- Valvetrain noise after CHE trunnion install and what CHE said- not cool
- 2004 Pontiac GTO
- Ls2 Cam HELP!
- Cammed 6.0 possible head issue
- Engine stumbling HELP!
- Cam Position Sensor Issues
- First build on LS1
- Chain Tensioner on an L33?
- 5.3 rebuild
- Gen 3 5.3
- L33 / LS3 cam / Tune
- Engine tick?
- Marine rods and pistons?
- 806 heads anyone?!?!
- Milled 243 heads Cam Search NA
- 5.3L built with dyno results!
- Broken sensor when replacing camshaft sensor
- Cam suggestion
- LS1/LS6 with factory Gen 4 rods??
- Comp cam on factory tune?
- I need help finding the right cam
- 5.3 lifter problem
- Blue Smoke on Left Bank
- Cylinder 1 misfire
- Need Thrust Bearing Help
- on engine valve spring compressor for heads with 10mm rocker bolts?
- Lowest RPM it's safe to max load engine? (not lugging)
- Gen4 rod/piston swap or just go aftermarket?
- TopEnd setup and P2V clearance?
- quickest way to remove pistons and rods
- "Round-Lobe" Cam Cores ~ What Can They Do For You?
- 1721 camshaft in LS2
- Bent Reluctor
- Is this Ls1 engine noise normal?
- engine # for 2002 camaro ss
- Occasional random misfire, high idle, and seemingly random DTC codes
- Special Guest - Denmah (Matt Happel of Sloppy Mechanics) Livestream Noon EST Today
- 398 cam specs
- What Color Are Pac 1218 Springs?
- Oil pressure gauge reading zero?????
- LS1 first startup #6 & #8 not firing
- 6.0 L96 heating over heating problem.
- Oil leak in back of motor
- Can anybody guess my power output?
- intermittent lifter tick
- Summit 8704 cam
- Aftermarket Pickup Tube to help combat these O-ring problems?
- Am I screwed? LQ4 build.
- Something to consider before buying building whatever you're doing
- ticking sound from top of motor/valve cover :-(
- Magic Stick stage 3 and stock LS1
- What heads to get LM7
- Differences in Gen 3 5.3 and 5.7 LS6
- 2002 TA switching long blocks - lots of ????????
- LQ4 and LQ9 Bare Blocks Identical?
- Ls1 parts in an Lq9
- Looking for Engine Sourcing Opinions | In Search Of L92
- 6.0 - suddenly lower oil pressure
- Heads
- Which cam for the Street Walker?
- Sudden random backfire?
- Anyone use Cometic SEG gaskets?
- 5.3 Stock Re-Ring and Lower End
- Lq4 low oil pressure sometimes
- New, thanks for adding me! Got a cam question.
- Help Diagnosing All Cylinders Misfiring
- Ignition Timing Tips
- 228/232 vs 228/230
- C5 Corvette LS1 - plug #3 fouled?
- Anyone bought delphi lifters from atk?
- Flow loss from dirty heads
- Ls9 cam
- Cross Threaded Head Woes 853 Rockers and Pushrods on 243 heads
- Rocker arm torque specs.
- 2002 6.0 swap
- Stamping or engraving connecting rods
- Does this cylinder look glazed?
- Pistons for a turbo build
- 706 Castech heads
- NGK TR55 or NGK TR6ix Spark Plugs?
- Rebuild top end
- small hole in front of block
- MS3 PRC LS6 2.5 PTV Issues
- 5.3 need for balancing
- Help me identify my heads, casting # milled off
- Any issues to be aware of replacing a single (cracked) piston in an LQ4?
- New Oil Pan Capacity
- Just my luck
- Possible oil pan gasket rear main seal leak please help.
- Camapalooza Camshaft Dyno Test Marathon!
- Main clearance question with oil pump
- Cam choice for 383 with afr 230 and fast 102
- Cam/heads
- LQ4 Not starting
- Good news! SALE!
- No power after cam wtf?!
- WS6 stores Hi-lift ASA cam/fast 92 1/8th mile results..
- Cometic Head Gaskets on Modded LQ9 and The 50RA requirement
- Throat size of 706 heads
- Ls6 springs in 5.3 wanting to go back to stock cam
- LS3 Heads on boosted LQ4 with a twist
- milling heads: how much causes intake fit problems ?
- Opinion on Lifters
- Oil around intake ports
- Bored and Stroked Single Turbo 5.3 Over Heating
- 408 rebuild what could be wrong?
- Compression test
- Oil coming out driver side header
- 6.0 LQ4 Build
- Summit stage 2 or stage 3 turbo cam
- Will LS1 stock lifters last over 400 flywheel HP?
- Oil pump on LQ4 losing prime after sitting
- Streetable z28 - finally
- New to the Game - Advice?
- LS1 TF Gen X 515hp kit questions
- Cleaning Aluminum Head and Block Sealing surfaces for head gasket replacement.
- Help?
- Got a LS1 that has not been cranked over in 8 years
- Do I have the correct 862 hg?
- Oil pump relief valve
- 5.3 z06 cam?
- Help with compression and head choice
- Oil pressure switch screen
- Trickflow 215 head default springs
- Ls1 Head/cam upgrade help_are Trick Flows worth the wait??
- Anyone running MS4 with .051 mls gasket
- Heads?
- I Need to Make Progress
- best 3rd gen LS1 oil and oil filter?
- Oil pressure question
- Boring / piston replacement
- BTR Shaft Rocker Kit + PRC 225 heads
- Best LS Porting and Polishing Service
- Piston to valve problems with Summit Cam
- Head gaskets
- Hi lift asa cam iszues
- White smoke out exhaust, Coolant pool inside of intake manifold.
- Over tightened rocker arms
- Is this Excessive ring gap N/A
- 99 LQ4 block interchangeable with a LSX block
- Breakup at about 4500
- lifters and rocker arms
- What cam to use
- LS1 Crank Nose Wear from Loose Harmonic Balancer?
- 7500 RPM reliably
- Baby Cam Thread v2
- Should I lower the compression?
- Looking for advice on ported 243 heads
- Crank length problem
- Need Info Texas Speed Torquer V4 Cam Degreeing
- Is my cam done for ?
- 06 Lm7 build
- Lifters
- 408 build questions inside
- Ls3 New OE Headgasket Scratches! Is it OK to use?
- Help Me Piece Together My 500hp NA Build
- 600hp 6.0l recipes?
- STREETSWEEPER VS TSUNAMI cam
- 2500HD LQ9 SS2 cam
- LQ9, 317 or 799 heads?
- Comp BSR Rocker system install techniques?
- Lq4 gaskets
- need advice before I light a match to my ride!!!
- Cam choice
- Lq4 6.0 heads
- TFS 215s: How Much to Mill?
- Titan 4 spec @.006 for dynamic compression
- Help noise on decel
- Making Hp with a lq4 6.0l
- Can I pass smog with bad lifter?
- 5.3 LM7 Cylinder head recommendations
- Newbie doing head gasket - sanity check
- Weird groove in crankshaft counterweight.
- Oil flow route through cooler port?
- First time cam swap opinions.
- Best flat top pistons
- Ls cam help
- Effects of valve lift on part throttle.
- Cam swap with heads on - lifters stuck in tray?
- Check internals after hydro lock
- Low end torque with this combo
- 4.8 cam swap issue
- Odd ring gap question
- cam replacement for a custom grind...without retuning?
- Piston clearance
- Caming my ls1
- Do truck 243/799 heads have standard length valves?
- Steam vents on Heads
- Need assistance
- Inside of valve cover ? Help?
- Need recommendations
- 4.8 vs 5.3 rods
- Nova Smokin
- best ls lifters
- Misfire maybe
- Help me cam my ls1!
- Help identifying pistons
- The simplest thing you will read all day.
- Head bolts for LQ9 with 243 heads
- 6.0 862 FSJ Build
- 1996 5.7 cranks but no start
- Cam identification
- L59 idles rich on bank two.
- Hyper vs Forged piston for 6.0 build
- Oil Pickup o ring.... again
- Full 5.3 rebuild won’t fire
- Valve Spring Change with engine in car.
- Any good engine performance/machine shops
- LQ9 daily driver build
- Are my heads any good
- 5.3 build
- Engine oil life
- 7.4"+ pushrods for 2116LSR lifters??
- Cam help 427 ls stroker
- Ls1 mods hp
- Head Studs
- LQ4 nicked piston, replace or run it
- Oil Pan Pickup O-ring
- Timing set recommendations
- Camshaft selection for my C5
- BTR .660 springs on Trick flow 220 heads
- Normal??
- While I'm in there......
- Oil filter adapter m22x1.5
- TSP 216/220 low lift chop?
- What to do with pistons? 5.3 lm7
- 243 Heads - Heavy Valve Deposits
- Cam Bearing O.D. greater than journal I.D.?
- Are there different versions of the 317 head? Re: head bolt lengths
- LS1 short block hard to spin
- break-in, oil change, and type questions
- Another what cam?
- Comp 54-777-11
- 5.3 swap upgrades
- ARP Head Studs too short
- Solved: Elgin Lifter Preload? Research to find top secret data inside!
- PTV check without pulling heads...
- LQ4 Pushrod Length Help
- Lq4 build looking for 800+ all motor suggestions
- Cam only lq9 which big nasty cam should I get for my setup
- Metal Oil Galley Plug? or Plastic?
- .020 or .030 mill with 862 heads?
- Strange Oil pressure issue
- Pushrod length calc spreadsheet and data collection form
- Does this crank pulley look wobbly?
- which heads lq4
- Need a built LS7.
- Intakes on 317 heads.
- LH6 pushrod measurements seem off
- LQ4 Torquey "build" cam help
