View Full Version : Generation III Internal Engine
- 5.3 rebuild
- Cam Lift?
- difference between 04 GTO LS1 and 01 02 fbod LS1
- Tips for prolonging Valvespring life?
- what the flow rates of stock and aftermarket heads and intakes ls1/ls2/ls7
- 1.85 ratio lifters, a good idea?
- ok on to push rods
- Started Cam Install..
- How big a deal is this?
- Cam
- TFS 225's...
- pushrods and rocker (ratio?)
- best cam for my combo???
- spray
- interesting question for you guys
- Valve spring Compression tool
- TSP 228R & comp 918 springs
- Does stock 99 LS1 cam have gm part# on it?
- info on valve cover grommets
- cam with trickflows and fast
- studs or shaft?
- waterpump
- for n20
- camming my c5
- stage 2 mti heads plus cam do i need new oil pump?
- PRC H/C dyno results pic and video
- help with engine build
- Yellow Under Oil Cap?..
- want to buy crate engine
- Budget heads and cam build......
- More goodies!
- need a true gm part # for ls1 lifters!!!!
- TR230 info on heads...
- need some info!!!
- good set up?
- oil pressure zero!!!
- TR 224 114lsa on stock stall?
- Best heads for the $$$ for a N/A + Nitrous setup
- LQ4 truck long block
- solid roller springs
- LQ4~~arp rod and main bolt #'s
- PRC springs
- do i have everything?(not another one of these)
- Cam Swap: Keep OEM oil pump?
- X-mas in Feb!
- MS3 or MS4 Daily Driver
- trick flow h/c combo
- Head/Cam
- what crank are you running
- Tapping relative to RPM
- Intake centerline for a stock cam?
- Crane gold roller rockers. Problem???
- Heads and Cam Swap
- How much power am I leaving on the table.....
- changing out the stock cam for a stock cam?
- My Temps keep going Up!!!
- Another cam question
- Clarifying an over-rev
- Whats the orange/red stuff under the top lips of the rocker bolts?
- Dyno sheet
- difference in ls1 and ls2 243 casting number heads
- What can I expect to pay??
- is this a good deal on a set of 243 heads???
- valve spring deal
- ET heads
- Oil Pump???
- Clearance for pick-up to oil pan?
- 98 383 block
- I would like to get some more thoughts on the 228/232 .588/.595 cam please?
- Hanging idle after install
- FAST 90/90 set up or wait for new Weiand
- what are the stock part good for
- ls6 springs with tr 224 cam
- idle prob
- heads
- Well i did it, The Cam Is In
- ls1 crank sprocket?
- Magnaflow question
- New Patriot Cam
- Ignition problem?
- Anyone know what kind of hp this cam gives?
- Tuner for cam
- 383 stroker
- trickflow heads????
- v4 cam sound clip
- roller rocker ratio
- slp maf
- will my car run?
- Is the crany pully a press fit or keyed? I have both.
- Low oil pressure after overheat, thoughts?
- Heads/cam ?
- help with internals
- belt throw after a cam swap
- Please help me ID my motor (pics)
- Looking for PRC S1 LS6 head Results
- LS1/LS6 Highest N/A HP Record???
- LS6 to Vengeance FAST 90/LS2 90 Results
- A4 car 112lsa or 114lsa?
- Pics of our LS Project:
- mti x1
- Is this possible with the engine still in the car???
- 1.85 Rockers VTP Clearance Issues?
- ok im about to give up.
- Thinking of forging my LS1!
- Scorpion roller rockers?
- Pushrod Question
- How much lifter preload comp rockers?
- smoke on start, rough idle, ticking. help please.
- Head swap help
- 395 Stroker!
- Spec Stage 1
- 383 stroker build - looking for dependable shop
- 97 Vette Cam Position Sensor
- No oil pressure to rockers
- pickin heads
- AFR (205) with ms4
- h/c tuning help
- Ls1 Hp
- cam heads and intake diy?s
- 04 6.0 block what connecting rod length
- Misfire
- Crazy Noise at 5k+ RPM??
- black smoke?
- Need help with cam choice
- rev question
- 383 hits oilpan. Also what holds the cam rear?
- cam, spring question
- High rpm damage
- whos car wistles after cam swap
- pics of my stock pistons/valves.. good? bad?
- Another heads question....
- Cam?
- Heads to mate with MS3 Cam?
- PRC Stage 2.5 Heads.. Good or bad?
- U-joint help
- 5.3L pushrod length on milled
- how to pull stock balancer off crankshaft on ls2
- I need some opinions on this setup!
- Help with pistons selection and CR
- tuning after cam install
- Head advice
- Bought supposed 99 LS1 engine but has 241 heads, what year is it really?
- Are my compression figures right?
- Confirm My cam is alighned (Please)
- wht do i need??
- Guages
- ls6 how much power?
- Opinions on my new heads
- change rod bolts with motor still in?
- What Intake do I have
- New Block for 500rwhp
- Cam choice...
- high milage ls1
- Pulling the Trigger (DD Cam only) Decision.
- Any tricks to get the oil pan to drop?
- Headers for lowered ss
- What Cam Do I Have????
- trashed bottom end???
- which double roller??
- Rev Limiter or Knock Retard????
- what heads do i got..
- oh snap, carnage pics inside!!
- Ls1 - Ls6
- Two bolts to the oil pan I forgot where they go?
- Rollers check
- Installing rings today, quick question. Extra rings?
- has anyone got a pulley off with a stock bolt?
- best heads for 230/230 .612/.592 111+2 LSA cam?
- Might as well get injectors...right?
- Alternator is DEAD!!
- Any big cam only guys with ported FAST 90 setup?
- Torque spec?? Head studs and rod bolts
- How can I achieve 400 HP from my stock LS1?
- 1/4 mile with the my mods????
- future plans for ls1, i have a little bit so far, any suggestions
- New to the LS1 - How to mod?
- Changing alternator
- Pinning crank
- how much is a valve job on 5.3's?
- Patriot Head And Cam Kits For Ls1
- OPINIONS WANTED - might need a shortblock
- What is your guess on hp for...
- noisy valvetrain .......
- help? how to check engine compression ?
- Deal or no Deal??
- Pics of ported LS1 heads
- can someone tell me what pushrod length to get??? Engine specs inside...
- Whether to get a cam
- Eagle Crank?
- TSP heads and cam
- How to make an ls1 a monster
- 383 or 346?
- cam install prices
- can i run this cam with a stock stall?
- Cam for stock heads
- Dyno tomorrow,guess numbers
- What heads to get
- ms4 with patriot stage 2 heads
- How much power before I have to start worrying?
- Livernois Stg 3 LS6 heads to big for G5X3??
- Cam
- Props to Texas Speed!
- Will 04 injectors fit my ls1?
- AFR still the best LSX head on the market?
- what size dowel
- rear cover question
- possible 500rwhp stock cube?
- Melling 10296
- P0336 problems
- 383 power
- ls6 cam sizing questions
- Guru's pls help?
- Valve Spring/Rocker Arm question
- Rod bolt wont come out of end cap
- All aftermarket cams etched?
- all around what head is better the 853's or the 5.3's
- Harland sharp is a rip off IMO
- Quick Cam install question
- Flat spot in powerband?
- Oil pump o rings?
- Question about CTS v ls6 motor???
- what cams better MS3 or MS4???
- Considering my options
- Connecting rod Q.
- Wanting to inch up. 5.3 to 5.7
- PRC Predator heads
- Good brand of push rods
- please help!!! LSX noob needs cam help
- 317 heads-help
- Loud noise COMES AND GOES, help diagnose please!
- Tune/breakin new engine,clutch?
- X1 can plus stock tune, can I drive the car hard?
- need 2 find a good cam!
- Car Idling bad, Sputtering.
- Ported 98' oil pump.. Have a question
- Which Cam?TR224, 224R, 228R?
- cam and main bearings
- do i have all my parts for the cam swap?
- Alright guys, which rod and main bearings should I be using
- Head Swap --- Gasket Confusion
- LS1 top ten aftermarket proformance parts supplies?
- Need to change reluctor ring..
- gm head bolt part #
- spec'd my own cam...what do you think
- H/C install
- Cam spec opinions...
- F10 vs f11 vs f12 cam
- help 383 sroker on an LS1
- Cam Advice, newb ( long )
- AIR System with breather? HELP
