View Full Version : Generation III Internal Engine
- LS6 Cam guys, please give me your valuable opinion
- any problems with bent pushrods in ls1's or trucks
- Should I change out my lifters
- Who's got a strong running 382 stroker?
- need help with heads
- all bore & nitrous.....
- lunati rotating kit
- LS6 block where to buy....
- Just got my sonic results...need advice???
- Backfiring at WOT over 4500 rpms
- heads/cam nitrous ?'s
- dropped a bolt in oil pan...
- 422 Shortblocks for under $2000 with forged parts?
- Help me pick a cam fro my 02 Z06-please!
- RMS C5 cam stock heads results!
- Short block assembly.....
- ASA cam times
- Help! Still got low oil pressure
- another cam question (Z06)
- Differences between TR and Comp pushrods?
- GM head gasket differences: 01-prior and 02-newer
- 383 stroker.... initial impressions
- Would an LS6 oil pan fit in an f-body
- Felpro head gasket VS Cometic - help
- Is this cam swap worth it?
- need some knowledge in here
- Flow #'s on ported LS1 heads? HEAD HELP????
- BBC valve springs on a LS1 ?
- Degree of advance for big cams?
- Stock crank on 383?
- How much does it cost to offset grind crank??
- Opinions on TR 224 and Yella Terra 1.8 ratios
- New shortblock question...
- Any opinions as to when to change valve springs?
- ASA Cam Question.
- Any updates on JPR's new cam tooL?
- How many cam only cars over 400? post up
- Comp 224/224 .581 Cam Dyno Results!!
- Whats the max cfm our heads can be ported to?
- LS6 heads vs 5.3L truck heads
- Cloyes timing gear- which mark?
- Block Clearances
- ARE Z/28 589 RWHP N/A
- Which spring do u guys recomend, Manley or CC918's
- The best cam for 382ci ALL-BORE
- New to the board...cam question fo L98
- LS6 blocks in 2001 & 2002s?
- rev 1116 spring question
- My ASA cam is in.
- Did I mess something up?
- Trashed a lobe on my cam..anyone else ?
- Gut the cats???
- Rod Length?
- power loss on holley, why?
- what would I see with this mods
- G5X2 Installed and running!
- Cam Question
- Good list??
- Cam timing hell, please help
- Got the car dynoed with the new cam...
- oil leak help needed
- GM SER-912 spring compressor tool
- A stupid question about the PCV system...
- Burning alot of oil since cam install
- LS6 oil pump>>
- Engine almost complete....
- LQ9 heads, how much?
- HotCam users inside
- X1 vs C2 cam
- Valve Spring tool for dual springs
- Cam sound and spec question
- Best cam for the job
- Hotcam & 1.8 rockers
- tune with cam question.
- What do you think the G5X2 will do in my LS6 ?
- Very confused about "2" things
- ARP head bolts
- FUEL with Heads and Cam >>
- what size cam?
- Anyone Have Their Pulley Off Their Car Right Now?
- CHS Stage 2 5.7L Flow Numbers
- Valve seal install
- Losing Coolant after Heads and Cam install
- Double Row timing chain And Pulley
- Cam Recommendations
- building engine...comb. chamber vs piston dish Q's
- ls1 vs tpi
- Can I use yella terras?
- New Engine Break-in Procedure
- Hotcam question
- ? Computer with heads??>>>
- S1 Cam too big? G5X-2 just right?
- What about this set up?>>
- Oil Pickup Tube Installed - See How I Did It!
- Will My 3.42 gear be ok for Tr224?
- ATTENTION - All registered members inside please.
- Installing ARP head studs, need help please
- At What RPM are you shifting H/C & Cam only Cars?
- Un-milled 5.3 truck head = what compression ratio?
- Extra Quart of oil OK?
- Are the stock pistons forged?
- How to install cam?
- Some help please
- 100,000 + Miles on the Old LS1
- '96 Vortech 5.7 w/ LT4 HotCam
- Stupid valve question
- Ticking after rebuilding engine
- REV or Comp Dual valve springs??
- Comp "R" lifter question..
- Anyone running a 5.3 oil pan with PA K-member?
- Self Porting your oil pump
- Double REV springs Vs. .560 lift cam?
- ASP and double chain, spacing problem?!?!
- 1.8 Rocker on Intake only???
- Info and advice appreciated on the LPE GT2-3 cam
- [Video] 388 big bore at idle
- Reading TR6 Plugs..
- Oil pressure sending unit... special tool needed?
- What is the compressed hight of GM head Gasket?
- Passed Emissions with 224/228 112 LSA Cam !!!!
- Will an MTI cam work in a truck?
- 5.3 heads or ls6 heads ?????
- White smoke out back, where to start....
- ? about ARP Main Studs and the oil deflector!
- How to remove timing gear from crank snout?
- How to check for bent valves???
- bare ls6 heads *DELETED*
- Harmonic Balancer Bolt?
- anyone retard an ASA cam
- Cam's List... help
- HELP I lost my oil 5 QUARTS
- Time to upgrade some parts, but what?
- Have to Exchange heads, HELP
- 224/224 110lsa 106icl cam dyno results, VERY HAPPY
- Lost in cam world!!!
- HELP Ls6 pass. side head leaking! sensor?
- Please Help Me: Oil Pickup Tube and SDPC Chain
- JPR 387 Darton Sleeved Motor on Order!
- ASA racing cam question???
- Knock, Rattle or WHAT???
- Major oil leak...Need input?
- Cam questions
- TSP 396 on Nitrous: 729.9 RWHP and 834.9 RWTQ!
- Low comp 422?
- Do I have too much preload? Not making good power
- *CAM ONLY* #'s
- [VIDEO] My 382 Stroker ..some ear candy for 'ya
- Who has high milage on their Isky 295D springs?
- new member
- 11:1 would be fine for 93 gas right? TEA 5.3's
- Update on P/V clearance with my H/C combo
- MTI B1 cam >>
- GAINS WITH TR224 OVER CURRENT SETUP?
- what is the best cam 4 me?
- possible new set up ??'s
- CAM ?
- Newer cam grinds (on 114LSA) to replace TR224
- Can 2.02/1.60 valves be put in 5.3 heads?
- Bigger cam = Better ET's in my car?
- Tapping sound at idle, now at cruising speed
- Anyone use Crower valvetrain parts?
- stock injectors with head/cam setup?
- 4.8 heads compression ratio
- Hammer Cam
- Timing chain and/or Ported Oil pump necessary?
- difference between ls1 and ls6 heads
- The 2001 ls6 cam
- Milling
- ARP head studs, need help please
- Purpose of LS6 valley cover??
- Bolting in a LS6 >>?
- G5X2 cam question
- Ready to re-install my lifters any special tricks?
- 4.8 Vortech heads
- ASA Cam
- *-Stock head specs-*
- Safest compression with 91 octane
- Dyno Results - TEAS2 Heads and Yella Terra Rockers
- Ed Potter and Cartek
- Crank Bolt for UD PUlley
- '02 & Up Z-06 Cam Technical Discussion--Cam gurus
- How to assemble a short block...
- Quick - need advice on how to clean intake ports
- To late for h/c mods?
- Valve Spring Change Question
- Z06 cam question
- Oil pump O-rings - part # please?
- Cam Q's
- Absolute StgII Ls1 + TR224? Got numbers? (prf A4)
- How much to mill for 11:1?
- 580 lift w/stock heads,manifolds? What et's
- Cam question, REF: Roller rockers
- How many guys run 11:1 CR with their heads?
- Engine Removal Guidance Needed
- Cam and Headers With Stock Tuning
- TR224 RWHP Average with stock heads
- Login problems? Step inside --->
- Yella Terra Rockers don't bolt in direct 97- 98
- Higher RPM?
- Cam specs for 02 LS6 motor, opinions?
- More Performance Valvespring tool?
- Knock Sensor TSB?
- Couple of newb questions
- 98 valve covers wont fit 5.3 heads right?
- 98 motor
- Sources/cost for Oil Pressure sending unit
- Oil Pickup Tube and Double Roller Timing Chain
- Compression Question - 5.3L Heads...
- Maximum valve lift for stock 2002 LS6 Valve Spring
- Picked up 52rwhp with MTI C2 cam!
- G5 cam and which heads?
- 02 WS-6 Dyno #'s within!
- f1 cam
- Can the 2001 LS6 cam compete with 2002 LS6 cam...
- Useless information to anyone who cares....
- Recieved My cam today from COMPCAMS, have question
- Question about the original G5 cam
- Whats the stock 241 casting CC numbers?
- HeadBolt ? please help
- Springs for X1 cam?
- engine builders needed
- Picked up some YellaTerra Rocker Arms today!
- low oil pressure, possible causes??!?!?!
- 1998 Block
- Motor Installation Question?
- Want a Powerful but Safe Cam
- Weird, chirping noise..pls look at description...
- Compression
- Where to get oil pump O-Ring?
- Best CAM only or head/cam combo?
- New LS1Tech software (identified BUGS)
- Polish, not porting, stock heads?
- LS6 CAM DYNO
- Lunati Engine Kits
- Need opinions on doing sponsors a favor
- Do I need different pistons with my heads??
- Where to set the gap with Diamond rings @
- LS6 Block? How Do You Identify One?
- Install Head Gaskets Dry?
- 226/234.554/.575 112LSA - Works w/ stock heads?
- Need some suggestions.......
- Today is the day! Old motor is coming out and....
- New LS1 owner has a plan
- 6.0 heads
- Joe Prince, your help is needed
- Turbo Camshaft& Max cubic inches out of a 346?
- bigger valves
- TR224 112 dyno numbers
- what to get, (experience needed
- differences between manifolds
