View Full Version : Generation III Internal Engine
- CAN You Run LG G5X3 Cam with Patriot
- colder plugs question
- ZH1129CT Pistons?
- need help with piston?
- Belt covered in oil
- 5.3 w/ 317 heads
- Damaged Lifter! (with pics)
- Help upgrading my 97 LS1
- Some problems and solutions...
- Want a g5x4 o4 g5x3 cam bad
- Will Heads work?
- New shortblock vs stroked stocker?
- Building a 383 w/ AFR205s
- Head bolts...?
- polishing heads ??
- 99' 26lb injectors to 00' 28lb injectors, any benefit?
- new moter little blow by help?????
- Oil in coolant.. and coolant in oil
- k1 billet lightweigt rods
- Speed Secrets 402 Iron Block!!! "Video"
- New cam installed
- stock cam powerband
- 8.5 tire class
- Can someone plz help?
- check engine light
- 02 ss won't start
- headucation....
- PCV valve placement
- which rod bolts?
- rocker arm stud?
- Any thoughts about the T-REX CAM
- Help choose the correct Pistons/Rods (Bore 3.898) stock 346
- Blown ring: stroke or new shortblock?
- Valvespring life?
- How Much Oil will a -8 an fitting flow??
- Camshaft sensor to front, hole left over?
- heads/cam info asap ....ordering monday
- First cam swap?
- 04 gto cam in 5.3 engine
- bad lifters?
- Head question?
- Help! p1153!!! again and again
- Stock Lifters with Torquer 3?
- help asap with spring swap
- Heads compromise
- Need help identifying patriot heads
- Wondering what this object is
- At what horsepower level does a single 3" exhaust start to become a restriction?
- Why/where is my coolant disappearing???
- Oil pressure problems
- valve springs
- Ls hot cam
- longer crank bolt
- Replacing Main\Rod bearings?
- Reusing Brand New MLS Head Gaskets???
- ANOTHER oil pressure question.
- T&D rockers? Who has them working? What are your mods?
- What CAM? Catastrophic Issues require me to get a NEW One. Want Bigger...
- New Valve Springs, now Need New Cam, Lifters, and Valves! wtf??
- need help....oil pressure issues
- Looking for a piston thats works with a lq9 / l92 head combo
- Got a cam picked out, want some opinions.
- Wierd issue with my car, any ideas?
- Power Gains
- Is ptv a normal problem? Please help!!
- Edelbrock for old schoolers
- Cracked Head/Block or Blown Gasket?
- low milage LS6 needs a sleeve?
- Oil pump
- what kind of engine is it??
- Question about Deck Height
- PTV clearance
- My E85 as a Octane Booster Experiment
- ls1 to Lq4 swap question about heads
- Miles on car? Whats to many?
- Ideas Ideas
- Got the car dynoed :(
- Car shuts off after 10-20 secs, oil pressure fluctuates as it cuts off
- What is a THICKER 30w oil? (Not a BEST thread)!
- engine failure after rebuild
- How well will this 370 hold up?
- The Stupid Question
- flycutting new shortblock
- 6.0 intake manifold on early 5.7 LS1
- Need help with high compression test readings
- Stock block on a 383 Stroker?
- stock rockers?
- Engine stutter at high r's and at wot
- how much boost will a stock ls1 hold
- what else to do besides heads
- Which head with ms3, 5.3 or 317
- why do they make valve stem retainers so small??
- running rich, seafoam first or install new o2 and plugs first?
- Few size limitation questions
- Head bolts?
- Best oil pump with double roller?
- Bought a used cam, should I be sending it back?
- Do I need new Rear Cover Gasket?
- Best way to clean engine block?
- whos using a texas giant cam
- 5.3 Setups
- oh nooo, not another ls6 block thread*interesting*
- crank pulley/harmonic balancer puller question
- 5.3... z06 cam or hot cam?
- oil flow?
- engine unbalanced?
- MTI r1 combo question
- Weight of stock valvetrain components
- lifter noise????what the deuce????
- ls1 overheats below 2k rpm
- Little help with a part
- Hi...
- Vengeance Racing 575 HP kit
- new oil pump with cam install??
- anyone running this cam: Comp Cams 54-412-11
- are aftermarket rockers necessary with a larger cam?
- What PR Length?
- How to find a bad lifter?
- Correct head gaskets?
- 6.0 install for '99 Camaro????
- Blow a ring....what do I do?????
- which timing Chain?
- Comp Cam 581 588
- What kind of oil do you guys run
- coolant boiling hot NEED HELP
- crank pulley is squealing
- anyway to clean an ls6 oil pump
- Comp 26926 vs. Patriot Extreme Duals
- p.r.w.stud mounts
- Oil leak
- Question about Heads
- Clutch questions?
- All engine builders Read PLEASE!
- Warm Up Probelms
- Cometic sucks...how about milling these heads?
- Ls1 kms + engine modifications
- Does this sound like a bad oil pump?
- 224 228 112 Cam
- Help me get 9.5 compression
- Bad oil leak from behind the crank pulley.
- El Torro cam....better with 3.42 or 3.73 gears?
- how much vacuum are you getting with your MS3?
- oil pressur 80psi cruising?
- AFR 205, Trickflow 215, Edelbrock 215, or LQ9?
- LS1 windage tray vs. truck 4.8L windage tray
- MultiAir / UniAir vs PatAir / PattAir
- Replace Valve Springs C5, anything else while I am there?
- Did I do this math right for CR? And need piston advice!
- How to identify an aftermarket Maf with no decal.
- Your opinion on heads/cam
- Lower compression + Decent sized cam's
- Need some opinions... Alum 5.7 or Steel 6.0???
- Morel Lifter vs Push rod length question...
- Best sealing head gaskets and piston notch info
- Just finished head swap,......Oh Shit.....LEAKING
- Lifter Preload "Slack" Question. Please Help! Simple Question!
- sdpc cams.
- where to get head gaskets 3.905
- WHY THE HELL cant i bleed the air out of my cooling system????
- who has a polluter cam with a stalled auto???
- Do LS series main caps get out of shape like Gen1 SBC caps
- FIRST PICS PRC LS-3 Aftermarket Casting Cylinder Heads Sneak Peak INSIDE!!
- Whats the best swap for my 3rd gen?
- Degree my cam or not
- what pistons?
- LQ4/LQ9 Service Manual link
- 5.3 cam and compression question
- Which 15* heads?
- ??? on the corvette c6 wheels
- How are rotating assemblies balanced?
- H&C help
- Which Oil Pump?
- ls6 with 222/224 w/ 862 heads?
- How to remove broken valve cover bolt from head?
- Dumb question......but what are these?
- ls1 piston slap lifter wrist pin??? with video's
- 5.3 Jeep build. Head questions
- Engine miss fire trouble shooting
- Prelube or not
- 408 stroker what heads to buy
- Oil pressure problem month after cam
- Head bolt pattern
- LS2/7 Throttle body on an LS6 Motor Issue
- Just a question about the 8.1L
- 222/226 114lsa pass ca smog?
- reluctor 24x
- 5.3 short block in a 00z28 or buy broken headbolt short block
- used heads, what to do????
- HELP which camshaft should I go with??
- what camshaft should i run?
- Odd issue need thoughts
- cam for 408 L92 heads???
- camdoctor
- 5.3 (re)build advice needed.
- Performance Inductions heads
- 5.3l with 4.8l pistons
- Rockers
- Head Help
- Setup question
- '98-'02 F-Body Oil Pan Question
- Thumbs Up To Texas Speed For Their 233/239 596/605 Cam
- Cylinder #7 showing a misfire? And it now dies at idle? related?
- my next head and cam set up
- Buildding 383
- Does grinding down ls6 intake ribs make it weak enough to crack?
- help!!!!!!!!!!!!!!!!!!!!! please..:)
- harland sharp rockers coming loose
- HP limit for stock 2000 6.0L crank?
- Single Piston Ring???
- Cam help please!
- Ram air HELP please
- My new H/C/I setup, any opinions on this
- valve seal fitment
- Do I Need to change my stock rockers?
- ARP rod bolt question?
- question about lq4 block
- How to verify cam specs
- ICL explained ?
- Broke Oil Pressure Sending Unit
- 01 ls1 problem cranking
- Z06 243 Heads visual?
- Help with future build plans
- Calling pat g
- level out my ride
- help me pick a 408 cam
- Cam issue needs solving
- Scat LS1 forged I-Beam Rods anyone use em?
- need help guys on cam please!
- mid 400s help
- Need some ideas on problem
- balance question
- Any Damage Running engine 15/20 Seconds Without Oil???
- lq4 build
- Is this normal after a cam install ???
- 1998 LS1 stock 28 lb injectors for my heads/cam combo?
- Spacers needed.
- Need write up on removing motor from top!
- 1.8 rockers on ls1
- 370 lq4... which heads? help
- 06 GTO anyone have else have werid engine overheating issues
- Another pushrod length question
- difference in valves???
- Help with lining crank and cam
- Question about LQ4/9
- Are these rocker arm bearings?
- Darton Sleeves????
- Oil pressure - changed sender weird reading?
- Help please!! Is this a normal color? (head pics)
- 1.8 roller rockers on a ls6 motor?
- ls1 iron block build question
