View Full Version : Generation III Internal Engine
- Heads that flow well on the exhaust, or intake? Which is better?
- How would ported 5.3's or 243's with TSP giant cam perform in a 408?
- Anyone running a Tick Street Heat cam?
- Attention all gearheads need advice
- Replace those stock lifters!
- 230/234 112 + 4 idle clip
- Tubo 408 build, cam suggestion?
- Cam selection help
- Lookin for a sound clip..
- Intake Removal Question
- Could you please help me with pushrod length
- general Ls6 lifter cup question
- Anyone used EPS's LS Single Plane Cam
- honest oppinions please
- Spark plug gap question
- 4.8/5.3 genIII question?
- What kind of rockers should I run with PRC 215s with bronze guides?
- I talked to 3 sponsers...4 cam options to choose from. What would you do?
- Need some cam swap injector help
- stealth/ small cam thread
- Engine lift plate template or basic measurements anyone ?
- 383 questions
- Are these overpriced?
- LS1 Rocker Bearing broke, what now?
- gen iv in a 99 TA
- Random Misfires on Cammed Trans Am
- Help Diagnose this Exhaust Smoke
- C5R chain or double roller?
- Am I missing something?
- what weight oil?
- 5.3 rocker arms
- 5.3l biggest cam install
- ughh flycut or not
- Oil pump?
- Need Help Deciding on Idle for Tune
- Heads and milling question
- lq4 questions
- ZR1 crank in a LQ4?
- Need quick help
- Piston slap after fully warmed up
- Vic jr, Proflo xt or something else?
- Wrecked 5.3L (Engine Autopsy)
- Valve C. gaskets blew out. HELP
- ls1 vetter with ls6 top end what all is needed to do the swap right??
- 59cc Heads?
- ETP 215 Head's??? Anyone Run titanum valves???
- Wich head gaskets should I get?
- 2000 SS SLP input on purchase
- 02 LS1/T56 45,xxx original miles (whats it worth)
- Hot idle knock
- stock shortblock lq9 build, prc ls6 2.5 head or ?
- Heads on cam degreeing
- Comp XR269HR-114 for 5.3 questions
- needing a little engine build guidance.
- my LQ4 build plans and a few ?'s
- People w/ EPS cams, post your setups
- Head Options for Mild Street Build (Ls1)
- Pushrod Length Suggestion
- timing chain question?
- Time for some winter upgrades/suggestions
- Cold engine start up Tick. LS1
- Long hot starts
- 408 rattling noise. Long story but would appreciate your input.
- 5.3 Truck Cam Question
- Recommendations LS6 build
- Ordered custom cam surprised with new specs but looking forward to how it runs
- 5.3 to 5.7 ?'s... Mostly hp & reliability..
- Dropped Valve resulted in serious carnage
- 00 SS what do you think
- Odd oil pressure
- 6.0 lq4 bad vibration
- Harlan Sharp SLS17 Users Questions
- Stage 2.5 PRC Heads Help!!!
- ~230+ cam with shorty headers & no cats? Who has done it or has results?Overlap okay?
- gas mileage
- What Models/Yr's are 243/799 heads on?
- Could this be bad valve seals?
- Does anyone have experience with ProPower Performance?
- Fast 90 Intake
- Major oil leak!
- Replacing my 5.3 crankshaft what needs to be done?
- My reverse split tr230 cam and budget heads?
- Melling oil pump rebuild kit??
- Motor not starting after ice storm, Starter? HELP!
- MAJOR endplay problem?
- ls1 oil pressure ???
- LS7 crankshaft in LS1
- Piston slap teardown
- need help setting Wipe and preload.
- Lq4 no oil pressure
- LQ4 Block, GTO Oil Pan, which windage?
- rotating assemblies best bang for the buck
- Misfire problems. Please help
- How much do you gain with hollow stem valves?
- Replacement Heads for LM7
- Crank pulley installer tool
- LQ4 W/Eagle H beam Question
- Can overlap increase octane tolerance?
- will this timing chain work
- Cam recommendation?
- Opinion needed on Ferrrea Valves
- Chain Damper
- 408 need plan checked
- Why is the clutch making this noise?
- waking up an ls1
- Critique my LM7 build
- Ls1/Ls6 Pistons?
- lq4 gasket question
- Anybody use Same Main & C-Rod Bolts on rebuilt eninge?
- 799 milling
- 2002 8.1 in foxbody?
- miss fire
- Will I need to flycut? (EPS Cam, TEA 5.3 Heads)
- Lq4 swap plans & problems
- Ls motor help!!!!
- Pulley Damage, would you run it?
- LQ4 Cam options
- best driver cam?
- How much can you mill before intake issues?
- ls9 cam dyno results lq4
- LS1 3D CAD for SALE!
- LS6 bottom end?
- Shaner S3 throttle body
- 262/250 555/534 106lsa
- Help! Metal parts in engine oil
- 2002 LS1-what trans to use 4l60e or 700R4
- Little help for this WS6 Noob??
- 0 oil pressure... NEED HELP FAST!!!!
- Should I buy this Fast intake?
- need help im planning a 5.3l and 4l80e in a 95 suburban
- Brian Tooley Valve Springs???
- PRC 227 Questions?
- Crankshaft q/a
- 2004 GTO ls1
- LS7 Lifter & AFR Head replacement w/ Super Vic???
- ls2 timing chain question
- Has anyone seen a spun rod bearing using ARP rod bolts?
- Lifter replacement necessary?
- Head Gaskets???
- Help getting over 500rwhp, Stock Cubes
- water temp sending units
- Heads/Cam Supporting Mods
- Milling my heads need comp ratios
- Really strange sound..
- 6.0 motor question
- 2001 camaro ss running lean ? Help
- piston resistance
- Whats my options? Collapsed lifter/valvespring 116,000 miles
- Hawk's Sinister cam?
- F body camaro 99 flywheel weight
- Best Driveability 230 Duration Cam
- 12576400 lifter work on ls1?
- Arp head bolts or studs?
- Engine Machining Prices, reasonable?
- 15xxxx ls1
- Ptv??
- Australia is hard to find what I need
- Flycutting pistons and nitrous
- Is aftermaket heads worth going to vs. stock worked
- Question about heads on my ls1...
- LS6 cam swap
- Quick question
- new to these engines but not chevys
- Tapping sound on right head...
- ever wonder what inside your cylinder looks like
- what is this weird substance under my oil fill cap ???
- TFS Head spring work on stock casting 241's?
- LS7 Lifters - Correct Push Rod Length
- higher duration?
- 102 intake w/ ls2 tb ? HELP
- LQ4/9 part numbers
- Reinstalling the drivers side head on my 2000 WS6 T/A question.
- I need help chosing my cam.
- Any problem if using PAC Beehive Springs with this TSP cam
- Water in oil pan and oil in exhaust after 5 year nap
- valves, how big can you go?
- Can pistons be bushed?
- 2005 6.0l build combo questions
- rod bearings for resized rods
- cutting valve reliefs
- Measuring to zero lash with 1.7 rocker arms. Questions...
- Any exterior differences in LQ4's
- Oil pressure....
- Should i swap these parts...?
- Wtb asa cam
- Comp pro magnum rocker issues
- My MAMOFIED 416 N/a Stroker Build!! (powering a 93 Mazda RX7)
- Rebuilding an engine
- ls7 lifter???
- ls6 ported heads
- 241 heads on 5.3?
- comp cams shaft mounted rockers on AFR 205s clearance
- gas mileage questions
- questionable intake valves
- Pushrod help
- L33 rebuild
- LS1 HP Increase ?
- Experts advice wanted: Does anyone out there use Crane Lifters on their Gen III?
- Lots of oil on spark plugs
- compression
- threw a rod what to do?
- 2000 ls1 conversion wiring
- Code p1518
- Cam position and Crank position sensor o-rings?
- Ls1 pilot bearing switch
- Water Pump
- Best heads for a max effort stock bottom end nitrous car!
- Anything else needed for cam/head swap
- LQ9 swap; rough idle problem... need help diagnosing!
- 4.8 ...... mti c1 hammer cam
- I wonder why everyone uses YT Rockers? Why not Crane?
- 4 inch crank into a ls1
- How much power to be made by...
- texas speed coupons or discounts
- Ported Stage 1 LS6 heads, good daily cam around 400 rwhp
- cloyes single roller vs Rollmaster double?
- 5.3LM7 with TSP 224R ??
- LSx Oil Pan Spacers
- Need valve spring help??
- New cams from Tick Performance
- 5.3l etc help!
- bad lifter
- is this deck ready?
- Help Car Will Not Start
- T&D Shaft Rockers
- How much spray safely?
- Continue chasing noises on my LS1 with 155K or rebuild??
- 408 with 11.7 compression, 93 pump gas friendly or more ocatane needed?
- Upgrading cam - NEED OPINIONS
- 5.3 heads on 5.7 ls1, coil pack question
- RHS 450cid with AllPro Heads - 2days to Install
- Ms4 results
- Compresion Ratio
- quick question
- info Lunati camshaft
- Quick Question on Diamond 11502 Pistons
- Can anyone tell me what these are! help! Pics inside
- Main bearing bolt hole stripped how do I fix it.
- 6.0 Block Identification
- Cam advance ground in
- 5.3 to 5.7 is it worth it?
- what oil pump and timing chain should i run?
- 853 head cc's question
- Valve spring help! please
- Can I use Manley Nextek Springs I have on an MS3?
- Supercharged 383 Build
- push rods question
- Need help on first build
- How far can you bore a LQ4 block?
- 5.3 crankshaft
