View Full Version : Generation III Internal Engine
- What is this broken part?
- oil pan
- LS1 Oil looks like chocolate Idea?
- What springs do i need?
- HEAD Opinion plz help needed
- tsunami and stock 98 heads?
- opinions on head/ cam combo??
- Edelbrock ls1 water pump info.....
- comp type r lifter length diferent over stock?
- ls2 timing chain waay too much slack
- Gaskets for cam swap
- Need help picking cam 87 rx7 lq4 4l60e 4.1 etc
- Replacing rack and pinion, whats the difference
- heads swap from ls1 806 heads to a 5.3l heads
- Quick tranny fluid question. Yes I searched.
- Cam and tune Question.
- Help me asap, ring install Q's???
- compression versus flow?
- CamMotion
- arp rod bolt torque
- ls1 valley cover gasket
- Installing some LS6 valve springs and have a few questions.
- Question about changing oil.
- HOW TO: Calculating static compression ratio(long post)
- 243 x1 upgrades?
- PRC 237's ?
- scared to get a cam and dyno
- Ms4 camspecs and drc!
- Guys running ebay headers come inside.
- Valve spring max lift? To much coil bind?
- Looking for general recommendations and info
- chip in head
- Mustard in my oil cap?? WTF
- slapping AFR gauge.
- guys with228/232 .588/.595 how many hp gains
- help needed with cam choice and id
- need ASAP knock sensor seals
- Ragin Racin C5 Built 383 ECS Novi2000 800rwhp*Vid*
- convert ls1 to dbw!?!?
- HELP!!! Need more power on my LS1(camaro z28)
- Easy balancer install bolt
- which valve springs and pushrods?
- Wondering about reusing original low mile lifters on H/C
- Curious as to what I will put down
- Ls1 Vs Ls6 crate engine
- Comp Cams "Comp R" Hydraulic Roller Lifters
- LQ4/t56 quick question,couldnt find the answer anywhere.
- Oil pump....?
- LS6 timing chain question
- shops for a cam install
- ls1 heads
- Head swap with no dyno gain...what's wrong?
- What would you do next if you where me ?
- stock weight ne one
- Head milling question
- Another "help me pick my cam" thread
- Stuck Cam
- 232/228 limit.
- DIY two piece stock timing chain cover
- Go with a bigger cam or no?
- need help with picking cam for lq4 with ls3 heads and intake
- Crane Cams
- Head question
- intermitten smoking issue?? need thoughts
- lifters or pushrods???
- 01 241's fit 98 LS1?
- who runs patriot ls6 heads?
- Spark Knock
- Comp 926 Springs
- using a yank py converter
- buying used oil pump
- LQ4 questions sorry
- couple questions?
- Trying to figure out my CR (HELP)
- Lq9 with L92 setup what do you think?
- Reuse of stock con rods?
- best option f0r 130k ls1 motor
- motors
- Rocker Arms
- What plugs to run on modded motor
- ls6 heads and ls2 heads the same?
- Torquer V.2 too small for a 408?
- Ls1 Cylinder Hone DIY
- ls6 cam for 00 transam?
- Need some help with my fuel setup on my HCI project
- 414 with 72cc heads compression
- Going with bigger cam... Need advice.
- 317 vs stock heads
- setup help please
- Comps LSr cam
- cams with little to no lope.post vids.
- Most likely a stupid question but.........
- HP Estimates?
- ballancer bolt
- more ls7 questions
- 651/657 239/247@.050 on a 109 LSA
- need input on a cam for my ls1
- what tool are you using to change the valve springs without pulling the heads?
- should i change teh cam chain? 30,000 mile 2004 lq9
- 6.0 vs stock ls1
- Trigger finger is itching for one of these cams
- Ms4 Cam Piston to Valve Clearance Problems?
- Visual differences between LS1 and LS2 timing chains?
- Engine knocking on cold starts....?
- LS2 and LS6 heads the way I see it
- 5.3l compression
- Power difference between 5.3 and LS6 heads
- F/S New Comp Cams Timing Chain
- 6.0 power estimates???
- high ratio rockers question
- ts 233 239 valve springs
- HELP !! LS1 H/C swap(Block Issue Also =s !!)
- Looking to get close to 500 with 5k
- Iron block 427 6.0
- Best header gasket?
- Trex RWHP numbers
- Cam lobes explained
- Quick VS Kit swap questions
- head cam question
- Is this an issue?
- Going h/c have q's
- On the rocks.
- is this true that a ms5 cam might be coming out?
- heads for 99ss
- Just Installed H/C/I and Injecors-Can I drive it 45 miles to get tuned?
- Specs on new LS1
- El Torro Setup?
- 01' Stage 3 SLP head identification help
- a few ?'s on the ms3 cam
- Post up your 228R videos!!
- cam question
- Water leaking when poured over combustion chamber
- Timing chain question
- Novice questions regarding LS1 buildup
- Valve train noise with Comp xtreme or Voodoo camshafts
- Ls1 or ls2
- Valve Spring Shims for LQ4
- aluminum vs iron heads
- IS the balancer snout supposed to sit against the timing sprocket?
- any sponsor sell me a set (2) harland sharpe rollers?
- Compression Ratios
- So I'm doing cam/heads, what supporting mods?
- Katech/IWIS LSx Timing Chain
- Lost on 370 Build
- What CAM????
- #3 misfire
- 2000 Silverado V8 Sputters to Life
- smoke out the exhaust...
- Help!!!how to take off ls1crank sprocket?????
- lq4 with ls3 or l92 heads and ls3 intake will compression be too low?
- 99 Z-28 175,000 miles! How much $?
- Clevite H bearings or P bearings? other?(stock LS1 crank, aftermarket rods)
- CAM or Gears?
- can someone recommend a good shop in so-cal
- Leak Down Results
- 02 LQ9 (escalade) misfire #4 im stumped
- Ticking help, no its not the headers.
- Cam for lq4
- options for 5.3
- it's Time but confusing " LG G5X3 vs Vengeance VRX5 "
- Which Gasket kit to go with?
- Another Heads n Cam thread.. WOOO!!!
- help head porters!!!!
- Cam and gear question
- Daily driver cam?
- Got my PRC LS6 heads today!
- coolant coming out of header bolt holes
- What motor to build??
- Cam without long tubes?
- LS2 coils on my ls1
- new stroker motor - low oil pressure! please help!
- looking for suggestions on porting and milling 317 heads or 241s on lq4
- LT1 - LS1 forged rods... fitment?
- How Much Do I Need To Mill The Heads????
- Head Swap
- 06 GTO Oil pan same as 04?
- bilding lq9, have a question about cam.springs
- most lift with stock pistons?
- PAC 1218's with a F13????
- engine stutters between 40 and 60mph
- Hinson Supercars FAST 102
- 2004 LQ4 Spark Plug Gap
- I have two choices for heads right now.
- Thriftiest 427 option to keep my fast 90 with?
- Will this setup have potential to run mid 11's?
- rocker arm confusion
- I want to shim my oil pump spring. How do I do this?
- PVD Coating for Engine Parts
- Timing chain
- ls7 lifter with 228/232 and 5.3 heads what pushrods size?
- Are these heads port and polished?
- Cam swap and heads getting worked...
- Speed Unlimited President's Day Sale This Monday !!
- 317 casting 6.0l
- I was presented with a good offer for a ms3 cam...i think?
- Flycutting?
- carb LQ9 cam question
- new cam just in
- need to know if i would have ptv clearance???
- What cam in a H/C/I ?
- Can you please help me indentify this cam
- Effin A -- Nightmare first cam swap...
- input wanted on Head and cam selection for stock lq4 come in Pred z, Pat G Tex speed
- Ls1 swapped car, with Nitrous cam help
- 243 heads worth it?
- 5.3 rocker arms in 317 heads?
- no power...
- which cold air to go with??
- Am I missing anything (cam install parts)?
- 5.3 problem
- Cams that pick up the HP but don't drop the Torque
- going 6.0 need help
- weird compressor type sound coming from engine bay
- Problem with JE Piston
- Exhaust Question and Need ideas
- Head gasket question
- best pully puller
- Building ls6 heads
- Head bolt length?
- LS head dimensions/blueprints
- H/C Swap Question
- Original LS1 Prototype Head Casting 554
- Power difference?
- ohio..e-check(emission testing) legal cams?
- company for porting heads
- Cam Swap
- Power sterring pump , is ls1 same than ls6?
- Which heads for my setup TSP Stage 1 or Stage 2.5
- Which lifters?
- New style of 918 springs????
- Compression Question........Little Help Here
- LS1 383...where to begin?
- Yet another cam choice thread for H/C C5 Z06. Opinions PLEASE!! Pred-Z, Pat G welcome
- Oil cap keeps blowing out!
- torquer V3... a few questions
- valley cover
- 04 GTO Cam advice
- how to find out what vehicle and what years a 6.0 came out of
- Help figuring out what is making this noise (video)
- Heads issue
- DBW truck throttle body on ls6 intake
- Good Head for my Setup
- resurfacing heads
- 6.125 rods
- Seriously what pump clears the cover and double roller TChain?
- ls6cnc or 5.3cnc, 233-239 or t2
- Is 0.005 ovebore enough to rebuilt LQ4 with 150k mile ?
- Which windage tray?
- longer crank bolt?
- Sound clip of my comp xer281
