View Full Version : Generation III Internal Engine
- F13 or F14?
- electrical problem? or is it blown engine?
- Any sponsor dyno preproduction Darts...
- 5.3 Heads????
- 112 LSA F13 who have a professional tune..
- Head torque order
- Patriot Heads and Cam????
- Valvetrain gurus ? about geometry
- Temperature Gauge Not Reading
- cam for 205 afr
- Oh no-another will this cam clear question!
- How much lift can I do without changing springs again?
- Rod Bolts
- LS1 complete engine project
- will lifters cause misfires??
- perplexing problem
- GT2/3 cam and GMPP LS6 heads
- Where to buy all thread for crank
- possible to run 120MPH N/A? (what heads/cam?)
- Hey, anyone running with a TRex cam?
- NO COMPRESSION....wtf?????
- Sponsors with Cam Doctor?
- 5.3L Head and Cam Questions
- Should I swap cams?
- Cometic Question
- Thinking about ordering! NEED HELP?
- has anyone here built a 455 ci ls1?
- ses light only on high rpms, speed?
- Other ways to hold flywheel!?
- Cluster lights
- help, i have a question that i need answered
- Candy Futral MS where are you?????
- Anyone running the Tr 230/236 cam?
- running with out lid
- Cam Recommendation afr205 fast90/90
- Question: Under Heavy acceleration=check gauge light comes on?
- oil pressue question, extremely high
- CR w/ my setup
- Leaking oil after rebuilt shortblock
- Timing properly
- Oil pressure Question
- fm-15 soundclip
- which direction? H/C or FI?
- problems with 6.200" rods
- TRak cam
- Best "Bang for the buck" heads for my setup
- What to expect from this H/C package?
- Finally True Stealth
- 5.3 forged?
- What's the real deal with strokers
- Anyone got Dyno results on F13???
- Offset LS1 crank question
- Tell me about the Z06 cam for a trans am...
- O.E. pushrods- Anyone have part the part #
- "Re-training" the ECU?
- block casting?
- SLP 250/246 .596"/.596" 114LSA?
- best combo of price/quality for a forged short block?
- 6.0l stroker parts
- What's the most powerful N/A set-up for an LS1?
- Oil Everywhere...Leak....
- length pushrods for .030" milled heads?
- Car Won't Run
- why do TR224 112 have more valvetrain noise than some bigger cams?
- No oil pressure, help
- what sensor is this? *pic*
- help with head/cam decision
- 46MPH hesitation
- Oil pump removal? Help.
- Help!!
- pulled my F10, now im looking for a cam to get me..
- Last minute questions on Engine reassembly?
- Thinking of replacing cam, need thoughts...
- Can I spin 7k
- Surprise when I changed my oil!
- Does this sound reasonable for a cam swap?
- which package to get with cam
- Went to the track after mods
- loud ticking...
- 408 compression ratio
- Coates Spherical Rotary Valve System
- H/C swap on to 5.3 truck
- Got my PRC's, what do you think, 56k beware
- just got new ls6 heads but something doesnt add up??
- No Water flow
- ASA cam and lope and loudness
- Who all has gotten the JWIS timing chain?
- Life of a stock rocker?
- cam swap help what is NECCESSARY!?
- HELP: Keep the G5X2 or get the HPE S?
- Is anybody running C5R heads in thier F body
- What rings would you go with....
- Valve train geometry question
- Just Talked To Dart.....
- 850+rwhp internals?
- Head/cam installer near Savannah/ Hilton Head area?
- Diamond Pistons Rings
- Rockers galore!
- Help me calculate my compression...
- Bad original cam choice..what now?
- which heads ?
- Question about replacing valves on BN LS6 head?
- Cheatr Package
- LS-7 heads on an LS1?
- Starting to gather items for a Cam Swap what must be changed?
- Torquer II, PRC 2.5's Results
- WARNING! Cam Retainer Plate Wear
- PATRIOT CAMS? GETTING SOME BEAT NUMBERS>>
- Gold German Castrol Syntec 0w30 Oil Analysis Results
- 2 Questions power and a tune?
- help problem
- 98 crank vs. 99+ crank
- bought a cam today got some ?'s
- Any update on the new aftermarket blocks?
- Need some help with New APE shortblock!
- weeding out an IMPOSSIBLE problem.
- valvetrain issue.. please look inside and help if you can
- just found out i can get machine work for free, what should I get done to ls1 heads?
- cam retainer plate wear
- ATI Damper Installation
- Cam Bearing question
- Valve cover spacers
- anyone experience MORE piston slap with German Castrol 0w30?
- Some Problems with my car...
- LS1 Hot Cam & LS6 Heads Question
- Stock 2004 GTO valvesprings?
- any differences between 01 and 02+ ls6 springs?
- how big can the ls1 go??
- what heads to get for a 408 forged.. with a procharger
- LME's motor building reputation
- LME's reputation?
- Storing Engine Block?
- is it possible to make a 455 ci ls1
- 5.3L Stock Head Flow
- Noisy Valve Terrain
- titanium spring retainers - worth keeping?
- Best way for checking piston deck height?
- LS1,LS2,LS6 heads ???
- does cam size really affect mpg?
- Big Problem
- TDC Method Question
- Who to use for engine coatings...
- ZO6 valve springs suk?
- hows this setup for my future 98 z28.
- LS-1 350 => 408
- head gasket size
- old 918 springs
- ZO6 heads Flow ?'s
- increasing duration, Crazy idea that came to me
- Pushrod questions
- Total seal piston ring questions
- Morel lifters and valvetrain trouble
- Diamond Piston?
- Cam Help
- Quick head removal question
- what cam to go with?
- Dowels for Cam Swap
- is the aluminum Slp ZL402 short block a good stroker block
- Thoughts on custom build...
- Anyone have Quicktime Cam Cover?
- ls1 heads on lq4 block
- The 6.0 lntake
- 112 vs 114 LSA - Difference?
- with ls6 valve springs
- Should I replace my stock oil pump?
- Anyone use et performance heads?
- Anyone daily drive HPE "S" cam
- Pen Magnet Question
- 918 cheap
- New Cam guessing game
- Valve tap after switching oil?
- Cam with high mileage.
- D1sc blower on a Lingenfelter top end kit???
- which heads should i use on my 427 ls1 motor
- Comp 918's with FM 13 Cam
- LS1 vs LS6 heads w/ LPE GT2-3 cam
- short block from Racetech problems
- which springs should i use
- z06 cam?
- After cam install lifter tapping
- engine ?
- New cam for my Z06?
- oil pumps
- How high in the RPM range with this Cam?
- Finally ordered my 408 Shortblock
- mti X1 cam or LG G5x1 which cam is better?
- Tea Afr S2.5
- New Curtis shaft rockers
- Torquer II Cam is in! Initial Impressions...
- Go big on an LS1 or LS2?
- yes this is a serious question...
- Its Sept 7th,Wheres the Edlebrock Heads?
- 500Hp out of a Ls1??
- What are better pistons than Diamond forged?
- Any advantage of Iron block over aluminum?
- Change Rocker Arms?
- Blue smoke?
- Lifter question?
- Long block assembly questions.
- Getting Cam, What Computer Mods Needed?
- Comp Cam beehive springs ???
- Squeeking Noise Coming for the Engine?
- 406ci?
- C5R engine block ..owners please come in..
- In car LS1 valve spring change
- REV double springs - any issues?
- Hydraulic roller 402 w/ healthy cam
- Need help
- new cam/springs/retainers in and maybe revved too high?
- F13 cam and mild heads installed - car doesnt feel very fast
- Help Guys!
- I think I might have gotten screwed!Help!
- How do i check how much my heads have been milled?
- Stealth cam owners......Need help!
- Valve tran noise after H/C swap
- Thoughts about topend cleaner
- Gas,
- Dart LS1 heads
- Pushrod Length?
- Still backfirig-nothing on scan
- New setup...opinions?
- Patriot heads
- Before you dismiss reverse split cams...
- What kind of heads are you running w/ your f13-14
- Who is running an aftermarket cam with 1.8 rockers? Lifter problems?
- G5X4 cam for 408 or another cam?
- Any particular reason not use the smaller Darton Sleeve?
- Torquer cam, which heads to run?
- Cams and stock valve train?
- timing chain z06 vs stock ls1
- Another question on TDC?
- LQ4/th350 questions.
- Zero Oil Pressure at Start up - New LS6 Oil Pump
- Cam it or Spray it?
- 2001 Ss
- Which cam for my '67?
- 02+ ls6 cam question...
- 224 224 112 lsa
- How many use a micrometer to set up the valve springs?
- Recommendations on Mods??
- my impressions of the futral fm14
- Rear Main Seal Install question
- Started cam swap...here's how it's going so far
- Looking for some cam cards
- can it be done....
- 6500, Good redline for 918's?
- I have Junk 6.0 engine. What can i make use of?
- Couple Noob Piston Q's
- brake vacuum problem after MS3 install
- hows this setup sound???
