View Full Version : Generation III Internal Engine
- Winston Cup Technology coming to LS1. . .
- Cam swap on high mileage motor?
- What might this be???
- puff of blue smoke on start up???
- Rev dual springs w/ G5X2 cam?
- 1st Patriot Heads & G5X-#3 dyno #;s
- Ideal big HP spray cam for 6.0L 372 Iron block motor
- Jesel users inside please
- Compression Ratio for Milled heads
- Bottom end build up
- What is the maximum lift LS1/LS6 and LQ9
- Help me pick my heads and cam!
- Help me fool my friendly local GM tech - which cam is stealth enough?
- Compression Experts....who has calculated Dynamic Compression Ratio?
- any1 waiting for there patriot heads???
- Which Block
- standard oil consumption for aftermarket Cam cars
- TR220 and 1.85 rockers
- Thinking of trying a new cam setup
- ARP head studs torque specs?And wath head guskets
- anyone have pics of ls1 vs ls6 block?
- crane cams dual valve spring
- Any sites on degreeing cam on LS1?
- Hot cam vs.. Tr 220 ????
- LS1 Heads .vs LS6 Heads
- Need a couple of LSx specs
- Received my Patriot LS6/LQ9 heads today!
- Cam Advance and Retard... which do i do to make this change?
- will oil analysis show if bearings are hurt?
- Why are stroker motor tolerances "looser"?
- 1.8 Rockers and TR 230
- anyone with the origional G5 cam and the new patriot 5.3 or LS6 heads?
- Degreeing the G5X2... Who's all done it?
- If the ASA cam makes good torque
- Quick question..
- how the pro magnum's?
- 1,200 for cam install... WHAT...
- Anyone able to get the Comp adjst shaft rockers to work.?....
- Can ls1 head bolts be reused?
- What kind of cam in firehawk
- TR224/112.....Rev limit?
- What cylinder is what?
- Where would you go for a 427 package
- Future 3 valve heads that bolt to LS1 block
- 6.0L 372C.I. Iron Block N/A Power.....??
- Need info on fly cutting
- Streetable compression?
- I have an X1 MTI cam...I'd like something bigger...
- Still sucking oil w/ LS6 valley cover and catch can...
- Working on being in the 10's cam only
- What does a new cam cost and which should I get
- Heads-Cam Installed; Early Impressions
- Am I getting beat up on this deal??
- H/C or Stroker
- cam install gaskets
- Cam install nightmare! broken crank bolt!
- Patriot LS6 Heads with 6.0 liter iron block
- difference between 806 and 853 heads?
- A4 W/224
- head gasket or cracked block?
- LSX intake and camshaft design
- 5.3 or 5.4 engine?
- SLP 1.85 Rocker Arms
- C5R heads VS LS6 heads
- Rocker Arm bolts and Loctite?
- Oil Pump porting
- AFR New LS1 Heads
- ABS heads/TR230 update...Track results!
- Looking for 382(3) & 402-408(9) Dyno#'s
- How to install LS6 intake manifold?
- How do istall valve springs and retainers?
- Pulled the intake and found this....
- Who makes a solid roller head setup?
- H/C installed/tuned 421.2rwhp/387.5rwtq
- Still looking for Hp after cam install.
- Heads/cam/LT install. Any tips for 1st install.
- When to change injectors
- Heads/Cam= maxed out injectors???
- Stroker-Explain Piston,Rod,Crank Events Please
- Colonel (update On Ss2)
- compression test of z06
- Problem with cam swap
- Darton Wet Sleeves
- Dyno today - 6.0L, Absolute Heads, etc
- The real deal on the ASA cam?
- Yet another new best thread w/ Absolute Speed Heads
- Can I replace just my rods and pistons myself?
- When to change oil???
- AFR heads?
- TEA Juding Massengile seris heads - Can anyone post pictures?
- Which Cam??
- Best Cam with stock-heads,ExManifolds and tuning
- Cam specs of Cartek "X" pkg, or JPR pkg?
- 383 Stroker LS1
- LPE's GT2-3 Cam.. Do i need new Pushrods?
- Valve stems 11/32" or 8mm
- 2002 Zo6 PVC system
- who makes a 4.125" Crank?
- Get My TR224 on the 28th
- hehehehehe!!!!!!!
- Got into a discussion today about Iron vs Alum and Nitrous..
- Rod Bolts
- Absolute Heads rock! Just back from the track
- HELP, engine noise?
- Vacuum pump to evacuate the crankcase and pull rings to the
- Need valve spring reccomendation.
- Cam swap and tuning.
- Can I dyno like this...?
- MTI changed, now need resleeved block for under $2k.
- Lunati Cam 242/242
- How can you determine how much advance is ground into a cam?
- Cam gurus: please assist ...
- What is a good price for rods/piston install??
- cam/spring help needed....
- How can I tell what block I have?
- Anyone with big bore motors have 2 different size pushrods..
- TR224 with a 7.350" Pushrod?
- Any negative affects running a 90MM LSX intake on H/C 346ci?
- Reverse split for a n/a stroker?
- ZO6 valve springs
- Anyone had 02/03 ZO6 valvesprings go bad.
- Comp R lifters, do i need new rockers?
- So my fuel pressure was 100psi at idle all week thanks to..
- need HELP deciding which cam
- Valve spring install tools?
- More info on the Gen IV
- valvoline racing synthetic oil???
- taping noise
- TR220 guys inside
- Anyone know the compressed thickness of a Fel Pro 9284PT?
- Anyone got a 224/226 .567/.569 112lsa? Dyno/powerband ?
- need help deciding on a cam
- Need help with valve spring pressure gauge.
- 230+ duration cam cars.. how useable is 6th gear?
- Specification Comp 26921
- wt do yall think
- What affect does advance ground into a cam have?
- TPIS cam recommendations
- Question about higher ratio rocker arms
- combustion chamber on heads
- Crank Bolt
- new lifters ?
- AFR heads
- Got a cam and want some opinions???
- numbers from C2 cam?
- cam question/ can I do this?
- Anybody here got a Lunati 408 stroker?
- Putting in ARP Rod bolts, should I replace rod bearings?
- 3k in engine???
- Alright guys, my car is almost back together! Whatcha think?
- Crane Cams Dual Valve Springs drop in no head work?
- The comp R series lifters are in the car now,have a question
- Oil pump w/ heads/cam setup...
- Would you buy a used cam with 10k on it?
- How thick is the metal 2001-2002 head gasket?
- F1 Cam From Speedtek Performance
- Two part question about dynos and flow numbers.....
- I have had 3 shops wanting to build me a 370ci motor. *DELETED*
- P.O. 342 After Heads Cam Swap...
- estimated whp loss with moser 12 and 4.11 gears?
- Good Sparkplugs
- Need some help!
- anyone have the thunder racing 227/224 'reverse split' cam?
- Opinions on RR's?
- GUESS MY Horsepower
- Lunati 382 guys....please look
- Any Tips to Tell My H/C Installer Before Starting?
- Didn't Get "Flow Sheet" with my New Heads
- DRE rockers, the untold story
- Flycutting in car in Fbody?
- T&D rockers with non solid roller heads?
- need help w/ heads and cam issue...
- Dyno question......
- post media clips of "stealth" cam or similar cams
- What makes a camshaft fail a smog test??
- I was in my friend's Z28 w/ the G5X-2
- thinking of another cam swap (is this too small)
- what cam should I use?
- Would too much oil in cylinder cause engine to die?
- How to remove ASP Pulley
- Broken Timing Chain?
- 2002 LS6 Cam Upgrade. What is needed to do it right?
- Colapsed lifter symptoms?
- Crane Cams Dual Valve Spring and TR230 good combo?
- Cam spec questions
- What symptoms and signs of sugar in the gas tank??
- Lunati stroker kits
- Dyno #s
- It's alive, video w/in of how she sounds
- New Dyno numbers with TR230, graph inside
- what do ya think of comp 921 springs?
- Who wants to play the guess my compression ratio game?
- ring end gaps on nitrous engines.
- Anyone ever figure out flywheel imbalance problem?
- bent valve?
- gremlins in my engine!!! HELP!!!
- How long should Comp 987 dbl springs last on a 231/224 cam?
- Engine smoking, heard whirring noise from fuel tank, & codes
- will tsp231/237 cam clear with my heads
- BEST HEAD GASKET
- AS heads G5X2 update
- all cleaned and ready...
- DON'T Strip Your Crank Threads > Here is some info you need!
- If your Dyno Graph looked like this....
- Do I need a special pushrod for Comp R lifters??
- Has anybody seen this site??
- Comp26921 Dual Springs
- Need a site to print out good info on cam install please
- Anyone running this cam?
- How Much HP can Ported LS1 stock heads support?
- Dynoed my WS6 today
- Stock rocker arm lost its bearings???
- Old vs New Lifters
- Question..........LS6 "CNC" Heads + Intake:
- Do New LS6 Longblocks Have Piston Slap/Oil Consupt. Issues?
- i dropped a lot of coolant in the cylinders...
- Good heads cam for a blower ls1
- what could cause 16 bent pushrods on start up after cam swap
- tr 230
- Yes, Another Cam Question
- i need cam recomendations please?
- lift vs rocker ratio
- 02 ls1 auto cam
- OK guys, help me figure this one out.
- for all those boasting high #s NON tuned...
- Ported head people, please post......
- Lifter Change Question?
- Why would sponser basher have 330+ post and only 2 show up
- what cam are the guys with stock heads running?
- anyone use the comp cams renegade lobes yet?
- Repost: 439rwhp untuned
- TSP231/237 cam in a A4
- Pondering new cam...
- Flycut the pistons for G5X2 Cam?
- AFR heads available soon!
- New cam coming for the 427...
- 2001 need rockers in cam swap??
- Quick Question
- TR224/224 112 LSA when does it fall off?
- any new tr230 soundclips
- Cam "experts", what would you......
- 6.0 aluminum block rumours
- Anybody with Cylinder Heads and Cam....
- PCV question
- GM bringing GEN IV to the SEMA show NOV 5 in Las Vegas....
- weight of comp magnum roller rockers
- Max Safe RPM For LS1 Valve Springs?
- 231/237 yes it sounds good but how does it run
- TR230/224 + Comp 987 Springs = valve float????
