View Full Version : Generation III Internal Engine
- Anyone Daily Driving TSP'S 233/239???
- Q about '241' heads
- 1/4 in gap between new 408 stroker and tranny
- just wondering what the torque on the header bolts should be??
- Build Question
- LS1 still runs lean and trips codes...
- Torquer 3 is in the car!
- I need some assurance before i order
- cam and bolt on setup
- Stroke my motor for a turbo?
- Help!!! First Internal issue w/ car!
- Mustang 2 valve 4.6 Gurus inside
- Drove through water...and now bad problems
- cant decide
- Forged Piston?
- Oil Temp Sender in Oil Galley?
- how good are mahle pistons and rods?
- Need Help
- Anyone seen this engine before?
- Anyone use Harland Sharp Rockers on their Dart heads?
- It's running!
- Buying a modded Camaro.. had some questions.
- my heads and cam package
- Heads cam question
- Is 500 RWHP doable on a stock LS1 bottom end?
- Anyone have LS6 Intake Runner Avg Diameter?
- L92 Heads/manifold For Sale Already
- 6.0L Engine Changeover from a 2003 Full Size Chevy Silverado 1500 Truck
- ported 5.3's unmilled with 2.02 valves
- valve cover oil leak issues
- LM7 5.3 from Tahoe
- How does this sound for a cheap rebuild?
- Cam installed, tunning question
- Emissions Equip - What can be left out?
- What size 3 jaw puller
- Cam Questions?
- Head Gaskets
- LQ9 to LS style intake???
- Fired up another combo tonight...
- Need an answer about these Diamond Pistons.
- LS1 Cam removal / install
- please help
- overheating..radiator hoses cold
- How long did it take you?
- stg. 1 ls6 heads.
- teach me how to use the ve calc
- What else do I need for this setup?
- Power / performance estimate?
- Who's got the best reputation for short blocks?
- head gasket
- Valve size, milling-pvc
- What length pushrods are you running??
- Anyone running 20w50?
- horsepower tv ls1gun
- Tech Gurus: Please check my problem diagnosis!
- Need reassurance on P2V with setup
- Dex coolant question?
- how to go about replacing piston & rod
- Oil in intake
- help me find out what this noise is...
- Which springs to go with..........Need help.
- Monster NA build
- Where do i go for a good tune after cam install
- Which Lifters
- I don't know what it is....
- OLD XE vs XE-R question....
- dart 205 ptv?
- forged stock cubes
- LS6 or Fast Intake config
- 6.0 L (317) heads on LS1, what head gasket to use?
- Katech rod bolts
- ARP rod bolts rrrg
- Does any head produce better economy?
- AFR large bore 225's on a stock bore ls6?
- ls-1 or 2
- What Lifts/duration Does Ptv Become Issue?
- What heads are on my 98 TA
- What springs to go with XFI (.600" lift) Lobes?
- bosch plugs
- head chamber ?
- Buying a T/A "ENGINE DAMAGE" 7K
- LS2 cam in an LS1
- What is wrong? Ticking and sqeaking, Im pi$$ed.
- "806" heads
- I have a question. about doing a heads and cam package.
- where is the best place to get ported heads
- 3.90 bore ET heads--What short block?
- Got my Car back H/C 347
- 205 vs 225 on a 384
- Which heads?
- collapsed lifter, or loose spark plug
- Edelbrock heads?
- oil pump spacer, RTV?
- Head bolt healacoil
- What's the prognosis? DR.
- Time for new lifters??
- Front/Rear cover alignment tools - are you using them?
- Any downside to 02+ LS6 cam?
- Lunati cam thoughts Vodoo 232/238 .599/.601 Anyone with experience with it?
- Wierd smell after changing to Mobile 1
- Just need advise on camshaft
- Need a help for cam
- Patriots stg 3 LQ9 head gasket question
- no oil in the valve cover during cranking
- LS1 SS - Horsepower TV Build
- how much?
- What's All Involved To Change Oil Pan Gasket?
- cam,flycut and tune in san diego area
- What heads for low-end?
- Seem to be having problems
- Wasn't somebody selling Heads?
- What pistons/rods for FI?
- stock fuel system
- no idle after h/c install
- Rod knock
- Shaft mounted Rocker Arms
- What should I do with my HEADS?
- exhaust ports
- properly tightening rockers
- Need Help Please!!
- Cracked PRC LS6 Head PICS
- Oil on Plugs and out Exhaust? WTF?
- Slight cam install problem
- Help, I need ARP head bolts part number
- 408 build help best place to build it ?????
- How rough did you car run after head install?
- need help tuning for my Cammed car
- 853 heads with the notch on #3/#6 pistons?
- car is smoking
- What about this ??
- Worn valve tips
- How much power from ported heads?
- Which block is stronger, an LS1 block, or an LS6 block?
- 1.85 roller rockers worth it???
- overheating ned help
- Current Head Swap - Need Help (sensor)
- World Casting Warhawk block
- Car will not idle after heads/intake install. HELP!
- Bore, Stroke and rod lenghts...
- Advice Please:Sponsers, Members Need some advice on upgrading my cam in my 02 Camaro
- thunder racing cam opinion
- HELP !! need some opinions
- what engine do i have?
- What size valves?
- Head gasket leaking again, any ideas?
- 2002 A4 z-28
- ARP Main Cap torgue ??????
- Upgrade my cam?
- Rod bearings Discolored..
- Doing Cam Swap - What Parts?
- Help! Engine noise...
- What is causing this knock? video inside
- 427 cam suggestions
- Help please.....
- Newbee, what to payfor one?
- how much $$ is a stock shortblock!!
- Potential 6.0 LQ4 swap problems.
- I'm losing oil pressure
- Dyno chart for 1999 Camaro
- beehive works with T-rex?
- TSP Torquer 2 VS FMS F11
- Benefits of running race gas?
- MTI-G1 cam question
- another head port thread *pics*
- set the valves and lost a cylinder
- 237/242 595/595 112lsa lunati cam
- Felpro 1041 head gaskets
- 5.7 to 6.0L ?
- TSP magic stick 4 with an A4
- Compression Ratios??????????
- Ticking when warm
- Intake runners on stock 243 heads??
- Help, Please Help
- i know another which cam thread
- streetable or no
- 500rwhp off bottle?
- Cam Swap in progress.....
- Need help / opinions - Winter project
- Please Help!!! Block Specs Needed!!
- What cam to go with my AFR 205's
- Timing chain question
- F11 cam users, what is your cylinder PSI?
- This is a yes or no question.
- Cam people jump in
- Cam question....
- Magazine Cam Install
- new block
- I think I blew an oil line and damaged the engine
- CNC LS6 heads leak in runner
- what should i do????
- question about LG motorsport cams
- specs on the torquer v3??
- Why is my piston like this? pic
- I have PVC question
- 6.0 Head gaskets..
- Oil Pressure
- 2001 Vette motor
- What could cause this leak?
- need help fast!
- weird noise ..need help trying to figureout what it is...
- Heads swap?
- Installing Roller Master double roller..
- Should i buy
- Cam help PLEASE
- need help and quick
- TSP Terminator Build/Mill question
- Need sound clip of cam...
- Looking For Cam Suggestions
- Crower Shaft Mounted Rockers for ET Heads
- New cam time again!
- TRak sound clips
- Rollmaster Timing Chain Slack after 10k Miles...
- How bad did your car run after cam on stock tuning??
- Tdc????
- push rod question?
- TR- 224/224-114 or TR- 224/227-114??
- where to set the rev limiter??
- Anyone have MS4 #'s yet!? Speculation?
- 3.8 Head removal?
- $4200 cash, what can I do?
- opinions on F13?
- 415ci Cam options....
- A4's with cams come in!
- What cam with TSP Terminator heads?
- woudl that cam be good with n2o?
- head gasket question
- Complete Ls1 For Sale
- budget heads that will fit
- Need Help and Advice - Long
- How to wash engine
- Voodoo Cams
- Which Head Gasket?
- Anybody heard of the updated stock rocker arms?
- My Setup, Advice Welcomed
- valve seals shot looking for new heads
- Torquer 2 vs. F14
- Whats the biggest cam for a 346?
- cam ?
- Will TSP 200cc Terminator Heads work with a 408?
- New Injectors???
- Quick Thermostat question
- How Much More HP With a Tune?
- need opinions on 2 different brand rockers
- Building my LS1?
- Homebuilt Mini Smallblock
- Just Called Comp Cams....
- Oil pressure drop
- Cam Help!!
