View Full Version : Generation III Internal Engine
- Whats the benifit of a "squared" motor?
- Anyone with H/C knowledge & experience, Help me out!
- Anyone running this combo...
- Car running hotter after Heads/Cam Need help.
- What H/C, bolt-on setup for max rwhp in a daily driver?
- How much can I spray on my h/c setup if I get JE forged internals and main bearings??
- ASP and Rollmaster double chain
- Valves and bore size
- MMS stage 2 heads/cam dyno results: 400/419
- HELP!! Need Hot Cam advice. WTF!
- Heater Core
- Car running bad after gauge install?
- Coolant Leak
- Bent Push rods?
- comp 224/228?
- ASP Crank pulley + Aluminum Flywheel + Big Cam= A ton of surging
- which pistons? help! rebuilding bottom end
- Cnc GM ls-6 heads and ASA cam anyone try it?
- What else do I need to install a cam & headers?
- LS6 01 vrs. LS6 02 differences???
- Oil cumsumption (leakdown-compression test)
- anyone done 02 ls6 cam with s2 heads?
- what gains: stock SS with 226/232 and .568/.568 comp. cam???
- B1 or change?
- GM Head Gaskets
- Milling heads on stock internal motor?
- How much honing can be done before....
- Paging George C or anyone with solid roller.
- ATTENTION: SIG LENGTH LIMIT!!!
- I am stuck helllppp!
- putting 98' head back on my 2000 .. couple of questions
- 2001 Injector Limits?
- 226/226 .591/.591 112LSA cam with 918 springs?
- I can do a compression test right?
- Bore and stroke sizes in relation to c.i. on LS1
- ls6 cam
- cold idle not great
- Cam Experts...
- Timing Set Replacement Question.
- Head Porting help..porter is stuck in high 270s
- LS1 339 Head Casting Number?
- Listen to my valvetrain and tell me what you think
- Cam install question
- A few more "just wondering" questions about strokers, compression, and power...
- Oil filler cap smells like gas......need some help....
- WTF!!!! Broken Valve Spring
- CNC heads and TR224 cam is in!!!
- Is there an equilibrium between lift and duration?
- Do I need to fly cut....
- Polishing heads worth it on stock internal motor?
- cam & valvespring?
- Signs of incorrect pushrod length?
- Base Circle of TR 224/224 112 cam?
- Paging anyone that has had trouble with double springs and rockers
- Paging {{{{{{{{{{PATMAN}}}}}}}}}}}}
- Titanium vs Stainless Steel Valves
- need a sensor part number
- I need help with my idle/stalling/surging probs after heads/cam install
- piston slap(ing) I think....
- What cam with ported 4.8 truck heads?
- What Parts needed for Head Swap
- LS6 heads vs LS1 heads
- Anybody know 99 F-body cam specs?
- Hotcam dyno results...
- 382 with supercharger what cam to use
- miss shift with m6 help bad noises from car now
- Jessel 2.1 ratio rockers
- Any 230/230 sound bites????
- Oil consumption Q? 500mi/quart?
- please lend me some advise
- What should you look forward to? Heat or humidity?
- How much to mill 5.3L heads and pushrod length
- I can't find a Freaking Shop to do my H/C install!? Little Help :(
- It's a different world above 7500!!!!
- How many miles before Stage II heads & cam?
- which pushrods should i get for this cam?
- Can a 'Hammer' cam be installed without changing any other internals?
- How long will my stock pushrods last revving to 6800rpm w/ 430rwhp?
- Thoose with 918's are you useing the titanium retainers??
- HO2S Insufficient Switching Bank 1 Sensor 1
- How much is a ring job
- EEK Confusion in my garage Please help
- what could happen if valve lash isnt set correctly?
- Gotta rebuild....What to - MODIFY - !!!!
- Surgeing
- Cam sounds and videos?
- 5.3 heads
- you guys gotta read this! unbelievable oh my lawd.
- Need your advice about my cam install....
- Audible ping @ low RPMs > bad gas?!
- Vacume leak :( Help me find it!
- I'm still a little unclear about how to correctly perform a heat cycle.
- B1 cam
- Giving up the bottle and going all motor. I need cam help w/ARE StageII heads.
- Project Dragula Update 8/19/02
- Valve Tapping
- LS1 vs LS6
- How much are Thunder's solid roller cams?
- 2002 Cam specs
- ANYONE WITH LARGER THAN STOCK CI'S
- TR 224 Installed Last Week
- Missing coolant?
- Lingenfelter Dry Sump System
- Who is running XE-R lobes and stock lifters?
- My quest for a cam more aggressive than XE-R lobes continues...
- Lifter preload, pushrod sizing questions?
- Enlight of my last dyno last week. Do you guys think I still have a problem?
- Cam/dyno experts, look at my dyno, I think I’m low...
- Cam ? 1,000,001 Search didn't help
- Will Jesel SS rockers fit under stock valve covers??
- BOTH heads cracked!!
- I'm confused...stroker motors and compression...
- I know LS1 valvetrain is loud, but damn
- Highest safe CR for 9-10 psi?
- Remote oil filters for LS1
- What are the parameters required to match a cam for a given set of heads?
- Engine Failure!Diagnosis opinions wanted.
- 6.0 heads
- Sound clips please!!!
- 918 and 941 spring question
- 5.3 block the same as 5.7?
- White smoke at WOT on dyno???
- Pic of blown Motor
- How do you guys get the oil pump out?
- Heads/Cam questions for a 382 Stroker
- Horsepower Store Stage 2 Heads
- Slp Package
- How do you test the Cam Position Sensor?
- 69 ZL1 cars, where are they?
- No fuel flow!
- When are double springs needed
- I NEED sound clip of c2 cam!
- Easiest way to get a dropped Lifter
- Sound/Video Clip of the TR 230 cam w/ TEA heads & true dual exhaust
- New Hotcam Dyno #'s
- What cam to go with....Help me make a decesion....:)
- Need specs for stock heads
- 5.3 vs 5.7 vs 6.0 L heads??
- TR224 cam Dyno
- TR224 cam Dyno
- Lifter Preload
- idle problems
- 411.5rwhp with ford 9" and 4.30 gears
- Will a bored engine have piston slap and oil consumption?
- TR 220 cam users! > Please tell us your impressions
- Who sells valve springs one by one?
- Pulled cylinder heads and this is what it looked like
- Need an Opinion Please
- Ruined Motor
- No Oil Pressure
- How many 918 breaks do we have on here? Pics of MINE BROKE
- Oil pump?
- who has T1 sound clips???
- who is using the T1 cam???
- Bent some valves, drove it around w/out knowing.....is it alright??
- motor specs
- Biggest cam in a 346????
- How much Power
- More Horsepower
- another top end cleaner question and water wetter question also.
- drilling out TB on a mms 229 cam
- Low dyno and low track times?
- trouble starting with cam
- Casting numbers 862
- Thunder Racing or GTP stage 2 Heads?
- LS1-LS6 conversion
- Misfires cam related?? car sputters really bad
- Apx. How much $$ for head/cam package?
- mti s1 cam with nos question
- Dyno Numbers!!!!!!!
- Why does no one run stage 3 heads? $$ issue?
- Head casting number ???
- RPM Problem
- 6.0l blocks
- New motor is smokin...need some input from the experienced guys
- If you were going to slowly build a motor part by part
- TR 224/227 .563/.569 114 LSA
- In general, what determines rev limit?
- I figured it out!
- ATTN ALL TR 230 CAM OWNERS: How big of a TB hole you got and where is your idle set?
- Gaskets, Bearings, and O-rings....Oh my
- help me build/choose my bottom end
- How do I remove motor from top? with trans?
- Does anyone make hydraulic LS1 lobes that are slightly more aggressive than XE-Rs?
- Thinking about trying a BIG reverse split
- drilling out TB on a 224/224-114
- AMS SOM TA in GMHTP- yep, thats right!
- Progress
- STROKE IT OR WHAT?
- LS1/LS6/C5R engine seminar-Katech-17th
- Is it safe for me to drill up to this size??
- What cam are you running in your 346 H & C combo?
- What mods to make a motor more reliable?
- How to check valvespring installed height?
- Could a cam cause high idle in gear?
- 383 ALL BORE OR 382 STROKE
- HOW WOULD THIS RUN?
- 230/230 .578 114lsa -> 230/224 110lsa...what are the possible gains?
- Is this too much???
- 383 stroker
- Pistons??????
- LS1 windage tray: do we have it, who makes em?
- R.G.R stage2 heads dyno results
- TR 230/227.569/.569 111 came in today!!
- Hey guys, tell me what you think of my new heads "pics inside"
- Anyone taken their LS1 in a FBody out through the top?
- Dyno Results!! TEA Stage 2 5.3L Heads w/ TR 230/224 cam
- Which Oil to use
- Anybody want an NGK spark plug sticker?
- LS6 intake install questions.
- 4 degrees KR, help!
- EGR removal
- Mixed Rocker Arm Ratios
- Not your usual LS6 intake question.
- smok'in
- 6.0L Heads
- Do I need Double springs for a Heads/Cam/Nitrous set-up?
- need help with my bump stick
- Got questions about Heads and Cams
- Question on Pushrods
- LS1 EWP part 2
- Who had dropped a lifter when installing a cam?
- HELP.... Are there stampings on a LS6 camshaft that will confirm that it is a LS6
- If the Thermostat is a restriction, can you remove it in the summer??
- Anyone using 2002 LS6 valvesprings?
- SLP double roller will reduce topend power right?
- For those of you with piston slap..
- WHAT'S THE BEST WAY TO GO?
- Woohoo!!! I have enough P/V clearance w/ the TR230 and milled heads!!
- some questions Thunder 224.224 112...
- differences in cam L/S
- 6200 or 6300 RPM
- JPR S2 heads & TR 224 cam dyno results
- X1 cam and 383 dyno
- Cyl Head Build Up
- ASA cam install results...
- Anybody ever do a heads and cam 6.0L
- Rebuild or Shortblock?????????
- 2001 Valve Seals
- Help me out with this proposed setup please....
- Bottom End
- C2 Cam Installed need help
- Light Weight Valves?
- TR 230 on stock manifolds with no tuning will it even run?
- valve seals for MTI stage 2 heads???
- Looking for new cam for 382 stroker
- My TR 224/227 112LSA must be TINY !!!
- 6.0l short blocks
- Header wrap: bad idea?
- What about this 6.0L setup?
