have LS6. Give me some ideas.
- Oil Pressure too HIGH?
- Once again another compression question....
- stroker, rods hiting windage tray.
- will i get piston slap?
- Flow bench on Long Island?
- What do you guys think?
- rebuild or new engine?
- need help deciding what heads to run...
- RaVagE's TFS/RAPTR Build Thread
- ECU with EGR Delete
- Valve train noise,but only at part throttle(2000-3500rpm)
- Turbo Prep/info on my ls1 f-body
- 408 question? please help.
- which cam for what i want?
- Input on 98 TA setup
- What is this hose?
- 02 WS6:AFR heads and stock rockers?
- 110,000 miles...can I cam it?? Which one?
- Uhoh project time and a long weekend
- While I'm in here, I might as well...
- 241 exhaust ports (pics)
- Katech's new VISION, LOGO, and 100-PAGE WEBSITE + secrets revealed!
- LS6 Heads vs. Stage 2 LS1 Heads
- 408 build need some sponsors to purchase from
- Whats head on a Lq9
- Best Heads for a 408 ci
- Which of your springs broke?
- decking 853"s???
- Did i buy the right cam?
- 2009 and older - GM Service Manual DVD - $20
- ASA cam whos got one for sale?
- Help me install these new ls-9 head gaskets correctly. This Time
- Whats wrong with this picture?
- Recommendations for cam bearing puller/installer?
- no head markings?
- Head Studs/Bolts in General - Aircraft Grade?
- double roller chain clearance issue
- Part name
- Very little oil at rockers. Lots of valvetrain noise.
- My 2000 Camaro, First Build
- icon pistons has anybody ever heard of them??
- problem after cam swap
- Question about comp roller rockers
- Need help identifying these rockers and springs *LS newbie*
- F Body sump, baffle for circuit racing?
- cam
- Anybody sell new rockers with trunion upgrade
- camshaft postion sensor freez plugged WTH??
- Basic gen 3 info
- is this cam to big for dd
- Anyone used Comp 273Lr HR12?
- What Would A Shop Charge To Put In Connecting Rod Bolts?
- Quick head disassembly question...?
- steel head gasket in 99 lm7????
- Dart Pro 1 Heads
- Help lq4 swap issues
- LG G5x2 cam owners what pushrods
- Timing chain loose then tight. WTF? Help! Video up.
- How fast do stock lifters bleed off?
- 1.8 rockers and .030 decked 853 heads? and miss fire question
- LS4 oil pump ??
- What year are my 317 heads?
- stock bottem end ?
- Looking for head to match cam .
- white smoke from exhaust
- Please help, Lifter? rod knock? see vid
- Mild Cam for a Full bolt on LS2
- So Is this the "Ticking" time bomb noise or what?
- Push Rod's?
- Push Rod's?
- Best springs and pushrods for this cam
- Llifter tick and misfire on 4/6/8 only in gear..any ideas?
- Comp 925 duals vs. Patriot "Gold" duals
- timing chain ?
- forged rods/pistons for my stock ls1?
- 05 lq9 motor
- how do i measure clearances?
- what rods, pistons, rings for nitrous build?
- 383 Worth It
- How to make more power
- LS6 PCV Restrictor Size?
- Help! Crank only turns 180°
- catch can?
- Possible Cam For A L33
- Texas-speed stg 3 ls6 heads and cam
- Used Prc double valve springs results
- Stock main studs?
- need some help on head and rod bolt torque specs!!
- help with 427 build please
- g5x3 or tru torque level 4 cam
- Differences between lq4 blocks
- valve spring id?
- 5.3 head swap worth it?
- Rods hitting camshaft? Using LS3 rods... Help needed...
- Narrowed it down to a few cams...
- Cam advise please!!!
- what cam?
- what to do
- bore .0005, or leave #1 cylinder .0001 larger?
- Low Oil pressure EPIC pursuit
- Where to buy titanium retainers for beehive springs
- need a little advice !!!
- can't crank motor over
- OK guys, serious tech question
- Dipstick is stuck in the tube
- Lpe gt7 cam question .
