View Full Version : Generation III Internal Engine
- Thanks LS1Tech
- ls1 with ms3 set up.
- LQ4 408ci Twin 72mm Turbo in Progress
- Cam Cores: 5150, 8660, 8620. Which is best?
- ls1 rocker torque spec with double springs
- Cam swap
- Head gasket leaking after install..
- Those with Trunion upgrade. Look HERE!
- stuck lifters on 5.3l
- New 408, help me decide on a top end
- Which oil
- What Oil For a Turbo SBE 6.0L?
- ls1 4in callies crank how much to clearence
- what is causing the need for shorter pushrods?
- Torque spec for connecting rods
- Newbie needing help
- New to the ls world
- New Top End Build
- About ls connacting rod
- LQ4/80E price help
- Source for Melling oil pump O-rings?
- Swapped Reluctor wheel for ECM upgrade [some pics]
- yellow terra ultralites ?????
- Thinking of tackling a cam install myself
- Installed Height valve spring shimming- How much is too much?
- head bolt pop help!
- Engine Oil Pressure
- LS1 engine build - 55 pictures - feel free to critique
- Recommended Viscosity Oil?
- Crane Cam direct Fit cams?
- What cam is this? 224/236?
- LS1 rebuild cost
- LS Crankshaft Speedi-Sleeve
- Does anyone know anything about 5.3's
- cam for 5.3 1972 Cutlass swap
- Cam and other mods need help
- Piston Slap at startup?
- Drilling out ARP crank bolt?
- Temp o-ring fix
- my 5.3 build
- Help diagnose bad misfire/no start on 5.3 build.
- Diagnosing my LQ4 issue
- lifter question for cam swap
- Homemade thread chaser for head bolts?
- Pre 2001 castech heads
- want to do a 5.3 to 5.7 build
- Low PSI with new LS1 motor. Please help
- Ring gap concern
- advise on coolant pipes
- lm7 piston question.
- First Post / Advice on build
- Flogging engine on chassis dyno after rebuild
- No go for the 6.0???
- Another What Cam Thread
- upgraded stock vs harland sharpes
- What heads are these ???
- which way goes head gasket ?
- ls1 clattering
- Tips & Tricks for Tickflow 215's
- tick performance /Brian tooley springs compared to stock, pics
- compression ratio
- 5.3 L33 coolant loss
- GM LS1 mls head gasket thickness.
- supporting mods for ms4 cam
- PSI LS1511ML spring kit?
- LQ 370 vs LS3
- Head gasket bore size?
- Texas Speed & Perf. Machine Work
- Oem cam part #
- Dart 205 v AFR 215
- Better choice: Tick Polluter V2 or SNS Stage 3?
- Arp head bolts
- When purchasing used 243s...what should I be looking for?
- what do you think of this cam and engine setup?
- new engine build could use some help
- Crane cams valvespring tool bolt size?
- Looking for a shop in North Carolina to install a cam + tune
- postive crankcase ventilation
- Thread deleted? Loose pilot bearing...
- Trick flow 215's on my ls1 383 ???
- Gen IV Rods & Pistons in Gen III 5.3
- 383 ls1
- Possible valve float issues, help on choosing new springs
- what do you recommend on my build
- Heads/cam swap method
- Engine oil?
- Changed oil...small spring caught on oil drain plug. What is it?
- LQ9 cam help
- after market throttle body?
- caint decided what cam need help
- Split duration cam question?
- Tick SNS Stage 2 or 3?
- Double checking before I buy new cam.
- Rods Question
- Speedmaster 1.8 Rockers
- 4.8 heads
- 5.3l l33 noise diagnosis
- LS1-LS6 opinion
- gen 3 rods safe hp limit
- LS1 Buildup, which cam?
- tuning... opinions wanted
- 5.3 bottom end line hone
- L33 cam swap
- new intake now which cam???
- a lil oil in cylinder
- LQ4 with 04 Ls6 Cam
- Looking to build a 6.0, who sells a machined block?
- 04 ls6 heads
- 383 Stroker Questions
- rod honing/line honing
- Cam and Crank Dot question,???
- Z06 Camshaft in 5.3L Turbo Build HELP!!
- stock ls1 crank size
- 24x reluctor ring
- Stock oil pump
- Anyone know Ozz?
- 408 piston swap with mast heads. what pistons?
- 5.3 ls with 76mm turbo?
- My ls1 is seized. Best options for a stroker?
- VRX2 cam, are dual spring necessary?
- caddy lifters
- What HP #'s should I expect
- Forged rod recomendation...
- good cam for my 2000 z28
- lq408 block machining & balance rotating assembly $1700...
- 383 stroker?
- Another 5.3 LS build, most cost effective route doable
- stock cam duration at .006
- which vale springs?
- 5.3 mods?
- LQ4 build help, the stupid little stuff
- Most streetable head/cam setup?
- 5.3L Main, Rod and Cam bearings help!
- Comp Cam XR265-15 With Blue GM Springs(12499224)
- Another hot cam thread
- Different length pushrods same head.
- head choice
- Ls1 build, hp gain?
- May have been burned on this 4.8
- Advice please. LS6 dry sump connection.
- The heads and cam end result - long read , videos
- comp cam xr273hr
- $12,000 to build a smog legal engine to go in '98 ta with at least 500 rwhp.
- heads vs heads & cam, Labor
- Felpro 1160 gaskets
- when should you upgrade stock rockers
- Identify wiring harness
- How screwed am I?
- lq9 + Ls3heads + L76
- My 408 14.1:1 build (lots of pics)
- what you think of this combo??
- What gains would I get with this setup
- 5.3 input
- Best combo for high 11's 2004 GTO
- Wiseco piston rings packaging mixup
- another morel lifter preload question
- motor upgrade
- Good machine shop in the Albany area?
- Suggestions for cam and intake only?
- RHS Pro Elite Small Bore LS7 Heads
- my build
- Which crankshaft?
- New cam WITHOUT a stall????
- 98 LSI block rear oil passage?
- Anyone running hot cam or Asa cam
- Pretty Excited: My Custom Trickflow Heads are Ready
- HINSON C7-R Seamless Timing Chain - The Strongest Single Row Chain Available!
- timing chain issues
- Valve stem seals?
- Nitrous ring gap
- ls7 lifter failure "pics inside"
- How many miles are too many miles?
- Help Inspecting a blown LS6
- Max RPM for TSP 224r
- 6.0 with ls7 lifters pushrod length question
- Forward Cylinders req Longer Pushrods than Rear
- 1998 LS1 head/cam advice
- Symptoms of missing oil pressure "barbell"
- Are the Johnson 2110 lifters short travel?
- Help me choose rods for my Wiseco k366x05's
- Putting an LQ4 in a Jeep TJ.. Looking for some advice
- Caked on crusty in exhaust ports
- 2010 5.3 low end
- ls2 pistons in lq4?
- lq4 low oil pressure on stand
- Whats needed to make a 6.0 a 6.2?
- 243 LS1 head swap
- My Rant / Advice Needed on 5.3 Turbo Build
- Is there a quiet lifter?
- 5.3 Ring gap
- cam install from hell
- ls7 lifters
- $7,500 Budget to replace ls1 in 98 TA. Any ideas?
- need advice on LS6 engine swap
- Building My LM7 Help! New to the LS World!
- which direction would be cheaper for my 4.8
- 5.3 400hp+ build, need input or suggestions
- Lots of PCV oil and miss up high
- DOD AFM delete burning question
- Anyone running BTR Stg 4 camshafts close to 500hp
- Ls1 vs ls6 heads
- cam swap advice
- Sealed Power E938K Piston Ring Tolerance
- Need help for sleeper build!
- lq9 243 or l92 heads
- ALL rockers are loose after cam install
- Thinking about picking up this 408 sb... need opinions. **pics inside**
- Oil pump replacement questions?
- Melling 10296 blue or red?
- 3.905 on a 98 LS1 block; how screwed am I?
- Just for fun what do you think my ride is putting out?
- Help me with my build!
- 10296 vs 10295 idle pressure
- ls1 stroker 383 or ls3 bolts on
- Cam decision, ms3???
- Aluminum block L33 ARP mainstud kit
- My E46 LS1 build! a few questions...
- Hopefully ...new 5.3 cam question
- Good
- My 346 tfs 220 build questions
- LS1 lifter preload
- Porting BBK TB. need suggestions.
- To change the Rod bolts or not is the question...
- Cam sensor single or 3 pole?
- 799 heads and cam in 5.3
- head gasket thickness???
- Ported OEM 4.8/5.3 liter heads----solid results!
- Thoughts on what could cause a dyno graph like this?
- Ls7 lifter preload.
- engine knock??? 2000 ws6
- Tick sound at idle after cam install, cylinder 3
- Fly Cutting 5.3 Pistons with Shaved 241 Heads
- RHS 225 For a C5 Z06
- crankshaft sticking
- Help me understand compression
- Crank rubbing on block? Picture inside
- Compression Test Results
- melling oil pumps
- putting a ls1 into a tbss
- Camshaft OVERLAP SCALE!!!!
- Fresh rebuilt motor how much oil should it take?
- Valve shrouding
- 233/239 112 lsa?
- Aftermarket springs in cold weather
- LS head coolent blockoff broken inside
- ls1 forged pistons
- Mysteries of Bore Stroke & Rod length Part1
- Cam Warranty?
- 5.3 stock piston rings. top ring has no dot.
- any problems for see able ??
