View Full Version : Generation III Internal Engine
- Crank pulley and alternator pulley?
- left&right head gasket.WHY?
- people need some help in my engine !!
- 5.3 cam swap and pushrod length
- AFR 215cc LSX heads
- Need advice before LQ9 purchase (PTV/mods/etc)
- Knock sensor help
- 400 rwhp, is it possible?
- Starting my H/C swap soon, last minute questions
- cam help
- Forged internals stock block
- a good qusetion
- Truck motor questions
- Announcing a new LS-series "How-to" publication:
- AFR heads
- destroker!?
- lookin for a true stock bore ls1 aftermarket/forged piston
- Rollmaster Double-Roller Adjustable Timing Set
- Need some advice for Cam (Ls1)
- Need help car won't start?
- spec me a cam!!!
- Too much spark?
- Porting intake to head question, HELP!
- Mechs and Techs...PLEASE HELP!!!!
- Books
- 150K miles Crankshaft,Rods,Pistons reammemble?
- Finding pushrod length for correct lifter preload - Dial Indicator vs. Zero Lash
- black smoke :(
- Patriot stage 2 ls6 59cc heads a good choice?
- Help my tight ass pick a H/C setup based on my goals
- TR230 cam, what valve springs?
- car idles really low and eventually shuts off!!
- What is comp ratio, LS1 w/ 5.3 heads?
- Help! Crank pulley fell off!
- what should i get?
- Where to buy a new shortblock?
- Another cam question
- What Heads/Cam/Intake combo for me?
- 160K. Heads and cam??
- Do I upgrade the timing chain on an LS1?
- wtb 317 heads
- LS2 C6 vett how much power can i make before i should worry about the bottom end
- Clutch is hittin the floor?????
- can't get my balancer off, any ideas?
- spark knock/valve clatter?
- Help me out need info quick
- What does it cost?
- Tune after cam?
- Help!! Tapping noise when engine is warm.
- Help me find a Engine and Trans
- 408-418
- PRC LS6 2.5 or PRC 5.3L with MS3?
- What would YOU do??
- bad bearing, weird issue, advice?
- Quick question when switching from perimeter to center bolt heads
- does anyone have a sound clip of a 228r 114 lsa?
- Oil on #7 spark plug?
- TI or Steel
- with this cam work
- 408 hp/tq
- confused????
- i bought a 5.3 for, i need some help
- cam card info for chet herbert?
- Would 5.3L heads be a bad idea for my LS1?
- need info on a good cam for my 2000 trans am
- Alternator pullies, Timing Chain, water pump, spark plugs?
- People who have made a 408... I need a total cost!!
- i wanna go the other way...
- stroker kit
- What cars/trucks come with LQ4 motors?
- thermostat Q
- lq9 vs lq4 differences
- Need LS6 truck motor info
- is it dead for good...with video
- please help me identify this cam
- 6.0 block...
- I made a booboo with my timing cover install
- Rpm international?
- Problem replacing YellaTerra Platinum rockers ?
- LS1 misfire problem
- Tsunami cam?
- What is the thread pitch (TPI) of the Rocker Arm bolts?
- planning 408 stroker build
- ls1 block ls6 heads but what cam??
- Valve Spring Question for MS3 Cam
- everyone using USED cams/lifters/spirngs/rods etc and there thoughts about it
- 4.040 bore 4.100 stroke dish from where?
- dream ls_ block to take down a ford 460
- 918 install???
- Will this work?
- Blue Smoke...Rich?
- cam sensor
- Little advice please
- EMERGENCY HELP! Valve fell in, but not all the way?(PICS!) Spring change nightmare
- Timing chain install
- How much over is this?
- Engine Power Systems
- 1998 LS1 vs 2000 LS1
- Any advice on cam selection.
- Ngk spark plugsTR55 go .040 or .060
- Timing chain slack...
- 408 who to buy off?
- Has anyone tried or used one of the ebay regrind cams? Opinions?
- Best double adjustable Timing Chain?
- LS6 ported oil pump vs SLP oil pump
- Help with cam
- 98- 806 heads vr 241 heads
- '04 LS6 head bolt torque specs???
- oil dipstick o-ring
- Eagle 383 stroker?
- 1/2" head studs
- stroker kits any ideas
- Need help big time with stroker kit
- Cam Swap - Tools Needed ??
- Pushrod length question H/C and rocker swap
- 228/232 cam results??
- Advantages of Aftermarket Rockers?
- H/C question
- Heads/cam swap result ....crank no start...
- 5.3 block guys come in
- What GM ls camshaft doesnt have a cam pos sensor
- L92 conversion
- How to determine value of used LS1?
- Swap from 241 to 243 heads?
- Valve seal help...
- rhs heads.
- New Style Rear Main Seal
- Cam help
- Procharger belt size
- Where Can I Find An Ls6 Shortblock?!
- What Causes A Spun Bearing?
- Help me with headgasket choice
- stock rockers w/ aftermarket valvetrain...help!
- question/problem
- My motor takes a dump.
- Heads/cam swap--Stock or Aftermarket Rockers?
- teching knock sensor
- FAST Intake rope seal help
- 414 commpression question
- broken valve spring dart heads takes out yet another ls1
- car wont stay running/horrible missfire
- need help please read
- prc 2.5 ls6
- LS6 cam plus what heads? Results?
- cam problem help needed
- What would you do?
- ***Quick intake question***
- 4.8 turned into 5.3
- perfomance module
- thermostat question
- Having issues with an SD tuned 398 FI engine..
- Default What should an A4 H/C LS1 Idle at?
- Stupid, but very lucky!!
- Support mods for larger cam
- rollmaster to tight
- 6.0l build need help
- Stock Bore LS1 Ring End Gap
- What's wrong now!!!!!!
- question about knock after head/cam install
- Blown head gasket
- got my new engine running and having a vaccum problem!
- Arp main bolt torque specs
- How Much HP, Per 1 Compression Increase
- Cadillac Racing lifters?
- Do PAC 1518 springs drop-in to 5.3L heads?
- What can I gain w/ TFS heads
- HELP, problem after cam install, sloshing sound
- Pushrod length doesnt seem right(Using a checker!!!)
- Which are all the CAMs pass C.A. SMOG????
- Bbk intake, and bbk throttle body!? Is this a good set up?
- Stepping up to a larger cam have a question
- Tell me about this cam
- Another dropping engine out the bottom questions
- Did a head swap and now my car runs like crap.. if at all
- 427 build
- almost time or a rebuild
- HOW TO REMOVE OIL PAN!! help
- Oil cap with vent AND one way check valve?
- Pred Z cam LQ9 - Videos
- Cam for stock heads
- Premium aftermarket heads vs. Stage 2 LS6 heads
- Car went boom! help! 01 T/A
- FAST 90 intake port gaskets
- NGK TR6IX, what gap for N/A, what gap for 100 shot?
- $1400 to spend...
- Blowing smoke out of the tail pipes
- 706 heads on a budget
- Need some help with motor problems (Intake Runner size, ring gap, etc)
- need help bad plz help
- Who else sells a dual catch can option?
- an embarrasing cam question
- Inspecting/refreshing an ls1 bottom end?
- Thoughts about AFR 205 heads and MS4 cam
- absolute best single timing chain 8500 rpm, 800 lift?
- Advice about cam install.
- If you have an LQ4 with aftermarket heads/cam COME IN!
- Spring replacement
- Trick Flow prices?
- JESEL .187 beam and AFR 8019 springs
- Head/Cam for 427ci Truck
- Cammed car reliability
- Oil Change Light
- ms3 combo????
- Building Road Race LS6
- head porting question? sorry i know another one
- Head Bolts?
- lsx weight
- Using check valves or pcv valves with vented catch cans?
- 2.055 Valves on 4.00" bore?
- Anyone using PRC EHT .675" Springs ?
- New build
- 243s
- Has anyone heard of this
- Cam & Heads, what needs done?
- dyno numbers
- Missing Shims & Perch On Yella Terra Ultralite 1.7's
- 225K mile LS1
- Cam before headers question/advice?
- Thunder Racing CheaTR setup
- what heads you running with the 228r?
- 5.3 heads vs 806 heads
- anyone got specs on the valve spring tool pictured here
- few questions on my upcoming mods
- ? about Comp 941 springs
- ? how much does a set of stock internals for a ls1 cost ?
- Valve spring part 2
- is there a cam for 1.8 roller rockers
- Looking For Reliable Sleeper H/C Set-up
- best combination for more power
- Help - Bent intake valves
- engine swap wont start need ideas !!
- Fastest LS series car and most power NA
- Home Porter Pics, NO CNCs
- Stage 2 Ported 853s?
- stroke or not to stroke
- what heads to run with a ms4 cam?
- Need someone to crosscheck me
- Rocker Arm Torque
- Push rod install question
- How much can LS6 springs be shimmed when using ASA cam?
- valvetrain noise and pushrod question
- rods orientation question
- g5x3
- LS1/LS6 rocker arms..
- Wilson TB with LS1 IAC
- Tapping!
- Valve Spring suggestions
- new pistons??????
- Yet another Cam question
- another tapping thread!!!
