View Full Version : Generation III Internal Engine
- Decided to change my cam with the new combo
- 12 Bolt Is Dead, Opinions & Gearing Help Needed
- Trany jumping out of reverse-M6, Adjustment or What ??
- Swapping Fuel Pumps...Hard or not too bad???
- SLP dual/dual & Borla......
- ASP pulley
- Rebuild parts
- valve breather Question
- A.I.R. air tube restrictors > Needed with Hooker Headers?
- So with the TR-55 plugs, a .050 gap will make it idles rougher?
- How much Horsepower Will Slp LongTube Headers Give Me?
- What causes this?
- Aftermarket 1.85 Roller Rockers: Are they worth it?
- need cut out opinions
- Getting 2 1/2 degrees of KR, how bad is that??
- HPP3 and a cam?
- flp cats or no cats????????
- anyone feel a difference in octane boosters??
- Dynatech step headers for dRagULa
- Question on next mod !
- LS6 Intake question about EGR
- Which of these Parts/where to buy
- Will a low IAC count of 3 cause a higher idle speed?
- Spark Plug gap??..some quick help Please
- Help me decide. Order SLP headers now, or wait for Hooker to come out with a y-pipe?
- Holley LS1 Intake in stock at Thunder Racing
- NineBall....a quick question
- 8.1L motor ?(everyone read)
- ? about 2 quick mods i can do today
- Anybody have a Vortech Supercharger in their car?
- Comp 918 spring and stock cam....
- How much "Slop" in your timing chain?
- O2 exstention ???'s
- Can someone pull this site up and hook me up with their phone number!
- anyone know part # for pace EGR and AIR block off plates???
- Where's my pressure regulator located???
- Dyno results stock, lid K+N MAF ends and cutout.
- battery dies after one week
- Those with LT, ORPs and MAFT please help
- Cam install today need some help
- How often should i change my TR-6's?
- Volant air intake
- IAC count ?
- Converting to LS6 valley cover setup, need P/Ns!
- so, ported maf is good on a 98?
- 98-02 stock cam specs
- Chambered vs. True Dual vs. Single Exhaust
- What hp difference will I notice?
- Dumb question - what does "blueprinting" mean
- Ticking sound upon startup question....
- IS GUTTING THE CATS WORTH IT
- MAF / MAFH Questions
- Broke spring, Please help!!
- What's the difference between MMS stage I and stage II heads?
- HPP3 out for 02 cars?
- What is the part # for a pilot bearing?
- SLP Dual dual vs stocker
- Should we be concerned about our LS1/LS6 blocks....read within..
- turbo question
- Hotcam/macs First Dyno #'s for me...
- Putting 98 injectors into a 99 LS1 that's already tuned w/ LS1edit??
- EMISSION CONTROL QUESTION
- Stock head differences
- Car height for header install
- Whatever happened to the JPR EWP dyno #'s?
- Sprayin a 01 with a 5177???
- Thoughts on TR 220/114LSA cam???
- Will running ope?n headers hurt the motor?
- Amosil oil
- HELP!!!!!! What is wrong with my car?!?!?!
- coil packs from 1997-2002... are they the same?
- Shifting at 6800 on STOCK heads!?!?
- 1998 Injectors
- What makes the LS1 run rich after cam and header swap?
- Hooker LT's are in! Open headers sound goooood!
- Need exhaust advice...loudness, etc.
- Question?
- Which heads to port:5.7 or 5.3?
- Hmm is it time to step off the curb?
- MMS 229 cam specs?
- What paint for intake mainfold?
- Finally doing headers...
- Engine Surge?
- Lets talk about Load
- rocker arm question????
- TR6 Plugs: Any Advantage for High Compression Motors?
- MSD Shift Light
- Questions for big cube motor owners
- Thanks to Thunder Racing
- Are these times about right for my mods?
- How do you degree in a cam?
- Took off the oil filler cap and......
- need help! making spark plug wires......
- In the middle of installing my Hooker LT's, gotsta kestion!
- Help Mike Morgan(Or Anyone)
- The old crackeregg technical info site
- Finally the 382 stroker is in!
- ELECTRICAL experts, PART 2: Weird result, but good news "I think"
- Next mod adding
- New Direct Flo Lid's tabs wont stay in place...
- Modifying the Grot Y-pipe....
- ISKY 295 springs - what's the deal?
- Engine Detonation???
- Pace 85mm MAF with screen vs without screen
- I need the BEST FLOWING exhaust possible.
- MAF Screen Removal = KR???
- Best Price on-line for #93009 Carsound CAT's?
- New LS1/LS6 block vs old LS1 block and resleeving
- Oil Change Light Help
- How does one determine what Comp Cam lobe...
- Who has the LS1 with MTI 422 for sale?
- ST3500 Question
- Evan's coolant?
- Exhaust system... Single vs. Dual
- Making mods purchace today...need opinions
- Rocker arm bolt thread size/pitch
- S2 H/C info/help needed
- oil pressure
- Corsa Exhaust is giving me some problems...
- SES light
- 382 and fuel (injectors)
- service engine code 0156....
- Any word on Hookers y-pipe?
- No more bolt on, ordered the T1 today.
- Flow bench using a 4.00" vs 3.9" bore size
- Air Control Valve?
- Custom Cam is in...what do you guys think?
- What technique for M6 launches with...
- My next project..... give me until September 02' for the release.
- Pics of dual exhaust, going over the axle.
- Chambered vs. Borla or Dynomax Muffler?
- Will a WS6 lower air box fit underneath an SS hood?
- If you've had MULTIPLE EXAUST SYSTEMS.....
- best flowing exhaust? true duals or y-pipe and catback?
- Drag radials in 275/40/R17
- Strange stuff after header install...
- Comp. 216/220 525 and 114 ls w/ stage 2 heads?
- Does anyone make a deep oil pan for our motor?
- Low Coolant Light On -- Help.
- Knock Retard Question PCM Experts!!!
- Another p/n# request
- Do we have any ELECTRICAL experts among us?
- Newbie just ordered Bridgestone Potenza RE730s...
- nitrous which one dry or wet
- intermediate pipe on Z28 and SS
- What are some signs that my posi is going out??
- Question regarding my brother's TA
- FLP Collector Vs. Flowmaster...
- how to make ta fog lights stay on w/ hi beam?
- need some help with S.E.S. codes!
- Part #'s for Crossover pipe and coolant plugs???
- Any problems related to true dual exhaust
- tranny problems
- Pics Of Dual Exhaust?
- random tech Y pipe w/cats
- ? about y-pipes & Flowmaster collector
- LS6 Retainers = LS1 Retainers
- Looking to compile a list of 'how to' links whatcha got?
- Ordering Y pipe material right now, 2.5" or 3" on cammed car?
- Guys Who Know A Little About Cars Help Me Out Please!!!!
- banging in rear end
- SLP 2OTL (two on the left) catback owners/knowledgeables inside please...
- '02 OE Thermostat Rating
- LS1 Motorsports - New Location and Expansion Details
- What cats should I put with Hooker LTs??
- Catolitic converter&Exaust dump
- MTI T1 Cam, Isky springs...
- Should I clean up the ports on my Hooker LT's?
- bosch platnum +4 plugs
- False Knock?
- Part # for oil pressure sensor?
- Opinions on next mod...
- ******Paging Team ZR-1 Oh ATAP Master********
- Hooker LTs
- cam install ?
- Help, who to install????
- Want to make a Meziere electric water pump work on your car?
- New BIG brakes ordered today.. :)
- How much HP gain with CF driveshaft?
- Hooker LT problems, HELP!
- Cheap stroker cranks?
- Direct Flow lid, what color?...
- Which shift kit should I buy for my 99 T/A
- LS1??? Help if you can??
- First post.. Looking for cam swap ideas
- Moroso Spiral Flow Muffler?
- HP gains w/ ZO6 intake & ASP crank pulley
- switching from Hotcam to T1
- header gasket part number
- Cam swap for max 409 power!
- Exhaust after headers & ORP install...
- Cheapest place to buy NGK-TR6 plugs???
- Giving thanks to MTI
- Borla or loudmouth +MAFT
- Is this hurting my set-up?
- Holley Intake
- Part numbers???
- Any experience with Edelbrock headers?
- Removing AIR system
- Ignition Timing Vs. Compression Ratio
- Someone help me Diagnose
- need help Installing oil pump
- bassani headers finally in..
- Which lid makes the most power?
- Motor build up Q's.....
- Need a Driveshaft Loop, What kind?
- Quiet good flowing muffer, which one?
- Possible ideas as to why chunks are coming out of my motor???
- Cam Degreeing Necessary?????
- Few questions on SLP Headers.
- Compression question?
- Need help putting back on stock pulley
- Inside Car, where is 12V switched ?
- Knocking sound...what the heck is it?
- need help on mods
- How long to do head work?
- follow up on the PCV fix....
- Fuel system with return line worth it?
- Stage 3 Heads Overkill on stock shortblock?
- should i put a breather in the valve cover? help
- Question about Hurst shifter
- Are bigger injectors needed with heads and cam?
- Help with Truck Heads
- Results from Dynatech longtubes, true duals, and a lil LS1 Edit tuning.
- I just ordered LG G5 cam!
- Interesting Grott-Y pipe and Mufflex Dyno information from my car at MTI
- aftermarket tach questions
- Just won $600 on superbowl, what mods?
- Pic from Ennis 2/2/02......Just testing
- Any dynos with Hooker LT's yet?
- ignore sig test
- Piedmont area DYNO DAY
- Who is running a Cartek heads/cam package?
- Question on 3.5 inch intermediate pipe
- torque specs and sequences question
- How Long is This Bolt?
- PN's & $'s for '02 LS6 Top End Parts
- What can I expect From this?
- New engine: Break-in before dynoing?
- engine spec questions
- Need Help Please
- TSB's
- How much do SLP LT's add?
- Comp Cams Question?
- Oops, need one more p/n
- need the website where they show how to port throttle body!
- EVAP system?
- Anyone descreen an 85 Slp Maf or Pace maf?
