View Full Version : Generation III Internal Engine
- help building an l33
- Wiseco Protru 3.903 Domes+Gen IV rods/crank in ls1
- Engine Build Questions
- Lifter noise when idling down
- Input on an N/A combo
- Question about power adders
- need help on building an engine
- Daily driver cam, bolt-on 02 SS
- Carb LQ9 build- 370 or stroker,ls3 or cathedral heads?
- Re-use pistons?
- 98 formula ls1 6 speed first build help
- cam question
- Smallest diameter crank pulley
- stock vortek 350 compatible with tpi?
- Oil pressure drops when revved
- camshaft selection
- Oversized valves that is the question
- what else should i do?
- Help! Rebuilt ls1 won't start
- LS1 Valve Lash Procedure?
- Could this be anything other than lifters?
- Dreaded P0300
- Best Vendor Experieces
- stock upgraded rockers. replace at what mileage?
- Starting my budget nitrous LM7. Need some input
- gto upgrade dyno sheet.
- heads and cam now starter wont turn motor
- what engine do i have??
- Do these numbers seem about right?
- Need help! Bank 1 running rich
- Looking for cam input for a PRC 2.5 headed 10.3:1 LS1 Vette
- Lq9 vs l99
- Cam and Injector question
- temperature vs resistance of 98 3-wire sender
- ls1 383 stroker ticking
- cracked timing cover - JB weld?
- How would you fix this ls1 block? *pics*
- Help Needed
- What intake/heads would you go with on this car with these mods?
- Top Speed Issues
- 240Z with LS1
- New here, thought I share my LQ4 build with everyone.
- 383 stroking ls1
- use stock fuel injectors or bump up after mods?
- Cam Crazy I need help bad.
- Quick ? On head bolt tty
- Gasket bore relative to block or combustion chamber
- oil pump help
- spark plug broke off in motor
- Major Oil Leak, Need opinions
- Looking to make 400 hp at the wheels, recommend me a good cam/head combo
- LM7 need help picking parts for 500+ hp N/A build.
- Light rattling noise a few seconds after rpm drops.- With Video
- Heads for a 5.3 with room to grow?
- 215cc Heads & MS4 Cam
- help me choose heads for a 408
- Coated or Uncoated Bearings?
- CAM IDEAS ? ls1-proflo intake- cnc243s
- Rocker support bracket
- Anything seem wrong with my setup
- Lq4 build with 6.365 rods
- Cnc LS3 Pro Comp valve guides - heads up
- Where to find PN 12568478?
- Rod-piston orientation
- Cam help
- F13 112 vs 114 cam gurus come in
- To balance or not balance??
- 04 gto intake manifold ls6?
- Help diagnose LS1 GTO Knock ( Video Inside)
- stroker oil pan clearance
- Car seems to be consistently down 25-30rwhp
- Ls2 coil bracket on ls1? Help frc
- Cracked ls1 block
- LS6 Cam says 5308 no barcode
- Swap T56/A4 in 1998 SS w/ 2000 SS? What's required? Thanks!
- BTR Stage 4 vs Tsunami
- LS1 balancer on 5.3 LM7
- ls1 block crack from oil pan bolt
- Lm7
- mods
- Fully Modded LS1 Ideas???
- Need Valve covers that will clear poly locks
- 223/239 tsp cam install huge problem
- balancing a cast crank
- possibly found the problem everyone please read
- Mystery Oil
- Are all lifter guides the same ????
- thinking of going with a bigger cam.
- is it possible to convert 5.3 to 5.7
- 50psi cold idle, 8-10psi hot idle? What gives?
- Need suggestion on a 6.0L build.
- tach and speedo sweeping back and forth at idle with check gauges light flashing
- Can valvesprings slow car?
- LQ9 n/a stock bottom end options
- 408, PRC 247, TSP giant cam, anybody run this?
- 5.0 ls
- max effort 347 nitrous build
- Large cam, valve train noise
- piston to valve clearance? ?rwhp??
- Sealed power lube on cam, good enough?
- best cam for stock setup and #241's?
- Starting to freshen up my old build, aiming for 460whp. Ideas?
- 99-02 ebcm with trac
- high oil pressure
- Good nitrous cam for 5.3?
- What would cause this much damage?
- External Oil Primer Home Made - A Pre Lube Option to prevent dry start
- LS6 Oil Pump Shims
- Custom Cam torque peek? hp? DCR?
- C5 cam swap
- changing damaged front cam bearing??
- very frustrated. did i mess something up? harmonic balancer pounded on
- Head gasket question
- ONLY Cammed LS7 makes 600hp!!
- Frankenstine??? need some info
- "eBay" Head Studs "How To" Video - Pro Comp - Alper
- valve train overhual
- Anybody tried this cam shaft
- ls6 oiling pressure issues
- Cam choice for set up, opinions.
- no oil pressure after new motor install
- Heard loud crack on first torque of heads with GM bolts
- Zero Oil Pressure
- Bad rasp on turbo exhaust
- How does my camshaft look...
- Blown head gasket
- What Trunnion kit are you running???? Any problems
- Which heads will work and fit to lower my compression on this setup??
- thinking bout camming my camaro
- Cam swap. Ran fine now won't start?
- Cylinder #1 Misfire - Valve Seal?
- LS Swap Help
- Junk yard dog pins won't fit
- 6.0 PTV clearance with this cam
- rods or rod bolts?
- What head gasket
- Porting an ls6 intake
- BRP hotrod ls girdle
- oil pickup tube bolt single or dual? space between bracket?
- pushrod length
- F13 cam..... Installed!!!
- How critical. Injector retaining clip?
- 241 heads on lm7
- Oil Pumps
- 50th corvette cam suggestions
- 2001 Chevy Z71 help. cam swap, headwork, valves, issues
- Crack between valves on 799 heads
- psi 1511 retainer/locks?
- Forged Pistons
- Winter Project now Spring Project
- lq9 pistons with ls3 valve reliefs???
- ls1 longblock value
- how loose is to loose?
- map sensor retainer clip?
- performance upgrades
- TSP 2.5 LS6 Heads question
- lq4 l92 build in progress
- can u help IDENTIFY this cam
- very slow coolant leak from headbolt
- Rod identification
- Complete Gasket Kits?!..
- Dash cluster all jacked on start up of New Lq4 (video)
- idle issue
- which size head bolts?
- Ring job on ls6
- Gains with tfs as cast 220's and fast 92 on ls6
- Rebuild kit
- Stealthy 5.7 build.!
- 5.3 tsp 220r cam or 224r cam?
- Have full access to a machine shop
- Input appreciated. Disappointing Dyno Result after cam
- rough idle
- Steem tube
- Am I in trouble or is this ok? Valve seals
- getting vrx4 installed at vengeance racing.
- L33 questions
- Assembly lube on pistons
- too much crankcase pressure? popped pcv out
- I have had it with this squeal!!!!!!!
- Question on CR
- Info needed on lq4 head gasket service!
- someone from texas speed i have a ?
- In need of LS6 piston
- Fans not coming on?
- lifter preload
- Throwing codes left and right!
- Planning first stroker LS1/383
- need some help...checking pushrods LS6
- Who knows what this is? Dyno vid included.
- 370 ?
- l33 using coolant, smoking... head gaskets?!
- Vengeance racing vindicator cam
- Tickng motor..
- TEA 317 vs PRC 215
- Do you replace old LS1 head bolts?
- Torque spec for Tella-Yellow roller rockers?
- How do you contact moderator? ..lost 4,056 posts
- Back to Modding! Thanks Texas Speed! (Sorry, Long)
- Compression ratio question
- Looking for a cam suggestion
- Used Rod & Piston Set for my LS!???
- Ls1 spring retainers vs LS6 titanium spring retainers weight
- Poor Gas Mileage After Move?
- BTR valve springs /seals
- sum-htlskit ls1 what brand are they
- Pushrod length questions - LS7 lifters
- Lifter tap??
- break in oil
- 370 with TSP 244/248
- iron heads
- Removing 317 Heads From Savana Van
- LM7 Build Questions BMW Swap
- 228r and Stock Oil Pump Concern
- 5.3 w/ls1 intake and nitrous?
- My first LS car. What to do?
- Cost and pieces required to complete a long block.
- 4.8 to 5.7 build
- Block machine question?????
- Help diagnose smoking
- budget silverado build
- Answered a thousand times & needing parts
- 1st time camshaft install: parts suggestions and advice please
- 6.0 block head studs part number ?
- ls1 conversation in to nissan patrol 4x4
- what is the preferable cam for my setup
- Got a new truck, now what...
- Help Diagnosing Oil Leak Please - Photos Included
- best cam and heads for 1/8 mile 346
- 853 heads Vs 243 heads (budget/performance)
- threw a rod in cam on ls1 w 46, 000
- Safe maximum RPM for my setup?
- trick flow valve spring problems
- 12:1 SCR, 8.6:1 DCR plug & gap question
- Trunnion Bearings: how to remove?
- eliminate PCV added timing
- Ls1 intake swap to ls6 intake
- LS (non shaft) rocker arm experiences, breakage, float what have you seen?
- Can't find proper main bearings
- lq9 414
- 370ci piston to deck height = .019?
- What about these heads?
- Morel 5452 solid roller lifters
- Camshaft Porn
- 383 stroker build
- header install
- 02 WS6, some boltons done but what else to do before tune?
- Comp 850-16 lifter preload???????
- newbie block question.
- LQ4 1982 Z28 Swap
- FFFUUUHHHH...royal screw up...LS6 C5Z
